Gigabyte osnovna in integrirana grafična, HDMI, LG tv, ni zvoka
Klemenn ::
GA-B85M-D3H osnovna plošča
integriran Intel Integrated Graphics Processor, stvar ima hdmi izhod
povežem prek dhmi na LG televizor (televizor 37LM620S-ZE
slika je ok, zvoka pa ni
v navodilih od plate najdem :
10) SPDIF_O(S/PDIFOut Header)
This header supports digital S/PDIF Out and connects a S/PDIF digital audio cable (provided by expansion
cards) for digital audio output from your motherboard to certain expansion cards like graphics cards and
sound cards. For example, some graphics cards may require you to use a S/PDIF digital audio cable for
digital audio output from your motherboard to your graphics card if you wish to connect an HDMI display
to the graphics card and have digital audio output from the HDMI display at the same time. For information
about connecting the S/PDIF digital audio cable, carefully read the manual for your expansion card.
Pin No. Definition
1 SPDIFO
2 GND
in pa
- 1 x HDMI port, supporting a maximum resolution of 4096x2160@24 Hz
* Support for HDMI 1.4a version.
in pa
HDMI Port
The HDMI port is HDCP compliant and supports Dolby True HD and DTS HD
Master Audio formats. It also supports up to 192KHz/24bit 8-channel LPCM audio
output. You can use this port to connect your HDMI-supported monitor. The maximum supported resolution is
4096x2160@24 Hz, but the actual resolutions supported are dependent on the monitor being used.
(Note) The DVI-D port does not support D-Sub connection by adapter.
kje naj še iščem zakaj ni zvoka?
Default device sem že probaval, pa ne dela...
morš prisilit nekak PC, da prenaša zvok preko HDMI. Maš kak adapter vmes ?
Klemenn ::
Sem mislil da je to to, da nastavis default device.
Ne, direkt na tv.
dogo ::
Poskusi desni klik na ikono zvočnika na orodni vrstici -->playback devices, poglej če imaš tam kje opcijo kaj je primarni speaker.
  • spremenil: dogo ()
Klemenn ::
ja, seveda, to sem vse preklikal
r3dkv1c4 ::
poizkusi tako, da zamenjas recimo na tv vhod, se pravi recimo, da imas na hdmi2, pa preklopi na hdmi 3 in na pc-ju zalaufaj en film(obvezno) in potem preklopi nazaj na pravi hdmi vhod.
Sam na tak način pretentam moj prenosnik, ker imam podobne težave.
Sem našel na netu ogromno nasvetov ampak mi žal samo to pomaga.
  • spremenil: r3dkv1c4 ()
Klemenn ::
hm, četudi to pomaga to v tem primeru ni sprejemljiva rešitev...
r3dkv1c4 ::
Klemenn je izjavil:
....sem samo podal eno opcijo, ker pač trenutno druge ni, zdaj pa čakam na tvoje odkritje nove rešitve.
r3dkv1c4 ::
pa se nekaj se mi zdi da je bila resitev.....za prenosnik je 100% ne vem pa kako je s stacionarcam.
Preklopiš na projector only mode in potem ni druge opcije kot, da še zvok skozi iztisne in potem, ko se zadeva korektno poveže pa po želji nastaviš recimo extended mode.
Klemenn ::
zanimivo je tudi tole...
 slika
slika
tudi ko priklopim kabel je "not pugged in"
  • spremenil: Klemenn ()
r3dkv1c4 ::
Klemenn je izjavil:
 slika
slika
točno to isto meni napiše...ko priklopim na prenosnik tv preko hdmi-ja
in to je bil razlog, da sem začel tuhtat kaj za vraga je to...
in na koncu poizkusi še to, da vržeš sliko samo na tv in potem nazaj na "duplicate" ali pa "extended".
DVI(PC)--->HDMI(TV) ni zvoka (strani: 1 2 )
Oddelek: Zvok in slika
6323228 (12340) BorutK-73
.mkv player
192348 (473) jankometek
Theatron Agrippa DTS 7.1
456020 (4335) jRk0
Je ta konfig OK? Hitra pomoč potrebna
82339 (2144) Area_51
A se splača kupit na eBayu ker majo nore cene
81673 (1576) Phoebus
