Forum » Kaj kupiti » Monitor za CAD, GIS
Monitor za CAD, GIS
Mercier ::
Na brzino se moram odločit med tema dvema monitorjema. Samsung je 12k SIT dražji od iiyame. Ampak se splača, ne? Dajte mi potrdit (al pa ne, no), tisti, ki se bolje spoznate na monitorje.
Evo nekaj specifikacij. To, da je iiyama trinitronska mi ni pomembno.
SAMSUNG 22” 1200NF
- 0.25dp,121kHz,1,800x1,400
- CDT Tube : Naturalflat
- Size : 22(inch)
- Viewable Image Size : 508mm(D),406.4mm(H),304.8mm(V)
- AG Pitch : 0.24mm(Horizontal)
- Surface Treatment : Multi-layer Film with ARAS
- Deflection : 90¡Æ
- Focusing Method : lectrostatic & Dynamic
- Bandwidth Maximum : 340 MHz
- Scanning Frequency Horizontal : 30-121kHz
- (Auto Scanning) Vertical : 50-185Hz
- Display Area Normal : 395 x296mm
- Maximum : 406.4 x304.8mm
- Microprocessor Factory Saving Mode : 8 modes
- User Saving Mode : 10 modes
- User Control Digital : Brightness, Contrast, Position, Size Zoom In/Out, Auto Adjustment,
IIYAMA Vision Master PRO 513, 22"
CRT
22" Diamondtron™ NF (20" viewable),
0.24mm ag pitch, anti-Reflect, anti-Static
coating, 90ş deflection, short persistence
phosphor
SYNC
Horizontal: 30-110kHz
Vertical: 50-180Hz
BANDWIDTH
280MHz Dot Clock
RESOLUTION
1800 x 1440 @ 75Hz
1600 x 1200 @ 85Hz
COMPATIBILITY
All current PC and MAC graphic standards.
Windows 95/98/2000/ME/XP
Plug-and-Play (DDC2B)
DISPLAY AREA (mm)
406 x 304
USER DISPLAY
On-screen display menus
USER CONTROLS
Contrast, brightness, colour temperature, sRGB,
zoom, horizontal size & position, vertical size &
position, pin-cushion, trapezoid, parallelogram,
pin-balance, tilt, horizontal & vertical convergence,
horizontal moiré, degauss, beam landing
correction, raster rotation, OPQ mode, OSD
position, OSD off timer, language selection,
lockout, save recall, help, information
SIGNAL STORAGE
7 factory pre-sets, 10 user memory locations
INPUT CONNECTOR
2 x 15 pin VGA
POWER SUPPLY
World wide AC198-240V, 50/60Hz
POWER USAGE
140W in normal use, 5W in suspend mode
POWER SAVING
VESA DMPS, EPA Energy Star and Nutek
ERGONOMICS
Tilt & turn stand
LOW RADIATION & APPROVALS
CE, TÜV-GS, TÜV-GM (Approved Medical
Devices), MPRIII, ISO 9241-3/ISO 9241-7/ISO
9241-8, PTB, FCC-B, UL/C-UL, DHHS,
Department of Health (Canada)
ACCESSORIES
User manual, power cable, 15 pin D-Sub cable
PICTURE PERFORMANCE
Linearity ±7%
Trapezoid 1.5mm
Barrel 1.5mm
Pin-cushion 2.0mm
Parallelogram 2.0mm
Misconvergence 0.3/0.5mm
Raster Regulation <0.2mm
SAMSUNG 22” 1200NF
- Size : 22(inch)
- Deflection : 90¡Æ
CRT
phosphor
SYNC
Vertical: 50-180Hz
BANDWIDTH
280MHz Dot Clock
RESOLUTION
1800 x 1440 @ 75Hz
1600 x 1200 @ 85Hz
COMPATIBILITY
DISPLAY AREA (mm)
406 x 304
USER DISPLAY
USER CONTROLS
SIGNAL STORAGE
INPUT CONNECTOR
2 x 15 pin VGA
POWER SUPPLY
POWER USAGE
POWER SAVING
ERGONOMICS
Tilt & turn stand
ACCESSORIES
PICTURE PERFORMANCE
Linearity ±7%
Trapezoid 1.5mm
Barrel 1.5mm
Pin-cushion 2.0mm
Parallelogram 2.0mm
Jux ::
Kje si pa vidu da je ijama tolk cenej? K jst tud studiram da bi uzel namest 1100p 1200NF samsunga, sam ce je ijama cenejsa bi rajs to uzel (pa baje je tud bolsa od samsunga).
web&blog&etc: http://lukabirsa.com
Mercier ::
Eni, ki nam dobavljajo robo nimajo monitorja, ki bi sicer spadal zarven pa lahko izbiram med štirimi drugimi (zahvaljen bodi Alah). Ta dva sta, predvsem zaradi cene, prišla v finale.
iiyama je nekje 166.000 SIT + DDV, samsung pa okoli 178.000 SIT + DDV
razlika cca. 12 kil, ali 14 z davkom
Če ti to kaj pomeni, mi mejlaj, pa ti povem firmo. Na tabli pa raje nebi (pre)konkretno o dobaviteljih.
Uporabljal bo en tip za CAD, GIS, TIS...in ostale TLA, torej je pri odločitvi nepomembno, da je iiyamin diamondtron, ker barve ne igrajo nobene vloge. Če to odštejem, pa samsung zmore 1800 x 1400 pri 121 kHz, iiyama pa 1800 x 1440 pri 75Hz. Zakaj se ti zdi boljša?
Pojdi sem :Mittsubishi 22"
Pa si izberi nekaj 22" stane pa tam 200.000 sit . Dolgoročno je to najboljša izbira.
| » | koliko bi dobil za Monitor LG Flatron 915FT Plus?Oddelek: Kaj kupiti | 1835 (1769) | Utk |
| » | 1 nakup lcd monitorjaOddelek: Kaj kupiti | 2161 (1999) | raab himself |
| » | LG 1980U al pa neovo 19EOddelek: Kaj kupiti | 1971 (1759) | Silencer |
| » | MonitorOddelek: Kaj kupiti | 1955 (1770) | jerry2000 |
| » | Kateri monitor?Oddelek: Kaj kupiti | 1957 (1808) | boštjan |
