Forum » Slo-Tech » Problem pri prijavi na Slo-Tech
smoke ::
Pozdravljeni!
Imam težavo z prijavo na forum in sicer mi Chrome da tale error:
Poskusil sem pravtako z Firefoxom in dobil error:
Probal sem z brisanjem piškotkov in zgleda ni nobenega efekta. Sistem je na novo nameščen Arch Linux z vsemi updejti. Browserja sta: Chrome (verzija 19.0.1061.1) in Firefox (verzija 10.0.2).
Kakšna ideja?
Lep pozdrav
Error 2 (net::ERR_FAILED): Unknown error.
An error occurred during a connection to slo-tech.com. Unable to generate public/private key pair. (Error code: sec_error_keygen_fail)
Kakšna ideja?
Lep pozdrav
- premaknil iz Pomoč in nasveti: OmegaBlue ()
matej_jack ::
Isti problem imam jaz na Fedori, firefox 10.0.1. Sem mislil, da sem edini
Vse ostale https strani delujejo brez težav, po drugi strani pa tudi slotech odpre v rekonq ali operi.
smoke ::
matej_jack, pri meni je enako, vse ostale https strani delajo, slo-tech pa ne. Dela pa recimo v Konquerorju.
technolog ::
Aja to vi o HTTPS? Potem pa tudi meni ne dela.
Firefox:
Chrome:
Opera dela.
Firefox:
Secure Connection Failed
The page you are trying to view can not be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem. Alternatively, use the command found in the help menu to report this broken site.Chrome:
This webpage is not available The webpage at https://slo-tech.com/ might be temporarily down or it may have moved permanently to a new web address. Error 2 (net::ERR_FAILED): Unknown error.
Opera dela.
| » | Ne odpre dveh strani v Firefoxu - Secure Connection FailedOddelek: Pomoč in nasveti | 1170 (1097) | nsa_ag3nt |
| » | [c#] in sql bazaOddelek: Programiranje | 1741 (1240) | japol |
| » | HP Pavilion dv7 reboot problemOddelek: Pomoč in nasveti | 2637 (2570) | Yacked2 |
| » | Preverjanje, če je spletna stran enakaOddelek: Programiranje | 1720 (1379) | Hayabusa |
| » | Firefox 3 in klik nlbOddelek: Programska oprema | 20878 (16697) | solatko |
