Forum » Strojna oprema » Radeon HD 6870?
Radeon HD 6870?
galu ::
5970 se porazno prodaja, naparam HD5850.. V performancu je 5970 že mogoče močnejša od GTX580, ampak ko pa človek primerja obe v praksi pa je gtx580 celar win.
Tako to gre.
Machiavelli ::
S5 nova govorica glede 6950:
1408 SPs, 200W TDP
We managed to score more details regarding the upcoming AMD Cayman based cards. By the looks of it, some things have changed since the last slides, which we saw back in November. According to the latest specifications, the HD 6950 ended up clocked at 800MHz for the GPU and has 1408 Stream Processors, 22 SIMDs (two SIMDs less than the HD 6970) and 88 Texture Units.
The info that we now have looks solid and it appears to be what AMD has been telling its partners and selected press about its upcoming Cayman based HD 6970 and the HD 6950 cards. The HD 6950 is capable of delivering 2.25 TFLOPs of compute power and uses the VLIW4 shader architecture, same as the HD 6970.
The GDDR5 memory on HD 6950 cards ended up clocked at 1250MHz (5.0Gbps) and paired up with a 256-bit memory interface, which is a bit lower than the 5.5Gbps on the HD 6970. The interesting thing is that both cards will be equipped with 2GB of GDDR5 memory.
The TDP, something that has been quite a debatable topic recently, is set at 200W. Note that 200W is AMD's PowerTune Maximum Power whereas typical gaming power is set at 140W. Idle TDP is set at 20W, same as the HD 6970. The card needs two 6-pin PCI-Express power connectors and has two DVI, two mini-DP and an HDMI output.
The card has already found its way to some of the press guys, and should launch on 15th of December.
1408 SPs, 200W TDP
Nigaaazz
TOP ::
Ja potle zoom si očitno mel slabe primerke,jaz sem jih 5 nastavu in vsi delajo na 4ghz BP.Jaz sem celo dobil super primerek ki na 4200 dela BP.Pa pustimo zdej to,ker je itak oftopic.Kar se tiče grafe je treba še mal počakat na tele cene,ker sedaj so več ali manj ugibanja glede ATIja.
Machiavelli ::
Mja se strinjam pač batchi procesorjeu so različni ...anyway še 3-4dni do izida f*k komi čakam xD
Nigaaazz
IvoJan ::
Jao niko xD
kmetek ::
Clubraider je izjavil:
Dejstvo, pa je da trgovci z pridom izkoristijo take cene...pa jih še bolj gor nabijejo...
seveda 50%.
- spremenil: kmetek ()
galu ::
V čem je fora nalepke na sliki tega 'leak radeona': Slow Speed Board? - tista zelena nalepka na strani..
Tako to gre.
Clubraider ::
Imam občutek, da ti novi driveri 10.12 nebodo nič boljši kot 10.10 in 10.11 ...
Vseeno upam, da se motim..
filip007 ::
Digatalen šublar smo pa precizni...bolj kot BMW.
Zero games, zero talk.
Machiavelli ::
Novice:
Prve frišne Novice samo tu In od mene za Vas :)
Avtor Prispevka :ZOOM
Vse pravice te objave so v skladu z zakonom in pridržane!
xD
xD
Nigaaazz
- spremenil: Machiavelli ()
Machiavelli ::
Za lažje predstavljanje:
Uporabljeni gonilniki za HD69xx 10.11 Domnevam beta..HD5xxx in HD68xx 10.10e
Uporabljeni gonilniki za GTX 26x
OG plan za tekmo:
hd6970 v boju z gtx480
hd6950 v boju z gtx470
hd5970 v boju z gtx580
hd6990 v boju z hd5970
Pomnite lahko da gre za 6950 model in ne 6970....
Crysis max 1920x1200 8xAA 16xF
GTX580 Avređ 39fps
GTX480 Avređ 30fps
HD69x0 Avređ 36fps
HD5870 Avređ 32fps
Heaven 2.1 max 1920x1200 16x 8x extreme
GTX580 Avređ 30.8fps
GTX480 Avređ 26.1fps
GTX470 Avređ 20.6fps
HD69x0 Avređ 25.4fps
HD6870 Avređ 14.6fps
HD5870 Avređ 13.1fps
HD6850 Avređ 12.7fps
HD5850 Avređ 10.7fps
HD6850 CF A 24.3fps
HD6870 CF A 27.8fps
3D MARK 11 P
GTX580 P6113
GTX570 P5306
HD69x0 P4939
HD5870 P4458
HD6870 P4329
OG plan za tekmo:
GTX580 Avređ 39fps
GTX480 Avređ 30fps
HD69x0 Avređ 36fps
HD5870 Avređ 32fps
HD6850 CF A 24.3fps
HD6870 CF A 27.8fps
3D MARK 11 P
GTX580 P6113
GTX570 P5306
HD69x0 P4939
HD5870 P4458
HD6870 P4329
Nigaaazz
galu ::
Tk da bolj ali manj, GTX570 je že malce boljša od HD6970, GTX580 pa je čisto brez konkurence?
