Forum » Kaj kupiti » Sandy Bridge in 1.65v rami
Pc Doctor ::
Evo kopiram pa si preberite.
Sandy Bridge has only been around for a short time, but sadly, there is an incredible amount of confusion regarding certain aspects of voltage adjustment. The information below, comes directly from Asus, Gigabyte, Corsair and Intel PMO (Platform Memory Operations), and to the best of my knowledge is 100% correct at the time of writing this. Of course, if any new information comes to light, I will update this section.
•Sandy Bridge does not demand only 1.5v modules, it will be perfectly happy with 1.65v modules too. If someone tries to tell you that you must have 1.5v modules, then they are either trying to sell them to you, or they have been reading misinformation, or both! Another point to consider here, is that in your BIOS, if you head to the memory voltage setting, and enter 1.5v, the text will remain white/grey, if you enter 1.65v, it will turn yellow, and it isn't until 1.73v that it turns red, so at the moment, I'd rest assured that 1.65v modules are OK to use, and I have had this confirmed by Asus, Gigabyte and Corsair so far, as soon as I hear from anyone else, I will update this again.
•Sandy Bridge does not require there to be a maximum of 0.5v between the VDIMM value and the VCCIO and VCCSA values when 1.65v voltage modules are used.
•BCLK Overclocking will not murder your CPU or motherboard. There is absolutely no evidence to support the rumours that adjusting the BCLK upwards on a locked or unlocked CPU will kill/damage it. What will happen, is that the system will become unstable, and you will lose control of things like your hard drive or graphics card, resulting in instability, corruption or the inability to start up properly. As with any overclocking induced instability, simply reduce the overclock and you will find that normality resumes - If you have suffered a SATA problem, then you may have to run your Windows repair console to get the boot loader back.
Share
Share
IvoJan ::
zanimivo :) zakaj pa je potem Intel na zacetku sam priporocal 1,5V rame?
mr1two ::
Načeloma je boljše, če vzameš 1.5V, ni pa z 1.65V popolnoma nič narobe - po standardu so zadeve nastavljene tako, da morajo delovati v najmanj zastavljenih mejah. Je pa res blo dosti telovadbe okrog tega.
mat xxl ::
No mene pa zanima sledeče imam Gigabytovo plato UD4 je B3 in memorije Adata Gaming, ki so 1,65 V po podatku proizvajalca naj bi pa delale od 1,45 do 1,9 V. Torej v Biosu mi jih krmili samo z 1,5V po defultu, vse dela na oko OK, ali naj povečam štrom na 1,65 V ali pustim, kot je ? Kje bi dobil detaljnejša navodila kaj z čem nastavljaš v biosu, ker za 90% stvari vem, za kaj gre, čisto za vse pa ne !
mr1two ::
Don't fix what isn't broken!
Jaz sem povečal napetost na ramih samo zato, ker mi matična ni razpoznala prave napetosti in se je zato crashal sistem vsake tolko časa.
| » | Sandy bridge (strani: 1 2 3 4 … 16 17 18 19 )Oddelek: Strojna oprema | 233693 (182711) | fr4nc |
| » | Okvarjen RAM? Prosim za nasvetOddelek: Strojna oprema | 3076 (2565) | Thompic |
| » | kateri ram naj vzamem??Oddelek: Kaj kupiti | 4405 (2564) | svetetko |
| » | Win 7, 4GB Ram, 2 GB usable; pri boot-u zazna 2 GbOddelek: Pomoč in nasveti | 2737 (2443) | Tea Time |
| » | celeron 2 steppingOddelek: Strojna oprema | 1552 (1406) | singular |
