Volitve 2011
Volitve 2011
17 / 32
Karaya 52 ::
Thor; S cim le? Ze Marx, pa verjetno kdo pred njim jih ni maral, videl v njih vzroke vecine problemov. V Jugi so prav tako bili prepovedan element, po osamosvojitvi pa so nekateri zaceli razmisljati s svojo glavo in ustavljali mala podjetja, ki so povpreckotom zaradi slovenske nevoscljivosti sla na jetra. Zdaj podjetja propadajo in kot da to ni dovolj, povprecen Janez koncno najde razlog za PREPOVED PODJETNISTVA, kot da je propad podjetja kaznivo dejanje. Tako, zakon ni nic drugega kot prepoved. V Silicijevi dolini gre povprecen podjetnik skozi tri stecaje preden mu koncno uspe, slovenskemu pa mora v prvo?
Glave bo potrebno potegniti iz socialisticnih riti!
T-h-o-r ::
s čim le? z obravnavanjem zaposlenih kot številk, s krajami, podkupninami in drugimi nelegalnimi posli
  • spremenilo: T-h-o-r ()
lexios ::
Karaya 52 je izjavil:
Ta mi je sploh pri srcu, pahorizem 1A:
Nadaljevanje je šele zanimivo, posebno z današnjega stališča, ko se celotna kriva pripisuje desnici - ravno iz istega razloga bo naslednja slovenska vlada padla, pa kdorkoli to že bo; preveč je vseskup zjeb...
There is not much choice. There is not, because we have fucked it up. Not a little but a lot. No European country has done something as boneheaded as we have. It can be explained. We have obviously lied throughout the past one and a half-two years. It was perfectly clear that what we were saying was not true. We are beyond the country's possibilities to such an extent that we could not conceive earlier that a joint government of the Hungarian Socialist Party and the liberals would ever do. And in the meantime, by the way, we did not do anything for four years. Nothing. You cannot mention any significant government measures that we can be proud of, apart from the fact that in the end we managed to get governance out of the shit. Nothing. If we have to give an account to the country of what we have done in four years, what are we going to say? Naturally, it is [i.e. the government's work] not constructed nicely, calmly or scrupulously. No. No. It is being prepared at a mad break-neck speed because we could not do it for a while in case it came to light, and now we have to do it so damned desperately that we are almost at the breaking point. And then we slowly end up falling over.
Glej, delo ministra ni to, da preverja, kakšne zakone predlaga opozicija in popravlja za njimi. Si pa lahko kar predstavljam, kakšen halo bi bil, če bi Zalar jasno in glasno povedal, da je predlog SLSa neumen. Bi nas razni telebani takoj podučili, da gre za vračanje v temne čase komunizma.
Novela je bila poslana na ministrstva in v vlado za usklajevanje, sicer pa resnega političnega interesa ni, zakon je "sporen" (bi blo pa zanimivo pogledat koliko spornih zakonov in odločitev je Zalar et al. že sprejel), kar bi imho lahko razčistili še pred sprejetjem...
http://www.finance.si/331592/%C5%BDerja...
Osebno zakona nisem bral niti nisem pravnik, tko da ali je zakon "kaotičen", "sporen" ali ne ne vem, kot "uporabniku" pa mi je najmanj debilno, da je slovenska zakonodaja še najbolj podobna švicarskemu siru; za piko na i pa sprejemamo še zakone, ki jih ni mogoče izvajat! Alo, nekje je treba potegnit črto in prevzet odgovornost? Včasih so avtorje in kolaborante takšnih zadev streljal...
Kot je na posvetu združenja nadzornikov povedal vodja interesne skupine delodajalcev v DS Borut Meh bodo ustavnemu sodišču predlagali, naj odloči, da sta določbi 10.a in 10.b člena v nasprotju z ustavo.
Niso sposobni tega ugotoviti sami?;((
  • spremenil: lexios ()
Truga ::
Pšenični je izjavil:
Če ti komej čakaš da kej podražijo je to tvoj problem. Če ti misliš, da bojo s tem kej porihtal, je to tvoj problem.