Zgleda da je nekdo šel na zimsko spanje, malce prehitro.. :D
Tako to gre.
Pšenični ::
Za Radeone so resnično uporabljeni beta gonilniki, saj nekateri podatki ne držijo-rezultati. Torej če 6970 ne bo bolša od NV 580 bo to že majhno razočaranje. Sploh če pogledamo cene. Če pogledamo cene, bi morala bit 6970 bolša za 5% od NV 580. No tak je moj občutek, da bo zadeva še malo boljša. Z gonilniki, ki bojo izdani pred 15 decembrom.
Machiavelli ::
Nemoreš trdit niti na podlagi cene ni čisto tako...
Zdaj pa če bo driver res kaj spremenil 5-15% potlej je pa možno...
Samo dvomim res..ker 6970 ni mišljena na boj z gtx580 temveč z gtx480 tak da tud če je 5-15% boljša od gtx480 je to že nek uspeh...za malo več denarja..
hd6970 380~440eur ("10-15% gor od gtx480")
hd6950 280~340eur ("5-15% gor od gtx470")
gtx470 200~260eur ("0 nevtrala")
gtx560 180~230eur (15-20% gor od gtx460")
gtx570 320~390eur ("0-3,5% gor od gtx480")
gtx480 325~380eur ("0 nevtrala")
gtx580 440~520eur ("15-20% gor od gtx480")
Po tej logiki iz novic 6950 ostane sama v svojem razredu kajti gtx470 in gtx560 nebo neke razlike....kartica pa nebo na rangu gtx480....gtx470 je trenutno neck to neck z hd6870,gtx560 nebo kaj veliko spremenila.
Torej hd6970 bo močnejša od gtx570 a posledično dražja,slabša od gtx580 a cenejša le od te.
hd6950 pa bo močnejša od gtx470 posledično dražja,slabša od gtx570 a cenejša od te.
Procenti izračunani z igrami in benči 14 za povprečni procent moči.
Nigaaazz
Machiavelli ::
Novice: part2
Več slikic in Gpu-z.
xD
xD
Nigaaazz
Machiavelli ::
Novice: part3
Lep Biftek xD
xD
Lep Biftek xD
xD
Nigaaazz
Machiavelli ::
Primerjava z 5870.
Futuremark 3DMark Vantage - High:
oAMD Radeon HD 5870: 13613
oAMD Radeon HD 6970: 15154
Resident Evil 5 - 1920x1080:
oAMD Radeon HD 5870: 107,4 FPS
oAMD Radeon HD 6970: 116,1 FPS
Unigine Heaven 2.1 - 1920x1080:
oAMD Radeon HD 5870: 16,5 FPS
oAMD Radeon HD 6970: 25,5 FPS
Nigaaazz
Xserces ::
zoom men se zdi da si ti mau obseden xD
Pšenični ::
Gonilniki so od prejšnjega meseca, tko da pričakujem te dni nove in boost za okoli 10%-15% minimalno. Za nove Radeone.
Razlika ki je podana prejle, je le premajhna. Med 5870 in 6970.
- spremenilo: Pšenični ()
Xserces ::
upajmo!
Pšenični ::
Gonilniki so od 18 novembra, navadno pa dajo pred izzidom še nove. Tko je bilo zmeraj.Jaz tud upam, da bo tudi tokrat tako. Včasih pridejo celo en dan prej.
"Resident Evil 5 - 1920x1080:
oAMD Radeon HD 6970: 116,1 FPS"
Tole je le malo več kot nič...za ta razred kartic. Tle smo v najvišjem. Razlika mora biti 30-50%. Minimalno. Drgač kdo bo dal 250 evrov več zza 9 sliki več na sekundo.
Machiavelli ::
Ja samo nebo kaj lih veliko vplivalo,vsaj jaz tako mislim...tu imam neko surovo primitivno moč kartice z poliranjem pa tam 0-5%+,poleg tega prašanje ali je testirano z defult kvaliteto slike ali vse na max ker defult prinese 5% boosta v primerjavi če damo ročno na high...
Kartica se odnese kar solidno v boju z gtx480 kot napovedano,tak da je tud cena primerna...
Razlika ni premajhna je kar solidna in resnična....
6870 da 16-17fspa
6850 da 14-15fpsa
6970 po specifikacijah je kot neka 6850cf oskubljena v enih elementih in pojačana v drugih..
Po testu tessalacije je opazna surova moč..
6970 ni mišljena kot 2x 5870 to bi bilo 50% gor,
bolj 30-40% gor od singl 5870
Še 1X si dobro oglej graf 6970 je slabša od 5970 ki je slabša od 2x 5870cf
6870 da 16-17fspa
6850 da 14-15fpsa
Nigaaazz
Pšenični ::
"Pa saj ni 500eur LoL 370~430eur isti rang kot gtx480 in gtx570."
