Forum » Pomoč in nasveti » cod2 server
cod2 server
oldb12 ::
no, probal sem naredit svoj server za call of duty 2, samo ne dela... jas lahko grem noter samo ko hoče kdo drugi pa mu ne zazna.
mam ruter, samo sem odprl vse porte
probal sem tudi z crackom pa isto ne dela
v bližnjici mam napisano: +set dedicated 2 +set net_port 28960 +exec server.cfg +map_rotate +set sv_punkbuster 1
v konzoli mi to izpiše:
CoD2 MP 1.3 build win-x86 May 1 2006
----- FS_Startup -----
Current language: english
Current search path:
D:\Igre\Call of Duty 2\main\iw_15.iwd (85 files)
D:\Igre\Call of Duty 2\main\iw_14.iwd (4038 files)
D:\Igre\Call of Duty 2\main\iw_13.iwd (22624 files)
D:\Igre\Call of Duty 2\main\iw_12.iwd (1016 files)
D:\Igre\Call of Duty 2\main\iw_11.iwd (1462 files)
D:\Igre\Call of Duty 2\main\iw_10.iwd (1936 files)
D:\Igre\Call of Duty 2\main\iw_09.iwd (2142 files)
D:\Igre\Call of Duty 2\main\iw_08.iwd (2723 files)
D:\Igre\Call of Duty 2\main\iw_07.iwd (3384 files)
D:\Igre\Call of Duty 2\main\iw_06.iwd (990 files)
D:\Igre\Call of Duty 2\main\iw_05.iwd (928 files)
D:\Igre\Call of Duty 2\main\iw_04.iwd (698 files)
D:\Igre\Call of Duty 2\main\iw_03.iwd (26 files)
D:\Igre\Call of Duty 2\main\iw_02.iwd (40 files)
D:\Igre\Call of Duty 2\main\iw_01.iwd (16 files)
D:\Igre\Call of Duty 2\main\iw_00.iwd (102 files)
D:\Igre\Call of Duty 2/main
D:\Igre\Call of Duty 2/raw
D:\Igre\Call of Duty 2/raw_shared
D:\Igre\Call of Duty 2/devraw
D:\Igre\Call of Duty 2/devraw_shared
D:\Igre\Call of Duty 2\main\localized_english_iw11.iwd (1 files)
localized assets iwd file for english
D:\Igre\Call of Duty 2\main\localized_english_iw10.iwd (414 files)
D:\Igre\Call of Duty 2\main\localized_english_iw09.iwd (98 files)
D:\Igre\Call of Duty 2\main\localized_english_iw08.iwd (8 files)
D:\Igre\Call of Duty 2\main\localized_english_iw07.iwd (1014 files)
D:\Igre\Call of Duty 2\main\localized_english_iw06.iwd (3110 files)
D:\Igre\Call of Duty 2\main\localized_english_iw05.iwd (5310 files)
D:\Igre\Call of Duty 2\main\localized_english_iw04.iwd (6240 files)
D:\Igre\Call of Duty 2\main\localized_english_iw03.iwd (6580 files)
D:\Igre\Call of Duty 2\main\localized_english_iw02.iwd (6404 files)
D:\Igre\Call of Duty 2\main\localized_english_iw01.iwd (5510 files)
D:\Igre\Call of Duty 2\main\localized_english_iw00.iwd (4764 files)
File Handles:
81663 files in iwd files
execing default_mp.cfg
couldn't exec language.cfg
execing players/666sloharder/config_mp.cfg
cl_paused is read only.
com_playerProfile is read only.
fixedtime is cheat protected.
fs_basegame is write protected.
fs_basepath is write protected.
fs_cdpath is write protected.
fs_copyfiles is write protected.
fs_game is write protected.
fs_homepath is write protected.
fs_ignoreLocalized is cheat protected.
logfile opened on Fri Jul 30 16:14:13 2010
sv_cheats is write protected.
sv_running is read only.
dedicated is read only.
Measured CPU speed is 2.33 GHz
System memory is 1024 MB (capped at 1 GB)
Video card is "NVIDIA GeForce 9500 GS"
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: hisni
IP: 192.168.1.2
IP: 5.59.78.106
--- Common Initialization Complete ---
execing server.cfg
net_ip will be changed upon restarting.
map_rotate...