Zadevi se rece inflacija, 0.8e je blo ze odkar smo dobil evro. Vse ostale cene so sle vmes gor. Nikol mi ni blo jasno zakaj LPP ni sel.
Kar pa se tice rihtanja, brez dnarja ga sigurno ni.
Nesta ::
GregiB je izjavil:
Hmmm, kaže na to, da je precej verjeten scenarij, da trojček SDS+SLS+NSi ne bo dovolj?! Kaj potem? Ugrizniti jezik in iti do Viranta ali pač spet večne destruktorje vlad DeSUS?! Ker povezave z SD se mi zdijo bolj ZF (Zajenzfikšn)
Virant je blizje SLS+N.SI nevem za SDS. Desus bo v vsakem primeru v vladi ce pride notri. Zoki itak h nobenemu noce. SD bo pa sam ostal...
  • spremenil: Nesta ()
lexios ::
Kolikor vem to ni problem, pošten podjetnik tu pade pod "collateral damage", jebiga glup zakon al glupa mentaliteta v državi? Imo je zadeva ravno toliko glupa in "sporna" kot obrnjeno dokazno breme, pa s tem zadnjim večina tule nima problema...
floyd1 ::
Zakaj pa je obrnjeno dokazno breme slabo? Samo razmišljam, pa ne najdem nobenega pametnega odgovora...
lexios ::
Zakaj bi pa jst dokazoval, da sem premoženje pridobil na pošten način? Kolikor vem je vsak nedolžen, dokler se mu ne dokaže krivda, zakaj bi torej moral karkoli dokazovat? Dokaži, da ga nisem...
Problem so kvečjemu obstoječe "luknje v švicarskem siru", ne potrebujemo novih!
floyd1 ::
Ajde, če bi zakone + sodstvo kdo uspel porihtat, tega res ne bi rabili, to mi je jasno. Ampak ker naše sodstvo deluje kot pač deluje, se mi vseeno zdi manj škode na tak način. IMO za legalno pridobljeno premoženje obstaja več kot dovolj dokazov in ne bi smelo biti pretežko tega dobiti. Seveda pa je malo tečno, to pa se strinjam.
lexios ::
Pazi, enako lahko trdiš za SLS-ovo novelo... ;)
GregiB ::
Nesta je izjavil:
Virant je blizje SLS+N.SI nevem za SDS....
Virant verjetno ne bo dobil mandata za sestavo vlade, torej... Čeravno se mi zdi njegovo sodelovanje z NSi manj verjetno...
Jaz sem bolj spraševal v smislu, kaj se zgodi, če bo trojček SDS + SLS + NSi, ki se nekako "ponuja", zbral na volitvah < 46 stolčkov? Pa četudi zbere 46, 47 stolčkov... je to močna koalicija?
Nesta je izjavil:
Desus bo v vsakem primeru v vladi ce pride notri...
Zakvaj??? (vir: GojkoAjkula)
@floyd1: Dokazovanje nekrivde je namenjeno javnosti, ki obsoja na osnovi indicev, takšnih in drugačnih. Na sodišču, kolikor je meni znano, velja dokazovanje krivde...
Nesta ::
GregiB je izjavil:
Nesta je izjavil:
Nesta je izjavil:
Hehe Desus je se vedno bil v vladi pa naj bo to desna ali leva vlada :) Kahl Ehjavcje pa itak kmecki fant z Naklega, ceprav deluje bolj liberalno a so mu vse stranke blizu ker se rad spogleduje tako z levimi kot desnimi.
Manj liberalizma vec postenja tega manjka danasnjim strankam.
S tem, da niti za SLS ne moreš 100% reči, da lahko njih kar avtomatično prištejemo h kakšni "desni" koaliciji; pa tudi za Viranta ne, glede na to, da po anketah sodeč največ volivcev pobira SD-ju ... kar pomeni, da imaš na "desnem" polu zgolj SDS in NSi; na "levem" pa vse možne variacije tudi LZJ+SD+LV+DeSUS+SLS.
djordjevic ::
Nesta je izjavil:
Manj liberalizma manjka danasnjim strankam.
