Forum » Pomoč in nasveti » Mp4 to mp3 ali dober program za ytube ali druge strani
Yugos ::
Probal 10 programov iz FF addon in cnet, vendar so zgleda vsi review-ji napisani s strani proizvajalcev, super program nobenih preusmeritev ni, nobene navlake, potem daš dol in samo 3 min dovoljena konverzija in na drugo stran te da.
Imam addon ki mp4 dol da nimam pa mp4 to mp3 ki bi delal brez problema, naj napišejo tisti ki imajo delujoči progam ne tisti ki v google napišejo mp4 to mp3 ali xilisoft in podobna sranja, ki po 5 dl crashajo namerno!
Yugos ::
Yugos ::
No Can Do ::
Mobile media converter
The Mobile Media Converter is a free video and audio converter for converting between popular desktop media formats like MP3, Windows Media Audio (wma), Ogg Vorbis Audio (ogg), Wave Audio (wav), MPEG video, AVI, Windows Media Video (wmv), Flash Video (flv), QuickTime Video (mov) and commonly used mobile devices/phones formats like AMR audio (amr) and 3GP video. iPod/iPhone and PSP compatible MP4 video are supported. Moreover, you can remove and add new formats or devices through the internet.
An integrated YouTube downloader is available for direct downloading and converting to any of these formats. You can trim your clips for ringtone creation or any other purpose and crop your videos for removing up/down black bars or other unwanted parts of the image. Additionally, embedded subtitles can be encoded onto the video for watching movies or shows with subtitles on devices that does not supports them.
The program has a very easy-to-use and simple GUI (Graphical User Interface) that helps even the most amateur user. Most of the times, the only data that you must enter is the input file(s) or just drag 'n' drop the input file(s)! The 3GP and AMR formats are used by mobile phones for MMS, video and sound recordings, etc.
This user may use sarcasm and cynicism
in a way you are not accustomed to.
You might suffer severe mental damage.
Cold1 ::
jDownloader je namenski program za snemanje podatkov s spleta, ki poleg drugega podpira tudi prenašanje posnetkov z YouTuba. Omogoča pa prenos vseh variant posnetka tako mp4, flv, WebM kot tudi mp3 - YouTube namreč vsebino shranjuje v več formatih hkrati (in več ločljivostih - 360p, 480p, 720p in 1080p).
jDownloader-ja najdeš tu (povsem zastonj in brez omejitev):
http://jdownloader.org/
Potreboval boš še Oraclovo Javo (zastonj):
http://www.java.com
(Zavedaj se, da je Java vir varnostnih groženj, če ni posodobljena; in tudi, da jo je v spletnih brskalnikih najbolje onemogočiti - javanski programi na namizju bodo še naprej delovali, zgolj napadom preko brskalnikov se s tem izogneš.)
Če pa želiš zgolj pregledovati posnetke na YT pa je najprimernejši kar video predvajalec Minitube (ki omogoča tudi prenos posnetkov - je pa ta funkcija omejena v demo inačici).
Minitube je na voljo tu:
http://flavio.tordini.org/minitube
http://www.java.com
- spremenilo: Cold1 ()
| » | Youtube to Mp3 (strani: 1 2 )Oddelek: Pomoč in nasveti | 25380 (615) | BlackFox101 |
| » | youtube v mp3Oddelek: Pomoč in nasveti | 4126 (3611) | Riff |
| » | Download video (flash) iz rtvslo (strani: 1 2 )Oddelek: Pomoč in nasveti | 60681 (23091) | Pizzicato |
| » | DLNA mreža za TV (PROGRAM)Oddelek: Programska oprema | 4361 (3507) | radmannsdorf |
| » | Kaj je kodek? (strani: 1 2 3 )Oddelek: Pomoč in nasveti | 14310 (12165) | Jst |
