Izšel Slobuntu 10.10.2
2
Gandalfar ::
Kako se 'windows' bloat razlikuje od 'linux' application bloata?
Kripto si sedaj prinesel zraven. Ne mesaj zadev prosim.
lukar ::
Mimogrede, vem, da je tole malo offtopic, ampak meni kot windows sistemcu jako olajša inštalacijo sveže mašine www.ninite.com. Naklikaš, kaj hočeš inštalirat, greš na kavo, prideš nazaj, zadeva je končana. Jasno, ni podprto s strani MS in tako naprej, ampak lahko, da bo (morebitnim;) windows bralcem te debate olajšala inštalacijo nove mašine.
poweroff ::
Gandalf - prerekanje okrog tega kje so razmetane datoteke je bullshit, ker end-user sploh ne vidi tega. Klikne na remove, pa je zanj stvar končana.
S stališča zasebnosti tudi ni problema, ker so vse pomembne zadeve izključno v njegovem home direktoriju. Se pravi VE kje so te zadeve. Na enem mestu.
Če ima pa v svojem direktoriju kup .xxxx datotek, pa to ne upočasni delovanja sistema. Bloated register ga.
sudo poweroff
Gandalfar ::
Vir? Wikipedia namrec pravi:
On Windows 9x computers, it is possible that a very large registry could slow down the computer's startup time. However this is far less of an issue with NT-based operating systems (including Windows XP and Vista) due to a different on-disk structure of the registry, improved memory management and indexing.[13] Slowdown due to registry bloat is thus far less of an issue in modern versions of Windows. More importantly, however, the difference in speed due to the use of a registry cleaner is negligible: rarely do they remove more than a few kilobytes from the total size of the registry. In fact, technology journalist Ed Bott has claimed that no one has ever successfully managed to measure any significant performance increase from the use of a registry cleaner.[14] Any potential user of a registry cleaner must thus balance a probably negligible performance increase against the possibility of system instability. A safer and more measurable approach to registry performance is to defragment the registry files using a Microsoft-supported tool such as PageDefrag,[15] or to use the Windows Performance Tools, which are specifically designed to troubleshoot performance-related issues under Windows.[16]
Cold1 ::
"Moje mnenje je pa, da je Windows čisto preveč poceni. Stati bi moral najmanj 5x toliko. Microsoft tudi ne bi smel poslušati neumnih želja namiznih uporabnikov in ukiniti podporo za starejše programe, itd. lalala."
Boš pol Cold tudi rekel, da je to moje osamljeno butasto mnenje razlog odhajanja uporabnikov na druge OS-e?
Matthai, pa saj ti nisi uporabnik Oken, uporabljaš jih kvečjemu s stisnjenimi zobmi, kot takega te drugi tudi prepoznavamo, torej tvoja mnenja (tudi takrat ko resno misliš) ne odražajo miselnosti okenskih uporabnikov.
Po drugi strani pa je By Hackers For Hackers™ izjemno popularen mem, ki se pojavlja vsepovsod. Temu primerno je moje sklepanje, da še kako vpliva na razvijalce, še posebej tiste, ki nasedajo GNU/kultu.
Registry is Ebil™
Stara neumnost, ki izvira iz časa Oken95, ko je bil _celoten register_ vseskozi naložen v pomnilniku, temu primerno je lahko ob pomanjkanju pomnilnika, večanje registra upočasnilo sistem.
OknaNT ne nalagajo registerskih panjev v pomnilnik v celoti, zgolj tiste del(čk)e, ki so trenutno v uporabi, tudi hiper velikanski register oken ne upočasni niti za milisekundo.
Po drugi strani pa uporabniku stare nastavitve pridejo prav, ko ponovno namesti program, mimogrede vse programske nastavitve se nahajajo v HKCU\Software in HKLM\Software so pregledne, samoumevne in če jih nočeš več jih z lahkoto tudi pobrišeš.
Oziroma, what Gandalfar said.
poweroff ::
No, če na hitrost res ne vpliva, pa so v SKUPNEM registru razmetani razni osebni podatki...
Velja tudi za .xxxx datoteke in Linux.
By Hackers For Hackers je traparija, ki sta jo Canonical in Red Hat povozila.
Jaz pa WIndowse redno uporabljam. Za razliko od tebe pa tudi Linux redno uporabljam.
sudo poweroff
Gandalfar ::
@Matthai: a tako kot v skupnem /etc/passwd ? :)
Ali pa se nisi opazil, da danes prav tako vecina Windows aplikacij shranjuje podatke v osebne profile na disku.
Cold1 ::
Niso, najdeš jih v osebnem delu registra, katerega panj je dostopen zgolj uporabniku. HKCU - HKeyCurrentUser je osebni register, v HKLM - HKeyLocalMachine lahko pišejo zgolj programi z administratorskimi pooblastili, uporabniki pa jih brez admin gesla niti ne morejo pognati v admin mode-u.
Matthai, časi Oken95 so dokončno minili z Visto, dandanašnji, programi vedno tečejo v okviru uporabnikovih pooblastil in ne sistemskih, ti kot kaže bolj kot ne uporabljaš (zelo) zastarela Okna.
Neverjetno, You Don't Know What You Are Talking About™, nehaj no; kot da bi bil Linux nek strogo zaupen projekt katerega podrobnosti so dobro skrite.
Kritika Linuxa je vsakomur dobro dostopna na spletu, razočarani uporabniki pa spadajo v vse kategorije; od Linux nubov pa vse do UNIX graybeardov.
Temu primerno, moja (bolj ali manj neobstoječa) avtoriteta za to ni potrebna.