Come again? Dark ages, here we come? ;((
lambda ::
Danes sem dobil prospekt od desusa ... kjer notri piše, da so za njih volilne obljube zaveze, v nasprotju z drugimi strankami. :D 1000 eur pokojnine je trobil prejšnjič, če se pravilno spomnim ...
Nesta ::
djordjevic je izjavil:
Nesta je izjavil:
Kaksno citiranje je pa to??
ah ja, no uglavnem upam da bomo pocasi liberalizem in delitev na leve in desne pometli cez prag. Nevem zakaj mora biti fora da moras biti proti nekomu oziroma neki skupini da si lahko car?? Ce si pa za posteno, delovno in pravicno si pa najbolj opluvan, potem pa vsi volijo barabe in se potem sprasujejo zakaj imamo barabe povsod? Ja ani cudno ko pa vsak hoce biti luftar, strajkat, se fino imet, imeti vse z lufta podarjeno, cim manj delati nic potrpeti.... KRUHA IN IGER... Ne vem ali smo tudi na slo-techu tako retardirani da verjamemo samo v zabavo in kratkorocnost. Ce hocemo nekaj narest ne moremo ziveti samo od kruha in iger.. mislim da to vecini na slo-techu je jasno ali pac ne??
Gregor P je izjavil:
TESKAn je izjavil:
Če je predlog resnično neumen in on ne stori nič zoper njega, pa je tudi nedopustno! On ne dela zase, ampak za nas vse in mora občasno sprejemati tudi kritike drugače-mislečih, sicer (v nasprotnem primeru) smo že oz. še vedno v "temnih časih" komunizma.
Zanimivo, kako se nobenemu ne zdi nič narobe, če opozicijska stranka skozi parlament sfura slab zakon, vsi pa skačejo v luft, da zakaj nek minister ni nič naredil glede tega.
Aja, pa pozabil sem dodat še, da če bi Zalar zminiral zakon, bi še:
- rekli, da minira poskus boja proti tajkunom
- rekli, da je iz ozadja prek Senice posredoval Zidar, Šrot, Hilda, ...
- seveda pa ne sme manjkati obtožba murgeljskega palčka in komunajzarskih sil iz ozadja
Nehajte se sprenevedat in si priznajte, da če bi Zalar kaj pisknil, da je predlagana "rešitev" slaba, bi ga celotna opozicija takoj družno napadla z zgoraj naštetimi "argumenti".
Noraguta:
Med temeljne naloge Službe za zakonodajo sodi obravnava predlogov zakonov in drugih aktov, ki jih vlada predlaga državnemu zboru oziroma ki jih državni zbor predloži v mnenje vladi, predlogov pravnih aktov vlade in osnutkov pravnih aktov ministrov, in sicer z vidika skladnosti z ustavo in pravnim sistemom ter s pravom Evropske unije in z vidika pravil pravne tehnike.
To je opis dela te službe, ki si jo linkal. Kje ti vidiš "preverja ustavnost zakonov, ki jih v parlament spravi opozicija"?
lexios:
To še zmeraj ni izgovor za to, da je SLS v obravnavo poslala skrpucalo od zakona. Mislim, tako lahko vsak dela zakone, nekaj nakracaš, spraviš skozi, ko se ugotovi, da je govno, pa kriviš druge, "da te niso opozorili".
Vprašajte se, si res želite stranko, ki skupaj spravi (kot kaže) protiustaven zakon, v vladi?
Glupa mentaliteta, ko folk nagrajuje populistične poteze, kar ta zakon je. Vsem se zdi fajn, da "tajkun ne bo več mogel podjetja ustanovit", da pa noter pade tudi Janez, ki je v nadzornem svetu podjetja x nasprotoval odločitvi, ki je podjetje potopila, pa nobenega ne briga.
djordjevic ::
Nesta je izjavil:
Nesta je izjavil:
Pošteno sem namerno izpustil, ker sem se dejansko hotel osredotočiti na izjavo, da je problem preveč liberalnosti. Mislim, WTF?
T-h-o-r ::
itak
že pederi se lahko poročajo
če bo šlo tako naprej, bodo še ženske dobile volilno pravico ;((
noraguta ::
@TESKAn
tole je to.
