drivers audigy player full instalation
DocRob ::
Pozdravljeni! Podrobno sem si prebral litanije kako si ne znamo poiskati gonilnikov vendar moj audigy se vedno ne dela. Kupil sem si kartico, na zalost brez cd-ja ki se sedaj
že en mesec praši:( na polici namesto da bi se grela v computru. Na žalost na natu ne najdem driverjev, največ kar sem si presnel je upgrade. Če ima kdo link mu bom neskončno hvaležen, pripravljen pa sem tudi kupit cd z driverji. Hvala lepa. Docrob@email.si
AngelOfDeath ::
v keri trgovini pa so ti dali kartico brez cdja ?
če še ga vedno rabiš mi povej
McNato ::
Download od Compaqa
Unpack the apps and driver with WinZip, WinRAR or any other unziping tool you have to a new folder
ocen that done you need to del the CTOem.cfg which in the folder called ?:\Audio\Setup\ now your ready.
Uninstall the previous package from the Add/Remove Programs now it take a few reboot doing this from
Add/Remove Programs ocen that done and what ever you do, do not canel hardware wizard let find
nothing then install the new package.
OC GURU bios update
82761 (2628) 4ever
Zvočna ne dela na XP-jih
51537 (1485) mitja01
Logitech MouseWare bug (?)
272602 (2198) Swiwer
Win XP - messenger
Oddelek: Programska oprema
111591 (1443) IgiS
RA2 preko dveh modemov?!
Oddelek: Igre
101795 (1690) bastadu
