Need 4 Speed HP II na voodoo3?
megadeth ::
Zanima me če dela NFS HP2 na voodoo 3 3000 kartici?8-O
Are you feeling lucky? Google me!
nojus ::
MINIMUM SYSTEM REQUIREMENTS
Windows 98, ME, 2000 or XP operating system
Intel Pentium III (or compatible) CPU running at 450Mhz or higher
16MB DirectX 8.1 compatible video card using a supported chipset (see below)
128MB of RAM
DirectX compatible sound card
1.2GB of HD space
56kbps modem (for internet play)
Network card for broadband or LAN play
samo vprasanje je kako?!?
sovražim Gargamela.
BendeR ::
Po moje to nebi ravno igralno delalo.
megadeth ::
Če dela na RivaTNT2, bi tudi na voodoo3, ne?8-O
BendeR ::
Porblemi z driverami .Razen če uporabljaš win98,te bi mogoče celo delal:D
megadeth ::
Kaj pa na XP?
BendeR ::
Saj sam veš kaki problemi so v kombinaciji voodoo3 +win xp.Lahko pa probaš z demotom.To bi ti le najbolj priporočal.
Predator ::
p3 450@550 pa v3 3000, na 800*600 že problemi ( beri občasni diapozitivi ); mam pa winse 2k
Return To Castle Wolfenstein (strani: 1 2 )
Oddelek: Igre
586842 (5710) LunKi
long live Vodoo 3 (strani: 1 2 )
Oddelek: Zvok in slika
605877 (5151) Senitel
Aalchemy (strani: 1 2 )
637963 (7201) Senitel
Emboss Bump Mapping vs. EMBM
442054 (1727) undefined
VOODO 5 5500 za 40 k sit?
192136 (1871) Ark4nge|
