Forum » Pomoč in nasveti » Problemi z Xp-ji, Flashanje Biosa in matična plošča,....
weaver ::
Lep pozdrav. Imam problem z Xp-ji, ki se glasi:
Computer shuts down(blue screen with this message.
A problem has been detected and windows has been shut down to prevent damage to your computer
DRIVER _IRQL_NOT_LESS_OR_EQUAL
If this is the first time you have seen this stop error screen restart your computer. If this screen appears again follow these steps.
Check to see if any new hardware or software is properly installed. If this is a new installation ask your manufacturer for any windows updates you may need.
If problems continue disable or remove any newly installed hardware or software.
Disable bios memory options such as caching or shadowing. If you need to use safemode to remove or disable componemts ,restart your computer press f8, to select advanced startup options and then select safemode....in tako naprej....
ter.....
PAGE
FAULT IN NONPAGED AREA.
Lepo prosim za vasa mnenja o problemu.....Hvala!!!
Gremo naprej.....
rad bi fleshal bios, pa ne najdem biosa za mojo maticno plosco, ki je Diamond Flower DFI:
Model #: P2XBL Pentium II Revision C
Manufacturer: Diamond Flower Inc. (DFI)
Ce kdo ve, kje bi dobil najnovejsi bios, za mojo maticno plosco bi lepo prosil za naslov strani....Hvala!!
Se moj sistem:
Celeron 433 - navit na 540Mhz
256 MbRam
Diamond Flower Motherboard
Geeforce2 Mx/Mx 400
Lepo prosim, ce mi lahko pomagate, ker mi kista kar naprej kaze blue screene in mi avtomaticno resetira kisto,...
Za pomoc se vam vnaprej zahvaljujem...HVALA!!!!!!!!!!!!!
ter.....
PAGE
Gremo naprej.....
Se moj sistem:
256 MbRam
Geeforce2 Mx/Mx 400
SLOWWWeb.net ::
Hi!
Najprej si normaliziraj procesor in inštaliraj programsko opremo po korakih
. Isto velja za gonilnike, katerim posvečaj izredo veliko pozornost.
__________________________________________________
WEBhosting / WEBdesign / WEBdomain / Security solutions
BREZPLAČNI marketinški nasveti za podjetja in www strani
KontraCepec ::
fak. isti drek pri meni. imam pii400 na abitovi plošči. ista verzija xpjev dela normalno na athlonu1700. dej povej če si zrihtau. hvala.
| » | Kako ugotoviti kaj mi serje? Bluescreeni...Oddelek: Pomoč in nasveti | 3345 (2736) | Cold1 |
| » | Blue screen problem / windows crashOddelek: Pomoč in nasveti | 1187 (1099) | Xserces |
| » | win 7 bsod - okvara matične ?Oddelek: Pomoč in nasveti | 2395 (2224) | vander |
| » | Težava z zagonom računalnika (strojna napaka?)Oddelek: Pomoč in nasveti | 2218 (2011) | jat2406 |
| » | Navijanje 3400+ na K8N Neo platinumOddelek: Navijanje | 1615 (1398) | Black Metalc |
