Forum » Pomoč in nasveti » Eror
Eror
Bellatrix ::
Ob inštalaciji igre se mi pojavi tole:
An error (-5006 : 0x80070017) has occurred while running the setup.
Error Information:
>SetupNew\SetupDLL.cpp (841)
PAPP:Caesar IV
PVENDOR:Tilted Mill Entertainment (http://www.tiltedmill.com)
PGUID:B7666229-351B-47D9-AA6F-DF777CF04BBF
$12.0.0.49974
@Windows XP Service Pack 3 (2600) BT_OTHER 256.64
Zna kdo to prevest ?
Error Information:
PAPP:Caesar IV
$12.0.0.49974
People are quick to judge and slow to correct themselves.
zvery1 ::
Google pravi tole:
This is an InstallShield runtime error message. It appears to be having problems finding the Windows folder on your system.
You can read more about the -5006 error here:
http://support.installshield.com/kb/...icleid=Q111253
In your case It appears that it is having problems with or finding the setupdll.cpp file.
It may not be getting copied to your system from the CD during the install process. Check your CD for any fingerprints, dirt, smudges, or scratches. Clean (carefully with a soft cloth) any dirt you find by wiping from the center hub to the outer rim across the CD surface.
Next, clear out your Windows TEMP folder. The installer dumps files there during the install and if that is full or cluttered an install may fail.
AMD X6 1090T, 16GB DDR3, GF 750Ti, Gigabyte 890XA-UD3,
1 x SSD, 4 x HDD, running Ubuntu 14.04 x64
| » | Ne predvaja novega audio CDOddelek: Pomoč in nasveti | 2618 (2574) | Tea Time |
| » | Linux / netOddelek: Pomoč in nasveti | 2054 (1727) | roscha |
| » | ne morem bootat v graficni nacin v red hat linuxuOddelek: Operacijski sistemi | 1526 (1478) | robinzon |
| » | Iščem alternativo vudujuOddelek: Kaj kupiti | 2450 (2214) | Arthur |
| » | Whitler (strani: 1 2 3 )Oddelek: Operacijski sistemi | 10094 (8536) | zetko |
