CREATIVE razkril zvočne kartice Sound Blaster RECON3D
BALAST ::
CREATIVE Sound Blaster RECON3D
The Sound Blaster Recon3D PCI Express zvočne kartice sestavljajo 6-kanalni 24-bit 102dB DAC-i, 4-kanalni 24-bit 101dB analog-to-digital (ADC) konverterji, integriran ojačevalec za slušalke, digitalni microfonski vmesnik, S/PDIF vhode in izhode!
THX TruStudio Pro - Featured in Every Sound Blaster Recon3D
• The THX TruStudio Pro Crystalizer™ enhances in-game sound, music and movies by restoring low and high end frequency curves lost to compression
• THX TruStudio Pro Surround™ delivers a 360 degree surround sound gaming experience so gamers can hear sounds clearly from the front, back, above and below
• THX TruStudio Pro Smart Volume™ addresses the problem of abrupt volume level changes in games, music and movies by intelligently applying gain and attenuation to deliver consistent volume levels
• THX TruStudio Pro Dialog Plus™ enhances voices in games and movies for clearer dialog, allowing listener to hear the dialog over the rest of sound track and over ambient noise in the listening environment
• THX TruStudio Pro Bass™ fills in the missing low frequency tones and give the extra impact for a better entertainment experience
CrystalVoice is comprised of:
• Acoustic Echo Cancellation - Eliminates echoes and enables whoever is speaking to listen to the other party clearly. Echoes are a common problem present in voice communication systems that disrupts conversations by making it difficult to hear the other party
• Noise Reduction - Enables who is speaking to be heard clearly over background noise by constantly monitoring the environment and eliminate the unwanted noise that interferes with the conversation
• Smart Volume - Automatically adjusts the loudness of a voice to maintain a consistent volume level. This makes it convenient for the speaker to converse normally, regardless of whether the speaker is close to or far away from the microphone
• FX™ - Enables alteration of voice with a variety of effects, which can be used to enhance the tone of a voice, create interesting accents, or enable someone to sound like a completely different person
Sound Blaster Recon3D Fatal1ty Professional
Playback: 24-bit Digital-to-Analog conversion (up to 48 kHz to stereo output)
Audio Inputs:
One 3.50 mm (1/8-inch) stereo jack for Microphone In
One 3.50 mm (1/8-inch) stereo jack for Aux In
One 3.50 mm (1/8-inch) stereo jack for Analog Line Out or Headphones Playback
VIR
"You may fool all the people some of the time;
you can even fool some of the people all the time;
but you can't fool all of the people all the time."
  • zavaroval slike: kuglvinkl ()
kuglvinkl ::
KOlk dobre zvočnike potrebuješ, da bi si blo fino omislit npr. dedicated zvočno kartico?
Zheegec ::
Neki high-end zvočniki (recimo Z906) potrebujejo integrirano zvočno z optiko :)
Pri mojih Sennheiser 555 pa sem moral nabavit zvočno, ker se je na integrirani pojavljala statika, to pa je treba že za zvočnike za 20€ :)
Janez Janša, 29.04.2014
dukenukem ::
creative naj enkrat naredi spodobne gonilnike, ne pa da štancajo tole kramo
BALAST ::
Že samo zaradi poslušanja na slušalke se splača imet dobro zvočno kartico! Sploh na katerkoli analogen priklop se pozna izboljšava z samostojno zvočno kartico, tudi na moji SB Live! 5.1 je razlika v dinamičnosti in nasploh boljši odzivnosti in manjšem šumu!
Zdaj, če imaš digitalni receiver ali zvočnike, ki premorejo digitalni vhod (npr Logitech Z5500) povezano na digitalni izhod integrirane zvočne kartice razlike ne boš toliko opazil.Ker zvok na digitalnem izhodu izboljšajo le digitalni efekti (echo, reverb...), ki pa jih novejše igre dobro izrabljajo in programsko dobro krmilijo, na integriranih pa je to krmiljenje zelo omejeno.
RejZoR ::
dukenukem je izjavil:
Imam že leta njihov hardware in ni nobenih problemov. Edino kar jim gre zamerit je slaba podpora med prehodi operacijskih sistemov. Npr ko bo zunaj Win8 bo podpora softwara za trenuten hardware drastično padla. Ampak če gledamo trenutne modele pa nimam pripomb. Tud ta Recon3D bo dobil proper Win8 drajverje z vsemi dodatki. Se vsekakor veselim. X-Fi Forte, ki jo imam zdele ima fenomenalen zvok v špilih.
