Forum » Kaj kupiti » Ali je ta switch dober?
Tito ::
LevelOne 8 Port SohoCon
Fast Ethernet Switch
FSW-2108TX 8 Port 10/100Mbps NWay Switch
FSW-2108TX
compliant with IEEE 802.3 and IEEE 802.3u
store and forward switching technology
half and full duplex operation
intelligent flow-control protocol
multicast support
broadcast storm protection
1KB MAC address table
512KB buffer memory dynamically allocated
CRC filtering
auto MDI function
no fan - soundless for Soho application
designed with external power supply
Mislim da tega prodajajo v techtradu, ampak nisem preprièan.
| hub level one 8xrj45 10Mbit | 7.690 |
| hub level one 8xrj45+1xBNC 10Mbit | 10.960 |
| switch level a 8XRJ45 10/100 | 15.130 |
| switch level a 16XRJ45 10/100 19" | 37.630 |
| switch sweex 5xRJ45 10/100 | 11.590 |
U joj mal je razvlečen :(, no zanima me če je ta modro označeni model enak kot na sliki?
- spremenil: Tito ()
LevelOne ::
- compliant with 10BaseT and 100BaseTX, 10/100Mbps dual speed at each port (RJ45),
- auto negotiation,
- auto MDIX function at each port (uplin možen na vsakem od portov),
- flow-control for each port,
- data filtering/forwarding at full wire speed at each port,
- wire speed performance,
- zunanji napajalnik,
- 4KB Mac-Address
- 128KB buffer memory,
Lahko ga postavite na mizo leže ali navpično (priložen podstavek) ali obesite na steno.
Cena: 12.446,00 SIT + DDV
lp,
LevelOne
LevelOne ::
montiramo ga lahko na steno ali pod mizo:
kaskadiramo:
pa še ena, ko switch postane pravi estetski dodatek na pisalni mizi ali polici
- spremenil: LevelOne ()
LevelOne ::
Vprašaj za 8-port switch FSW-0807TX ali artikl št. 530128!
lp, LevelOne
| » | optika T2 oprema in kabliOddelek: Pomoč in nasveti | 11435 (10497) | Senitel |
| » | za ceno starega PCja, profi router/ m0n0wall projectOddelek: Omrežja in internet | 2419 (2056) | Tomay |
| » | Večportni switch za LAN partijeOddelek: Kaj kupiti | 1721 (1514) | AlexUS |
| » | Kater Switch?Oddelek: Kaj kupiti | 1618 (1564) | PaJo |
| » | Kateri switch?Oddelek: Kaj kupiti | 1610 (1541) | LuiIII |