Ma, glede na spodnji oziroma srednji razded je majhno razočaranje, če bo ostalo tako.
Machiavelli ::
Jst kakor vem na moji kartici hotfixi so samo še znižali score in frejme v smislu optimizacije... res dvomim ...Ni pa to čist neka nova revolucionarna arhitektura da nuca nwm kake popravke v driverih...pač ja mal se da spolirat pač min fps povečat malo bolj simetrično pa kak score 5% dvignit...
če bo do prodaju navadno 6970 za 500eur se lahko komot z njo touče po glavi xD edini za to bo uporabno al kako xD
Nigaaazz
IvoJan ::
men se sploh ne da cakat na te grafe lol xD pomoje bom jutr narocu GTX570. amd me je spet razocaral.
Senitel ::
Med 6870 in 6970 je precej večja razlika kot med 6870 in 5870... Niti se mi ne zdi prav uporabno primerjat 6870 in 6970. Veliko bolj enostavna je primerjava direkt med 5870 in 6970.
Bo pa kot kaže ves bonus v hitrosti izhajal samo iz izboljšav v arhitekturi. Nekaj več teksturirnih zmogljivosti par izboljšav v ROP-ih ter spremembe v shader core-u in hitrejša teselacija.
Machiavelli ::
Točno tko,bo pa 6970 imela prednost v porabi štroma
20w idel
190w gaming
250w max
Pač zdaj imate širšo opcijo v tem cenovnem rangu..za singl jedro...
gtx480 najcenej poraba velika in veliko toplote.
gtx570 cena malo večja manjša poraba manj toplote boljši performanc.
hd6970 cena še malo večja še manjša poraba še hladnejša še boljši performanc.
Realno gledano hd6970 ni slaba kartica....
je kr v sorazmerju moč/poraba
ima pa premalo šejderou da bi bila močnejša posledično večja poraba,več toplote,večja cena itd...
Ampak moramo pohvalit AMD da je naredil dobro kartico no z izboljšavami..
Telbanc
384 (4d) 1536 vs 1600 (5d) 320
Update
20w idel
190w gaming
250w max
Telbanc
Update
Nigaaazz
Clubraider ::
So kake primerjave med 6870 CF in 6970...katera je boljša??
Drugače zoom vsaka čast za te novice in informacije.
- spremenil: Clubraider ()
Machiavelli ::
6870 cf je boljše brez dvoma...
6870cf je enaka oz boljša od 5970,6970 pa ni niti z 5970...
Nigaaazz
batista ::
Ne vem po kaki logiki ima 6970 manjšo porabo napram gtx 570? 250W(6970) VS 220W(gtx 570)?
250W max porabe pa res nebi pričakoval omfg. Glede na to da ima 5870 188W. Ajmo komentarje v smislu elektran ob hiši in turbin pod mizo...
sicer pa mislim da ko pridejo uradni benchi bo stvar drugačna, ker drugače je tole fail s strani atija.
Machiavelli ::
Po taki da spet slabo berete..madonca.
20w idel
190w tiipično gaming
250w max blokada za kakšen burn mark...
Fail jah niti ni je bolj hladna bolj varčna in malce hitrejša od gtx480 to je bil takrat cilj,umes je pa nvidia izdala gtx580 je pa bilo prepozno za karkoli spreminjat...
Stvari bojo samo malce spolirane min fps,pa kak procent gor za točke pa frejme to je pa več ali manj to...
20w idel
Nigaaazz
IvoJan ::
Gtx570 pa ima max v furmarku 219w. Torej ima 570 nizjo porabo kot 6970.
Machiavelli ::
Ja nwm če glih ma... kolk je pa ko odkleneš blokado?
225w je za 570...
any way sej bo tu tu brezveze se karkoli prerekat zdaj kar je je xD
Jah lih kaj bolj varčno na trenutni tehnologiji nemoreš narest...
vsakič ko bodo manšali proizvodni proces bojo blemi kajti prišli bodo do neke meje ko naravni zakoni fizike nebodo več dopustili...
Bo treba pol šaltat na dnk,atom,fiber jedra xD
225w je za 570...
Nigaaazz
| » | Katero grafično kartico kupiti 6870 ali 6950? (strani: 1 2 3 4 )Oddelek: Kaj kupiti | 41419 (37850) | galu |
| » | Radeon 6950 se odklene (strani: 1 2 3 )Oddelek: Novice / Grafične kartice | 38771 (33210) | Jst |
| ⊘ | Nvidia vs AMD,Gtx 470/570 vs 6970/50HD+Novice (strani: 1 2 3 4 5 6 7 8 )Oddelek: Strojna oprema | 101978 (96293) | bluefish |
| » | Nova Radeona sta tukajOddelek: Novice / Grafične kartice | 22423 (21110) | PrimozR |
| » | GeForce GTX 580 v sliki in številkah (strani: 1 2 )Oddelek: Novice / Grafične kartice | 23456 (21329) | Senitel |