BigWhale ::
Eni k uporabljamo oboje (vcasih celo troje) se ne mormo odlocit kaj je vecje sranje. ;>
zee ::
BigWhale: Žebljica na glavico!
Stvari še dodatno oteži uporaba več različnih distribucij GNU/Linuxa in več verzij Windows.
zee
To je pa zato, ker je premalo linuxdadyjev in preveč ZeroOnetov.>:D
O.
zee ::
Kar je naredil linuxdady, je v vsakem primeru vredno vse pohvale in spodbude, zato ne razumem povsem, čemu je potrebno "bashanje".
zee
Cold1 ::
...čemu je potrebno "bashanje"
Ni potrebno, zgolj nekaterim se zdi nujno potrebno izlivati žolč na domnevne sovražnike, pa naj bodo to programerji ali uporabniki, dovolj je nestrinjanje z zapovedmi GNU/kulta.
Se ne bi mogel bolj strinjati z Okapijem.++
Ales ::
Okapi je izjavil:
O.
Se strinjam. Pa brez zamere, ZeroOne, sam prispodoba si :)
Kaj če bi šli nazaj na prvotno temo in se hirearhije linux datotečnega sistema in primerjave z drugimi OS-i lotili kdaj drugič...?
Si bom pogledal Slobuntu ob priliki, vse pohvale za trud.
Se strinjam, gremo nazaj na temo.
LinuxDady, vse pohvale z moji strani, ravnokar testiram SloUbuntu v VirtualBoxu in je res dobro sestavljen.
Looooooka ::
Kako lepo je ko se o windows registru razpisejo linux userji, ki si se pet minut casa ne vzamejo za branje...
BigWhale ::
Okapi je izjavil:
O.
Ja, blind zealotry was always blind.
LorD_DDooM ::
Naložil Slobuntu 10.10.2 na družinski računalnik in bi rad izrekel vse pohvale za trud in delo razvijalcu/cem. Namestitev je enostavna, zadeva deluje out-of-the-box, brez kakih dodatnih (nujnih) nameščanj. Primerna predvsem za začetnike in nepoznavalce (v mojem primeru družinske člane).
Prisotnih je še par slovničnih napak (npr. dodajanje tiskalnikov - URL naslov), ampak razvoj gre v pravo smer.
linuxdady ::
Me veseli, da vam je všeč!
Glede prevodov pa moram povedati, da je v zadnjem letu prevajanje Ubuntu Linuxa dobilo povsem nov zagon. Tako obseg kot kakovost prevajanja sta na zelo visoki ravni.
Uradne izdaje pa seveda ne vsebujejo sprotnega napredka, zato priporočam, da med vire dodate pakete z najnovejšimi prevodi:
sudo add-apt-repository ppa:ubuntu-langpack/ppa
errhec ::
Pravkar vlečem dol :)
linuxdady pohvalno.
dd
linuxdady ::
Dodal sem še 64 bitno različico:
Torrent za prenos
Pri sestavljanju sem upošteval nasvete, ki sem jih prejel v zadnjih dneh. V prvi vrsti sem dodal vir paketov s posodobljenimi prevodi in potolkel nekaj nadležnih hroščev.
Pripravljam tudi popravljeno 32 bitno različico z enakimi popravki, ki jo bom objavil v enem ali dveh dnevih.
Damiani ::
pohvalno, nisem dol potegnil distrubucije. sem pa namesti isto ozadje.
RedZo ::
linuxdady vse pohvale. Odprta koda omogoča, da tisti z znanjem izrazijo kreativnost, nam ostalim pa občutek večne hvaležnosti :-))
IceBoX ::
Mene pa zanima, kako povečati ikone zgoraj na panelu, kot so tukaj na sliki te novice. Uporabljam pa ubuntu 10.10.
dragana ::
IceBoX je izjavil:
Širino pulta in velikost ikon povečaš ali zmanjšaš tako, da klikneš z desnim klikom miške na pult in v meniju izbereš lastnosti, ter povečaš oz. zmanjšaš število točk velikosti pulta.
damirb03 ::
Tu je še Slobuntu 10.10.2 64 bit .
http://www.linux23.com/torrent/slobuntu...
linuxdady ::
Nekoliko sem popravil tudi 32 bitno različico,
Tole je nov torrent za prenos
techfreak :) ::
Pohvalno, predvsem primerno za začetnike.
Imam samo eno pripombo: nouveau + Flash predvajanje videa = no go
Je kakšna možnost za vključitev binarnega Nvidia gonilnika?
linuxdady ::
Sistem-Skrbništvo-Dodatni gonilnik. Ponudil ti bo namestitev lastniškega Nvidia gonilnika. Po ponovnem zagonu bo delovalo. (no, meni z GeForce 8800gts deluje.)
Lastniških gonilnikov pa pač ni dovoljeno vključevati v distribucije, ki se javno širijo. Žal.
Mavrik ::
Bi morda vključil kako avtomatsko sporočilo pri prvem zagonu, kjer bi samo s klikom "da" namestil te gonilnike?
2
Podčrtane besede
212836 (2065) opeter
Izšel Firefox 14 (strani: 1 2 )
Oddelek: Novice / Brskalniki
8031444 (27735) MrStein
Ekstremadura migrira na Linux Debian (strani: 1 2 )
9938602 (34327) nekikr
Izšel Slobuntu 10.10.2 (strani: 1 2 )
7924358 (21042) Mavrik
Anon-IM - Anonymous Instant Messaging v. 0.0.1
Oddelek: Novice / Zasebnost
154569 (4031) lukaz