Blazz ::
dukenukem se povsem strinjam. Gonilniki še sedaj za X-FI niso spedenani, in to že tko 5 let niso sestavil gonilnikov, ki bi delovali normalno.... men moja X-FI xtreme gamer fatality zvočna jebe vsaketolk... nema veze kater OS imam, pa tud samo kartico sem že 2x zamenjal ... skratka s tega vidika je crap...
RejZoR ::
Ne vem kaj imate to ene čudne sisteme. Sam imam že četrto Creative kartico pa nikoli ni bilo težav. So bile malenkosti, ki so jih hitro popravili z novimi driverji. Sem pa imel SB Live! 5.1, Audigy 2 Value, X-Fi Xtreme Music in sedaj X-Fi Forte. Vse dela kot je treba. Ravno za Forte sem dobil nov driver update nedolgo nazaj.
RejZoR ::
Mogoče kdo ima kakšen info kdaj naj bi te kartice prišle na trg?
Blazz ::
Rejzor, če zamenjam 3 OSe in vmes tudi 3 compe (vse razen diskov in zvočne) pa vmes mi menjajo zvočno kartico zaradi recalla pa še vedno vsaketolk kr crkne in moram jo disableat/enableat v device managerju, da potem deluje. Pa včasih se je v XPjih sred nabijanja špilov zvok sesul in je sam piskalo do reboota (ne glede na špil), sedaj na win7 64bit včasih zvoka zmanjka ko nič ne počnem (tako da v Winampu niti noče začet vrtet komada ampak samo stoji), pa ga dobim tako nazaj da iz game mode prestavim v entertainment oz vice versa... potem druzga kot kriviti driverje ne morem...
no res pa je, da sem pred 14 dnevi dal neke beta driverje gor in je zaenkrat vse delujoče...
Blazz ::
No lihkar se mi je spet driver sesul (med igranjem BF3, totalno friznu comp) nato pa win 7 ne zaznajo več pravilno zvočne. Device cannot start (code 10), dal v drug comp, dela, dal nazaj, removal driverje, removal iz device managerja zadevo, na novo gor driverje in spet deluje... če se searchne v google ta error, se bo našlo ogromno folka s to isto težavo....jajca skratka...
  • spremenil: Blazz ()
Cold1 ::
Blaž, ko se mi je pred leti pokvarila X-Fi, je bilo to eno izmed najboljših doživetij - konec bedastoč z gonilniki, konec modrih zaslonov in obešanj računalnika... konec težav pravzaprav.
Odstrani Creativovo sranje iz računalnika in si olajšaj življenje.
(Nobena kakovost zvoka ni vredna zgage, ki jo povzročijo Creativove zvočne kartice.)
Enako pri meni, Audigy 2 ZS, sicer odlicna zvocna kartica, ampak kozlanje od gonilnikov. Vecino casa je bila v skatli na omari.
Sem jo pa cez vikend spet dal v comp, instaliral PAX 2.60 driverje in zaenkrat se dela :)
Od takrat ko sem jo nabavil, sem zamenjal ze ene 5 plat in 3 operacijske sisteme, ampak vedno in povsot so bili problemi z gonilniki.
Mimogrede, se kej ve, kdaj bodo RECON3D v prodaji? Mogoce bi jim dal se eno sanso :)
kuglvinkl ::
Kaj pa Asus? Ni kul? Predrag?
Hja, 120€+ za D2X je ze kr mal huda za filme pa kdaj ksn spil. :|
Gledam tm nekje do 70€ ce bi blo kej uporabnega.
RejZoR ::
kuglvinkl je izjavil:
ASUS ima šele govno od driverjev in softwara. Sem imel ASUS Xonar STX, sicer fenomenalna kakovost zvoka kadar je delalo ampak drugače neuporabna zadeva. GX način pa je tud 3/4 časa delal za en drek al pa je metal BSOD-e. Kar za ALchemy ne morem rečt in mi je do sedaj delal probleme samo v igri Rally Championship 2000. Vsepovsod drugje deluje perfektno. Kar je še bolj zanimivo, če pogledaš ASUS podporno stran, kategorije zvočnih kartic sploh ni. Imaš za matične, grafične in ostali šodr, zvočnih pa sploh ni. Kar veliko pove o tem kolk so resni... Tud 3D pozicioniranje zvoka v strelskih igrah je bilo medlo do amena. Sploh nisi vedel od kje res prihaja zvok. Točka kjer Creativove zvočne peljejo scat vse ostalo. Edine, ki so bile vsaj malo blizu so bile pred leti Aureal Vortex based kartice ala Diamond Monster Sound.
