Forum » Zvok in slika » Kaj gre prek HDMI
Kaj gre prek HDMI
dronyx ::
Na AV Reciver Pioneer VSX 821K, na katerega je priključen z HDMI kablom 26" monitor in 5.1 zvočniki, želim priključiti sledeče:
XBOX 360
PC z ATI 4850 in realtek audio
Sprejemnik za digitalno TV (DVB-T)
DVD predvajalnik
Če zvežem na AV reciever prek HDMI kabla XBOX 360, ali se prenaša prek tega tudi 5.1 zvok, ali res samo stereo zvok, kot sem nekje prebral? V tem primeru bi moral potem za 5.1 zvok domnevam zvezati Xbox na AV reciever še z optičnim kablom za zvok.
Računalnik imam trenutno povezan direktno na monitor prek standardnega VGA kabla. Za zvok imam na AV reciever speljan koaksialni kabel iz zvočne kartice. Zraven ATI 4850 sem dobil nek dodatni prehod iz DVI na HDMI, prek katerega naj bi se teoretično prenašala tako slika, kot tudi 5.1 prostorski zvok. Ali je to že kdo preizkusil in res deluje?
To sprašujem zato, ker ne želim kupovati nekih kablov po nepotrebnem, ne bi pa tudi rad imel stereo zvok, če vir da od sebe 5.1.
XBOX 360
DVD predvajalnik
Tilen ::
Na GTX 470 to deluje.
SSH ::
For digital audio, if an HDMI device supports audio, it is required to support the baseline format: stereo (uncompressed) PCM. Other formats are optional, with HDMI allowing up to 8 channels of uncompressed audio at sample sizes of 16-bit, 20-bit and 24-bit, with sample rates of 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz and 192 kHz.[21][45] HDMI also supports any IEC 61937-compliant compressed audio stream, such as Dolby Digital and DTS, and up to 8 channels of one-bit DSD audio (used on Super Audio CDs) at rates up to four times that of Super Audio CD.[45] With version 1.3, HDMI supports lossless compressed audio streams Dolby TrueHD and DTS-HD Master Audio.[45] As with the YCbCr video, device support for audio is optional.
Compatibility with DVI
Audio support
Since the DVI specification does not support audio-transport, an interoperability problem arises when an HDMI-source drives a legacy DVI-display (such as a PC monitor), or conversely, when a DVI-source drives an HDMI-display. While HDMI and DVI compliance rules ensure that a DVI video-connection can be successfully negotiated and established (via a mutually supported display mode), the audio signal must still be transported through means outside of the DVI connection. Typically, an HDMI equipped source will provide additional outputs for audio-only, such as line-level analog and SPDIF, which provide a baseline audio program (such as stereo PCM.) Likewise, when displaying video from an HDMI jack, an HDMI equipped display may support alternate audio-sourcing from a separate pair of analog-audio inputs. Provision for any of these compatibility mechanisms is entirely up to the discretion of the manufacturer, as they are not covered by the HDMI specification. As of 2010, nearly all HDMI equipped sources (set-top and media-extender boxes, Blu-ray/DVD players and PCs) provide separate analog audio outputs, and many HDMI-equipped televisions support alternate-audio input when sourcing video from an HDMI-input.
There are consumer adapters available to place between a DVI source and HDMI target which can insert a separate audio signal into an HDMI TDMS data stream.[94]
vir: HDMI @ Wikipedia
Po domače, vse bi moglo delat, moja praksa kaže, da je res tako.
lp, Aleš.-
MSI NEO4 SLI PLATINUM, A64 3000+@2500mhz, 2048mb geil 2.5-3-3-5 245mhz,
MSI NX7800GT 256DDR3, 300GB maxtor 16MB cache, LC6420 (420W)
dronyx ::
Tule je dolga debata o 5.1 zvoku prek HDMI na XBOX360 in očitno ima precej ljudi s tem težave. Bom sicer poskusil najprej HDMI, drugače priklopim nazaj optiko.
- spremenil: dronyx ()
sennheiser ::
Ponavad je problem, če je kabl 1.3 standard. Z 1.4 bi zadeva morala delati. Sicer pa načeloma ni razloga zakaj nebi delalo. Možnost je, da so nastavitve na ojačevalcu, tako kot na xboxu napačne in se nekaj tepe. Nebi bilo prvič.
dronyx ::
Če jaz prav razumem, je hdmi 1.4 samo še dodan ethernet k 1.3, tako da to na zvok naj ne bi vplivalo, oziroma naj bi imel 1.3 standard že vse, kar je potrebno za prenos 5.1 zvoka.
sennheiser ::
Mislm da ti je bol ARC pomembn. (Audio Return Channel) Pač zvok šiba v obe smeri lahko. Prvo pač probaj z tistim, kar imaš. Če imaš težave, mal preglej nastavitve. Potem pa pač 1.4 hdmi. Če maš šanso si ga sposod. Če pa ne bo šlo je pa pol optika. Pač nažalost ko pride do zvoka vsaj po mojih izkušnjah so tiste poceni vrjante hdmi kablov tako tako, ne delajo kot treba. Pač sam zato dam predlog. Mogoče pa je kaj na tem.
dronyx ::
@sennheiser: Imaš kakšen predlog, kateri hdmi kabel kupit? V cenah se precej razlikujejo, nisem pa čisto prepričan, da gre tu res za korelacijo med ceno in kvaliteto.
St235 ::
hdmi prenaša digitalni signal, tako da praktično ni razlike med kabli. In ni treba nasedat raznim foram o pozlačenih konektrjih in cenah kot jih ima BB. Jaz imam za ps3 HDMI 1.4 kabel ki je stal celih 7$ na ebayu in dela brez težav.
| » | 5.1 zvok v PC igrah?Oddelek: Zvok in slika | 6112 (2528) | KTr1sk |
| » | Priklop hišnega kinaOddelek: Zvok in slika | 6674 (4514) | ninjaxx |
| » | Gigabyte osnovna in integrirana grafična, HDMI, LG tv, ni zvokaOddelek: Zvok in slika | 2375 (2221) | r3dkv1c4 |
| » | Katero zvočno in slušalke?Oddelek: Kaj kupiti | 3003 (2362) | charlotte |
| » | Dolby 5.1Oddelek: Zvok in slika | 3946 (3494) | ciper |