TESKAn je izjavil:
Poslanec neke stranke je lahko tudi navaden človek brez ali samo z OŠ in od njega lahko pričakuješ, da morda ni sposoben sam spisati dobrega zakona, lahko pa ima dobro idejo, ali pa samo misli, da ima dobro idejo ipd. zato pa imamo na drugi strani ministre, ki naj bi bili TOP strokovnjaki, temu primerno tudi več plačani, ki naj bi tem "ubogim" poslancem pomagali, ali pa mu vsaj povedali, zakaj nek predlog ni dober, vsekakor pa vse skupaj dobro proučili in tudi kaj zavrnili oz. vrnili nazaj v obravnavo (če mu to zakon seveda dopušča), skratka delovali v korist državljanov in države ... meni se to zdi normalno:|
T-h-o-r ::
lexios ::
Same shit, kot če bi ga koalicijska stranka, kar se mene tiče...
Sj ga je miniral*, nekak na pol..., v končni fazi so celo dopustil, da je "kaotičen" zakon prišel skoz vse faze...**
*in sj so rekli; US mora celo direktorski ceh predlagt, naj odloči da je....
**ergo ga minirajo še sedaj, zraven pa še državljane
lexios ::
0. Se hecaš, ne?
1. Kdo je vlada? Koalicija? Parlament?
2. Koji kurac opozicija sploh počne v parlamentu, če ne sme tega, onega, tretjega, ne da bi jo kasneje fašala pod gobec...
3. Kje piše, da koalicija ne sme v obravnavo predlagati zakona, ki ga je v parlament spravila opozicija?
4. Kaj se gremo? Prelaganje odgovornosti? Sj vas je bil poln gobec o državotvornosti, s Kučanom na čelu...;((
Konec koncev pa je novela zakona šla skozi državni zbor, tko da ne vem kje je problem okoli citirane "definicije"?
globalna80 ::
Prava levica v današnjem sistemu ne obstaja in ne more obstajat.
Great spirits have always found violent opposition from mediocre minds.
Albert Einstein
Karaya 52 ::
T-h-o-r je izjavil:
Zanimivo da djordjevic ne odreagira na taksna posplosevanja. Pa bom kr js advokat podjetnikov in trdim nasprotno, da lahko tudi ti ustanovis podjetje in postavis zgled. Kraje, podkupnine in nelegalni posli so ena stvar, ki jih zakonodaja ze obravnava. Zakaj pa propad podjetij enacis s tem ... pa ves samo ti. Precej uradnisko razmisljanje, da gre podjetjem ok dokler je vodstvo posteno. Vraga jim gre, kot prvo morajo biti konkurencni. Proizvesti morajo cim vec, cim bolj kvalitetno in poceni. Potem pa morajo vse skupaj se prodati.
Haha, Finance:
Jaka Elikan in Peter Frankl sta pravkar Zoranu Jankoviću nakazala 30 evrov. Janković je namreč včeraj predlagal: »Če mi kaj nakažete na račun, bom imel boljše stanje.« Po podatkih Dursa ima namreč 300 tisoč evrov minusa na računu in njegova županska plača zadošča le za kritje obresti od negativnega stanja.
»Sledila sva pozivu kandidata za predsednika vlade Zorana Jankovića, da mu izboljšava stanje na njegovem tekočem računu. Zakaj? Še noben kandidat za premierja javnosti ni tako neposredno prosil za pomoč. Hkrati je negativno stanje v višini 300 tisoč evrov zavidanja vreden dosežek. Tako za Jankovića kot tudi za banko. Če bi nas bilo še več takšnih, bi bilo Jankovićevo stanje na računu še boljše,« pojasnjujeta Elikan in Frankl, novinar in urednik Financ.
lexios ::
Se strinjam! J*biga, vedno iščemo približke...
djordjevic ::
@karaya 52: Imel drugo delo, si pa v bistvu povedal, kar bi tudi sam. Vsaj tu se strinjava.