Rečte kar hočete, jezst vem, da si bom omislil Recon3D, ko bo na voljo. Trenutne Titanium sem preskočil, ker je šlo samo za malo predelane kartice z obstoječim čipom. Tele pa bojo imele drastično prenovljeno jedro.
Enron x86 ::
Ko smo že pri Aurealu - a je komu uspelo usposobit (emulirat) A3D na zvočni kartici od Creative? Rabil bi za igranje Thiefa 1 in Star Trek: Elite Force. Trenutno je v računalniku SoundBlaster X-Fi, pa se mi ne da menjat s Terratec DMX Xfire 1024, ki je nekje v omari... :)
Core i5-4690K@4.7| ASUS MAXIMUS VII HERO| 16 GB Corsair LP DDR3 1866 MHz|
ASUS 970 STRIX| SB Z OEM| Samsung 840 EVO 250 GB|
Seagate 2 TB| EVGA SuperNOVA G2 750 W| Fractal Define R4
Jo imam doma. Samo skoda, da je firma tako hitro crknila. ;((
Blazz ::
žalostno je, da res ni alternative, ki bi bila vsaj konkurenčna...
profii ::
Na sceni zvočnih kartic je res žalost že par let. Sam sem problem z driverji na svoji Audigy 2ZS rešil z KX driverji. Od takrat naprej nobenih problemov.
http://www.asus.com/Multimedia/#Audio_C...
Tole je pa...kaj?
Ce ne najdes, se ne pomeni, da ni. Samo iskat moras znat.
RejZoR ::
Dr_M je izjavil:
Crknila je zaradi tožb Creativa. Sicer se ne spomnim zakaj točno se je šlo, vem samo da je Aureal sicer v tožbi nakoncu zmagal, ampak je firma bankrotirala zaradi ogromnih sodnih stroškov. Pol pa je Creative pokupil ostanke patentov od njih.
X-Fi je bila prva kartica, ki je imela not tehnologije od Creativa, Sensaure in Aureala ter še ene firme, ki se je ne spomnim zdele.
Blazz ::
Dr M, tudi Asusova roba je več kot očitno crap kar se tiče driverjev...
Mozno, nevem, nisem se imel.
Zgleda,da bo realtek se najboljsa zvocna nekaj casa :>
jRk0 ::
mam modano x-fi fatality (drug opamp sicer samo), ampak je na audioengine a5 precej razlike in ob menjavi zvocne in zamenjanem opampu, mors pa seveda met se audio creation mode, bit-matched playback in v foobar/winamp WASAPI/ASIO/KS output za muziko, da spila tak kot lahko najboljse (ofc bi kaka drazja zadeva bla boljsa)
Gatsu ::
Sam ima x-fi titanium že leto in pol in se ni še nikol nič sesulo, nič pokalo nobenih bsotd nič. Zadeva dela brezhibno na Win7 64bit od dne nakupa in sistema vmes sploh nisem na novo nalagal...
mayne ::
Asus ma čist vredu gonilnike, odkar uporabljam nisem imel še nobenih težav z mojo Xonar DG. Je pa res da ne uporabljam tistega GX načina.
Janac ::
je res da so to samo preimenovane kartice prejšnjih serij?
  • spremenil: Janac ()
Torej, je ze kdo nabavil tole Recon3D zadevo?
Kako se kej obnese?
Je mozno imet 2 enaka stereo signala al se vedno ni mozno?
St235 ::
Najbolj žalostno je da šest let star X-fi pelje scat kompletno serijo Recon. Kar je popolnoma logično ker je vse stlačeno v en čip. Ko pogledaš pa še ceno je dini možen zaključek: meh...
Blazz ::
Lakotnik ima prav. Zadeva je bolj srednja žalost, razlog pa je v tem, da ni namenskih čipov, ampak je vse v enem in zaradi tega kakovost zvoka zelo šepa. X-FI srednji razred že pelje scat celotno Recon serijo...
Torej sam HW je bolj slab.
Sem pa nasel en opis, kjer pa zelo hvalijo SW. Da se je mocno popravil napram X-FI, manj bloata ipd...
AMD je napovedal nove Radeone in TrueAudio (strani: 1 2 )
5537985 (30235) BaToCarx
Zvočna kartica z SPDIF za DD in DTS
82288 (2218) GenZNPC
Creative Soundblaster Z series
Oddelek: Zvok in slika
101769 (1467) Skyman
Creative razpolovil število zaposlenih (strani: 1 2 )
549648 (7848) Han
Test Creative X-Fi
Oddelek: Novice / Zvočne kartice
356258 (4274) Gregor P
