error 6C10 on Canon Printers
medenko ::
Kako kaj rešiti? Imam pa MP540, filam z kompatibilnimi že leta :D
amigo_no1 ::
  • spremenilo: amigo_no1 ()
medenko ::
hvala, bom prebral.
Hi there they say the new printers same as you got cant be reset it go to be the shop to do this but you can try this, but pleas can you come back let us know if it worked so other can use this trick, Thanks
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
3. While holding the Power button, release the Resume Button.
4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
MAY WORK ON A MP550
Here this step by step to resetting waste ink counter printer Canon Pixma MP450
1.
You will turn off printer.
2.
retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3.
you will let go button Resume/Cancel, continuing to retain POWER.
4.
press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5.
when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6.
you will turn off printer by button POWER.
*** Some models have a Stop/Reset button instead of Resume/Cancel button.
  • spremenilo: medenko ()
Tiskalnik Canon MG2150 megleno tiska
192724 (2390) francek1
Apple
224417 (2159) WallSreet
Nokia E51 se ne prižge
61160 (1110) ...:TOMI:...
Samsung galaxy note BRICK
Oddelek: Mobilne tehnologije
204618 (4105) CaqKa
nujna pomoč - problem s tiskalnikom
61218 (1149) Highlag