T-h-o-r ::
in večini slovenskih podjetnikov prav 0 od naštetega ne gre prav dobro od rok
Ramon dekers ::
http://www.zurnal24.si/kucan-pri-lds-re...
ne razumeme a ni podprl zokitorja?
http://www.zurnal24.si/virant-padel-na-...
še malo pa Virant sploh ne bo notri...
lexios ::
in tu se motiš
Ramon dekers ::
T-h-o-r je izjavil:
zato je kriv Janez Janša. On prav on. Vse je načrtoval že leta 04 potem pa gural to politiko do 08 in tako smo tam kjer smo v riti.
djordjevic ::
T-h-o-r je izjavil:
Kot rečeno, odpri firmo. Gotovo jim boš svetal zgled. >:D
T-h-o-r ::
saj jo bom
but first, dokončanje faksa
djordjevic ::
Jezus, če bi jaz čakal na to, bi bil še zdaj pri starših. :))
lexios ::
Je, je, sedaj pa kot zmešana kura teka sm pa tja, ko Jankotu vse slabše kaže. Predzadnji dan bo podpru še Zares, pol mu pa ostane sam še SD!>:D
T-h-o-r ::
nekako v mojem fohu ne moreš odpret firme, če nimaš faksa
doma pa tudi nisem več :)
Ramon dekers ::
T-h-o-r dokončanje faksa? Kaj pa delaš? Javna uprava?
Ko boš faks dokončal bo začetni kapital kar sam od sebe prilezel do tebe? Mogoče boš s preprodajo orožja prej prišel do denarja.
T-h-o-r ::
analitska politologija >:D
ne, sej ne
Ramon dekers ::
lexios je izjavil:
T-h-o-r ::
samo škoda, da ni pahor bolj drnovšku podoben
če bi bil, bi ob golobičevih natolcevanjih le-tega brcnil v rit, odstopil, predsednik pa bi že takrat razpisal predčasne volitve, kjer bi sd dobil še več glasov, kot 08
T-h-o-r je izjavil:
ne, sej ne
Čakaj, misliš se iti podjetništvo, ne upaš pa niti povedati, na katerem področju boš deloval?
T-h-o-r ::
prevajalec&tolmač
ne bom ustvarjal novih vrednosti :D
ripmork ::
huh, tole je mal čudno. Ker na RTV volilnem termometru je Virant precej višje (zadnja dva dneva na 18 odstotkih).
Skokovit porast je pa (kinda makes sense) nastal ravno po tem, ko so se začela razkrivati mutna posla okoli Electe in KLM-a...
Katere analize so bile na prejšnjih volitvah bolj točne? RTV, Ninamedia?
djordjevic ::
T-h-o-r je izjavil:
prevajalec&tolmač
Pa si ti prepričan, da moraš zato imeti dokončan faks? Last time I checked smo APD (absolventi pred diplomo) komot odpirali firme na to vižo. ;)
p.s.: Diplome pa še ni, ker je dela enostavno too much to handle. ;)
T-h-o-r ::
no vidiš
zato pa 1 step at a time, ne pa da se grem biznismena, pol pa diplomiral ne bom nikdar :D
djordjevic ::
A, jebiga. Eni smo že na faksu 'ustvarili link z gospodarstvom'. Work overload pride sam od sebe, ko pare zadišijo, pa te 'pisanje neke trapaste diplome' hitro ne vidi več. Na neki način bi te celo spodbudil, da jo napišeš. Lahko se zgodi, da je jaz for obvious reasons ne bom.
Karaya 52 ::
Neverjetno, nekdo so obregne ob Zizka, kako vlece 4000€ na mesec na FF, odpredava pa niti 5 minut, pa ze dobi kamen v hrbet: Liberalna akademija: Finance so primitivne.
globalna80 ::
 Kateri politik?
Kateri politik?
A mi lahko kdo našteje kakšnega od kandidatov za volitve, ki je:
- brez afer, prevelikega ega, pošten in brez botrov oziroma omrežij iz ozadja?
Poznate kakšnega izmed sedanjih kandidatov za volitve 2011?
Albert Einstein
PaX_MaN ::
Tine Strela
17 / 32
Primerjava dveh koalicijskih pogodb (strani: 1 2 )
9836235 (27151) vidz81
