Forum » Pomoč in nasveti » limited or no connectivity
lunnnatic ::
mam problem na sodelavkinem prenosniku... fujitsu siemens amilo xi 1526... noce se konektat na net ...
Last diagnostic run time: 11/23/10 21:00:34 IP Configuration Diagnostic
Invalid IP address
info AutoNet address detected: 169.254.56.156
action Automated repair: Renew IP address
action Releasing the current IP address...
action Successfully released the current IP address
action Renewing the IP address...
error Error renewing the IP address: The semaphore timeout period has expired.
action Automated repair: Reset network connection
action Disabling the network adapter
action Enabling the network adapter
info Network adapter successfully enabled
action Manual repair: Reboot modem
info Zero (0.0.0.0) IP address detected
info Redirecting user to support call
Wireless Diagnostic
Wireless - Service disabled
Wireless - User SSID
Wireless - First time setup
Wireless - Radio off
Wireless - Out of range
Wireless - Hardware issue
Wireless - Novice user
Wireless - Ad-hoc network
Wireless - Less preferred
Wireless - 802.1x enabled
Wireless - Configuration mismatch
Wireless - Low SNR
WinSock Diagnostic
WinSock status
info All base service provider entries are present in the Winsock catalog.
info The Winsock Service provider chains are valid.
info Provider entry MSAFD Tcpip [TCP/IP] passed the loopback communication test.
info Provider entry MSAFD Tcpip [UDP/IP] passed the loopback communication test.
info Provider entry RSVP UDP Service Provider passed the loopback communication test.
info Provider entry RSVP TCP Service Provider passed the loopback communication test.
info Connectivity is valid for all Winsock service providers.
Network Adapter Diagnostic
Network location detection
info Using home Internet connection
Network adapter identification
info Network connection: Name=Bluetooth Network Connection, Device=Bluetooth Device (Personal Area Network), MediaType=LAN, SubMediaType=BLUETOOTH
info Network connection: Name=Local Area Connection, Device=Realtek RTL8169/8110 Family Gigabit Ethernet NIC, MediaType=LAN, SubMediaType=LAN
info Network connection: Name=Wireless Network Connection, Device=Intel(R) PRO/Wireless 3945ABG Network Connection, MediaType=LAN, SubMediaType=WIRELESS
info Network connection: Name=1394 Connection, Device=1394 Net Adapter, MediaType=LAN, SubMediaType=1394
info Network connection: Name=Nokia N95 8GB USB Modem (OTA), Device=Motorola SM56 Data Fax Modem, MediaType=PHONE, SubMediaType=NONE
info Both Ethernet and Wireless connections available, prompting user for selection
action User input required: Select network connection
info Ethernet connection selected
Network adapter status
info Network connection status: Connected
HTTP, HTTPS, FTP Diagnostic
HTTP, HTTPS, FTP connectivity
warn HTTP: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
warn HTTPS: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
warn FTP (Passive): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
warn HTTP: Error 12007 connecting to www.hotmail.com: The server name or address could not be resolved
warn HTTPS: Error 12007 connecting to www.passport.net: The server name or address could not be resolved
warn FTP (Active): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
error Could not make an HTTP connection.
error Could not make an HTTPS connection.
error Could not make an FTP connection.
Invalid IP address
Wireless Diagnostic
Wireless - Low SNR
WinSock Diagnostic
WinSock status
Duhec ::
Še kaj več povej kaj si že naredil, kateri sistem, adsl modem, kako je vse zvezano, žično, brezžično ... ???!?!?!
Če imaš povezavo preko mrežne, torej UTP kabel priklopljen v router/switch ali direktno v adsl modem, potem preveri fizično to povezavo (mogoče slab kontakt, kabel, nepravilen priklop ...) ker ta IP 169.254.56.156 po mojem nakazuje, da fizično nimaš nekaj dobro povezano in ti mrežna namesto ip javi nek rezerviran interni IP, torej dhcp funkcija v routerju ne doseže tvoje mrežne na prenosniku.
Če pa imaš wireless povezavo pa preveri, če ti sploh gori tista modra ledica, da je wireless vklopljen in seveda, da imaš adsl wireless internet dostop.
Poročaj !
Poročaj !
| » | Težave - internetOddelek: Omrežja in internet | 2204 (1942) | megy |
| » | Povezava zmrzne? Prosim za pomočOddelek: Omrežja in internet | 2020 (1847) | Neven |
| » | preverjanje net povezave z dos batch ukaziOddelek: Programiranje | 4207 (2547) | amigo_no1 |
| » | ne morem pingat hosta, ki mu ruterjev DHCP dodeli IPOddelek: Omrežja in internet | 2100 (2047) | amigo_no1 |
| » | Domena?Oddelek: Programska oprema | 1765 (1624) | kockish |
