Forum » Pomoč in nasveti » Nalaganje win 7 na hp mini
T-Mac ::
Zivjo
Kako bi nalozil na hp mini ki nima cd roma windows-e imam file *. Iso
Hvala
Hvala
- polepsal: Ziga Dolhar ()
T-Mac ::
zdej imam pa se eno vprasanje imam narejen boot na klucu ampak ko resetiram laptop mi ne zazene iz kluca sem neki nastavljal v setup biosu ampak vrjetno ne prav?
xxurban ::
Greš v biosu na ˝system boot priority˝(al neki tajga :)) in pač nastaviš za prvo napravo USB.
T-Mac ::
tko imam boot options
hp quickweb disable
cd-rom boot disable
floopy boot disable
internet network adapter boot enable
boot order
tukaj not je pa
notebook hard drive
usb diskete on key/usb hard disk
usb cd/dvd rom drive
usb floopy
netwoek adapter
ampak tukaj ne morm nic nastavit
hp quickweb disable
cd-rom boot disable
floopy boot disable
boot order
tukaj not je pa
notebook hard drive
usb floopy
netwoek adapter
T-Mac ::
ko kliknem na njega se nic ne zgodi
imas pa helo exit select item select menu change values select (submenu) save and exit
- spremenil: T-Mac ()
xxurban ::
notebook hard drive
usb floopy
netwoek adapter
A to se ti pokaže ko klikneš ˝boot order˝ ?
usb floopy
netwoek adapter
xxurban ::
xxurban ::
Follow the steps below to configure the boot order on most computers.
Turn on or restart the computer.
While the display is blank, press the f10 key to enter the BIOS settings menu.
NOTE:The BIOS settings menu is accessible by pressing the F2 or the F6 key on some computers.
Select the Advanced tab using the right and left arrow keys.
Use the up and down arrow keys to select Boot Order .
Follow the on-screen instructions to change the boot order.
- spremenil: xxurban ()
miranpozar ::
Vsi hpji imajo možnost izbire zagonskega medija brez, da hodiš v BIOS, pa tam čaraš, pa save/exit, itd.
Ob zagonu pritisni ESC, F9 ali mogoče F12 (poglej, kaj ti napiše ko se prižiga), potem pa izberi iz spiska in potrdiš... enostavno.
Miran Požar, Portorož, http://sites.google.com/site/miranpozar/
T-Mac ::
Vracam se na staro temo ki sem vprasal za program ki zazenes win 7 preko usb, zanima me ali ta isti program lahko isto naredu boot win xp na usb ali je ta program samo za win 7...vprasano zgoraj...hvala
DonPierre ::
Samo za win 7. Za win xp http://www.rmprepusb.com/tutorials/inst.... Ni pa to edina možnost, uporabi google.
| » | Windows 7 problem pri nalaganjuOddelek: Operacijski sistemi | 1841 (1713) | Han |
| » | HP Pavlion g7 - free dos?Oddelek: Pomoč in nasveti | 1141 (934) | ponaredek |
| » | iščem pomoč WINOddelek: Pomoč in nasveti | 1435 (1271) | marc100 |
| » | Notebook kupljen v italijiOddelek: Pomoč in nasveti | 2342 (1843) | Gutjerez |
| » | OS na USBjuOddelek: Operacijski sistemi | 2644 (2315) | Spajky |
