Forum » Pomoč in nasveti » Kako izklopiti page file
keezord ::
Imam 8 gb rama in se mi zdi, da za toliko rama računalnik prepočasi dela. Zato bi prosil če mi poveste kako izklopiti PageFile, uporabljam pa win7 64 bitni home premium. Lp
Vista in Windows 7 sta identična v vseh takih stvareh...(lohk pa windows 7 dodaš v search, res težko LOL)
keezord ::
No js mam w7 v slovenščini in nevem kje najdem te stvari na w7
Open Control Panel -> System and Maintenance -> System.
In the left "Tasks", click on Advanced System Settings.
You should come to "Advanced" tab. In "Performance" section, click on Settings button.
Click on Advanced tab.
In the "Virtual Memory" section, click on Change button.
By default, "Automatically manage paging file size for all drives" setting is selected so that Windows Vista system can manage the paging file without user's interruption. If you want change the paging file size, move the pagefile.sys to another drive, or disable virtual memory paging, uncheck the check box of Automatically manage paging file size for all drives.
Select and highlight the appropriate drive that users want to change the paging file settings under the box of "Drive [Volume Label]".
Ko sem delal to na Xp-ju sm takoj naredil pr w7 pa neznam.
Tako da prosim če mi lahko kdo to po korakih napiše!?
vorantz ::
glihkar sem poklikal po teh navodilih in sem našel
edino kar je možno, da imaš pogled v control panel drugačen
da ne kompliciramo:
zamenjaj korak "Open Control Panel -> System and Maintenance -> System." z
start > desni klik na my computer > properties
s tem prideš do tistega System
od tle pa je vse enako
da ne kompliciramo:
gzibret ::
Vseeno svetujem, da pustiš nek minimapen PF, recimo 128 MB. Določeni programi (in igre) znajo brez PF-ja štekat.
Vse je za neki dobr!
| » | Koliko placa za Visto?Oddelek: Operacijski sistemi | 2231 (1881) | Pesimist |
| » | win 2000 virtual memory to lowOddelek: Operacijski sistemi | 1860 (1686) | civava23 |
| » | Kako razdeliti 250GB disk? (strani: 1 2 )Oddelek: Pomoč in nasveti | 7151 (6264) | bajsibajsi |
| » | Win XP in paging file size ??Oddelek: Pomoč in nasveti | 1551 (1369) | bobby |
| » | evo problemčekOddelek: Pomoč in nasveti | 1192 (1027) | bobby |
