Forum » Programska oprema » Uporabniške nastavitve - Ubuntu
echoman ::
Pozdravljeni!
Uspelo mi je namestiti Flash, ki deluje na Ubuntu 10.04 z vključenimi efekti, vendar se je pojavila težava. Namreč, ko želim igrati Osvajalca (upam, da igro poznate), mi pri povezovanju na strežnike javi napako 10, tako da ne pridem do igre. Napaka je vsakič ko želim igrati igro, vedno prisotna.
Zanima me še glede Wine-a, kako bi lahko naložil Photoshop CS3 in Dreamveawer CS3, ker postopek na uradni strani ne deluje.
Hvala! :)
Hvala! :)
Za Photoshop CS3 so res napisali, da so lahko problemi:
http://appdb.winehq.org/objectManager.p...
How To succesfully Install Photoshop CS3 (XP dlls required)
First off: don't expect this to work well. Wine does not yet support Photoshop CS3. Only read these instructions if you feel like fiddling around, not if you expect to get a working Photoshop.
OK, now that you know that Wine does not yet fully support Photoshop CS3, here's how I got it to install and run today with wine-1.1.6:
1. Do 'wget kegel.com/wine/winetricks && sh winetricks gecko gdiplus'
2. Install Photoshop CS3 as normal by running its Setup.exe.
3. Run Photoshop CS3 as normal, e.g.
$ cd .wine/drive_c/Program\ Files/Adobe/Adobe\ Photoshop\ CS3
$ wine Photoshop.exe
That's it! It runs very slowly, though. Hats off to Jacek for fixing the installer!
I have had problems with the app's license manager giving up because the app was running too slowly. When this happens, you have to remove ~/.wine and reinstall.
Preberi še komentarje na tisti strani.
Tukaj pa je še en vodič za ostale Photoshope:
http://wiki.winehq.org/AdobePhotoshop
echoman ::
Sem opustil te zadeve glede drugih programov ;) Sem se odločil, da bom uporabljal le programe za Linux.
Še vedno pa me zanima tole:
Hvala! :)
Hvala! :)
| » | Grafični oblikovalci, kako je to možno?!?! (strani: 1 2 )Oddelek: Pomoč in nasveti | 24517 (21589) | ST-777 |
| » | Grafična kartica, primarno za photoshop CS4Oddelek: Zvok in slika | 1944 (1711) | Senitel |
| » | CS3 serija programovOddelek: Izdelava spletišč | 2854 (505) | VoX |
| » | intel z 6-timi jedri?Oddelek: Strojna oprema | 1620 (1196) | darkolord |
| » | Izdelava ozadja s Adobe Photoshopom CS3Oddelek: Programska oprema | 3046 (2803) | bluefish |
