kako se prevede sledeči stavek...
Ramon dekers ::
mi zna kod pomagati pri temle stavku?
Less often mentioned, but equally important,
is the presence of checks and balances
among the various players in correcting cost
and ridership estimates and the institutionalisation
of counter-expertise against the initiators
and beneficiaries of projects when bids are
evaluated and before contracts are signed.
od and ridership estimates and the institutionalisation of counter expertise se mi ustavi je stavek sploh logičen=
Hvala
Mrakw ::
Google prevajalnik :))
Ramon dekers ::
slaba
Mavrik ::
Tule imaš polno fraz in domensko-specifičnih izrazov, tako da brez konteksta ti lahko tole sam v bedarije prevedemo. Daj mal več (po možnosti cel članek/poglavje) da se vidi o čem sploh to govori.
.:joco:. ::
"Is science true?"
You don't get it.
Ramon dekers> Less often mentioned, but equally important,
Ramon dekers> is the presence of checks and balances
Ramon dekers> among the various players in correcting cost
Ramon dekers> and ridership estimates and the institutionalisation
Ramon dekers> of counter-expertise against the initiators
Ramon dekers> and beneficiaries of projects when bids are
Ramon dekers> evaluated and before contracts are signed.
Redkeje omenjena a enako pomembna je prisotnost zavor in ravnovesij med vpletenimi v usklajevanje ocen stroškov in količine potnikov in institucionalizacijo drugega strokovnega mnenja proti pobudnikom in prejemnikom projektov med preverjanjem ponudb in pred podpisom pogodb.
Verjetno je za "counter-expertise" tudi v slovenščini kakšen zavarovalniški termin, ki se pravilno prevaja drugače kot sem ga jaz - na zavarovalništvo se v slovenščini spoznam premalo.
Ramon dekers ::
Analysts also seem to be in agreement that a
number of essential institutional conditions
have to be met before PPPs can be fruitfully
put in place. It is often in developing countries,
which also have the worst record in overrated
benefits and project cost overruns, that
some of these conditions seem to be lacking
(Flyvbjerg et al. 2003). The conditions that
rank highest are the presence of secure private
property legislation; solid anti-collusion and
anti-monopoly law; consistency among various
pieces of existing legislation which complicate
coherent application of PPP; effective
recourse by private players to the law; and the
execution of both financial and wider socioeconomic
cost-benefit appraisal.
As
some players can benefit from artificially low
estimates, while for others it is the opposite,
checks and balances are the only way to mitigate
the presence of systematic bias.
http://newsletter.epfl.ch/mir/index.php...
naslov članka: The effectiveness of public-private partnerships
in China's transport infrastructure
tale stavek pač izraža prisotnost sistema zavor in ravnotežja (sodstvo, parlament...) tako da imajo na podlagi tega akterji ki bidajo v javno zasebnem partnerstvu lažje možnosti...ampak za besedo ridership je samo en prevod to je uporabniki javnih storitev. Če nadaljujem "uporabniki javnih storitev" ocenjujejo no tu se pa zgubim.
jype je izjavil:
uuu najlepša hvala, tole si mi dal pa 30 min...
V Pegatronu še slabše kot v Foxconnu (strani: 1 2 3 )
11035703 (32618) nekikr
Izgled je vse (op. gendale) (strani: 1 2 3 4 5 6 7 8 9 )
419111831 (106300) Ziga Dolhar
Aretiranih 700 protestnikov "Occupy Wall Street"
Oddelek: Problemi človeštva
414648 (3773) Ramon dekers
Ali gre zahod v pi***? (#2 edition) (strani: 1 2 3 )
14918733 (16690) Ramon dekers
maček
436250 (5146) dronyx
