ne morem pingat hosta, ki mu ruterjev DHCP dodeli IP
oneye ::
Lep pozdrav,
imam ruter Bintec R232bw, ki je tudi access point. Ko se brezžično povežem nanj z laptopom mi DHCP da IP katerega preko svoje desktop mašine ne morem pingat. Iz laptopa pa lahko pingam vse.
Torej problem imam z pinganjem mašine kateri je ruter preko DHCP dodelil IP. Če nastavim statični IP se laptopa da pingat BP.
amigo_no1 ::
start/run/cmd
ipconfig/all
na obeh pcjih
oneye ::
Najprej bi rad povedu da sm v zgornji temi neki zabluzil...celo ce na laptopu nastavim staticni IP ga iz desktopa, desktopa #2(linux) in ruterja ne morem pingat...iz laptopa (ki je wireless na access point prikljucen) pa lahko vse, desktop in desktop #2 je preko kabla na ruter.
ipconfig laptop:
Windows IP Configuration
Host Name . . . . . . . . . . . . : JR-LAPTOP
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Realtek RTL8139 C+ Fast Ethernet NIC
Physical Address. . . . . . . . . :
Ethernet adapter Bluetooth Network:
Description . . . . . . . . . . . : Bluetooth LAN Access Server Driver
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel® PRO/Wireless 2200BG Network Connection
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.0.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.10
DNS Servers . . . . . . . . . . . : 192.168.0.10
desktop:
Host Name . . . . . . . . . . . . : smoothoperator
Ethernet adapter LAN1:
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
IP Address. . . . . . . . . . . . : 192.168.0.1
help me out :|
amigo_no1 ::
Preveri firewalle
Kakšen poseben razlog zakaj bi rad pingal ?
  • spremenilo: amigo_no1 ()
oneye ::
jeje997 prav si imel. Problem je bil v Windows Firewallu. Torej če imaš odkljukano opcijo "File and Printer Sharing" ne moreš pingati. Zdi se mi popolnoma idiotsko saj so pod to opcijo zaprti/odpri porti UDP 137,138 in TCP 139, 445. Če ima kdo razlago za ta cuden pojav se priporočam...
hvala jeje997 in lp
amigo_no1 ::
  • spremenil: jvolk ()
Težave - internet
Oddelek: Omrežja in internet
302201 (1939) megy
Problem z internetom
473786 (3337) RuskiSnajper
Problem router/mordem
153175 (2862) gorenjc
wireless ne dela splj0h :D
122587 (2275) burka
wireless omrezje HELP
191932 (1746) igz
