Forum » Pomoč in nasveti » Rezultat testa ramov v Sandri: Warning W231
Sims ::
Sem stestiral rame v Sandri, pa je rezultat 315 nečesa.
Imam 2x 256 (133MHz) to so men se zdi SDRAM?...
Skratka javi mi še to:
Warning W231 - The IOQD (Host Bus In-Order Queue Depth) is set too low, most likely 1, i.e. no queue. This indicates the depth of the host bus pipelining; thus 1 indicates that no pipelining is to be done on the bus. This reduces the performance of the host bus which is crucial to performance. P6 (Pentium Pro, II, III, Celeron) has an IOQD depth of 8 while the P4 has an IOQD of 12. Most chipsets have an IOQD of 4 or more.
Fix: Check that BIOS settings were not reset or set to Fail-Safe defaults. Reset them to Optimised or Normal settings.
SiSoftware Sandra Help File
Nisem mogel ugotoviti kaj, kako nastavit da bo kao vreu...
[dodatek by bastadu: Prosim, piši naslove tem takšne, da se bo z njih vsaj približno dali razbrati vsebino teme. Sedaj bom namesto tebe to storil jaz...
- spremenilo: bastadu ()
bastadu ::
Kot prvo naredi to kar ti je pisalo v helpu, in sicer pojd v BIOS in resetiri nastavitve, ker zgleda da tam nekaj nimaš vredu nastavljeno...
Sims ::
Sem naredil, pa ni nič pomagalo... aja, isti warning mi napiše pri Mainboard Information.. Zgleda, daje nekaj na plati..
| » | Kako pohitriti FireFoxOddelek: Pomoč in nasveti | 5076 (4787) | Bakunin |
| » | sata/ide nepravilno razumevanje pojma!Oddelek: Strojna oprema | 3726 (3399) | Icematxyz |
| » | Navijanje procesorja Celeron Tualatin 1100Oddelek: Navijanje | 1824 (1504) | Spajky |
| » | Gentoo setup problemOddelek: Operacijski sistemi | 2210 (2034) | G2 |
| ⊘ | Aalchemy (strani: 1 2 )Oddelek: Zvok in slika | 7963 (7201) | Senitel |