"sv_mapRotation" is:"map mp_dawnville map mp_farmhouse map mp_brecourt map mp_burgundy map mp_trainstation map mp_carentan map mp_leningrad map mp_matmata map mp_downtown map mp_railyard map mp_toujane map mp_breakout"
"sv_mapRotationCurrent" is:""
Setting map: mp_dawnville.
------ Server Initialization ------
Server: mp_dawnville
File Handles:
handle 1: console_mp.log
163326 files in iwd files
Loading 'ui_mp/ingame.menu'...
Loading 'ui_mp/ingame_controls.menu'...
Loading 'ui_mp/ingame_options.menu'...
Loading 'ui_mp/ingame_system.menu'...
Loading 'ui_mp/ingame_leave.menu'...
Loading 'ui_mp/ingame_callvote.menu'...
Loading 'ui_mp/wm_quickmessage.menu'...
Menu load error: ui_mp/wm_quickmessage.menu, line 9: unknown menu keyword name
Menu load error: ui_mp/wm_quickmessage.menu, line 10: unknown menu keyword quickmessage
Menu load error: ui_mp/wm_quickmessage.menu, line 10: unknown menu keyword visible
Menu load error: ui_mp/wm_quickmessage.menu, line 10: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 11: unknown menu keyword fullscreen
Menu load error: ui_mp/wm_quickmessage.menu, line 11: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword rect
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword 640
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword 480
Menu load error: ui_mp/wm_quickmessage.menu, line 13: unknown menu keyword focuscolor
Menu load error: ui_mp/wm_quickmessage.menu, line 13: unknown menu keyword 1
Menu load error: ui_mp/wm_quickmessage.menu, line 14: unknown menu keyword disablecolor
Menu load error: ui_mp/wm_quickmessage.menu, line 14: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 15: unknown menu keyword style
Menu load error: ui_mp/wm_quickmessage.menu, line 15: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 17: unknown menu keyword onOpen
Menu load error: ui_mp/wm_quickmessage.menu, line 18: unknown menu keyword {
Menu load error: ui_mp/wm_quickmessage.menu, line 19: unknown menu keyword setDvar
Menu load error: ui_mp/wm_quickmessage.menu, line 19: unknown menu keyword cl_bypassMouseInput
Menu load error: ui_mp/wm_quickmessage.menu, line 20: unknown menu keyword 1
Menu load error: ui_mp/wm_quickmessage.menu, line 20: menu has no name
------- Game Initialization -------
gamename: Call of Duty 2
gamedate: May 1 2006
sv_punkbuster is write protected.
Working directory: D:\Igre\Call of Duty 2
PunkBuster Server: pb_sv_SsNext = 786354 (0 to 999999)
PunkBuster Server: pb_sv_LogNext = 112 (1 to 999999)
PunkBuster Server: PB Log File D:\Igre\Call of Duty 2\pb\svlogs\00000112.log Opened for COD2 (w)
PunkBuster Server: 0 Power Players loaded from D:\Igre\Call of Duty 2\pb\pbpower.dat
PunkBuster Server: 0 PB Rcon Filters loaded from D:\Igre\Call of Duty 2\pb\pbrcon.dat
PunkBuster Server: 0 Map lines loaded from D:\Igre\Call of Duty 2\pb\pbsvmaps.cfg
PunkBuster Server: Attempting to resolve master1.evenbalance.com
PunkBuster Server: Resolved to [66.36.231.175]
PunkBuster Server: PunkBuster Server for COD2 (v1.760 | A1383 C2.208) Enabled
Hitch warning: 4603 msec frame time
Resolving cod2master.activision.com
cod2master.activision.com resolved to 63.146.124.40:20710
Sending heartbeat to cod2master.activision.com
PunkBuster Server: Game Version [CoD2 MP 1.3 build pc_1.3_1_1 Mon May 01 2006 05:05:43PM win-x86]
cod2master.activision.com resolved to 63.146.124.40:20700
]status
map: mp_dawnville
num score ping guid name lastmsg address qport rate
pregledal sem že pol interneta pa nikjer ne piše nič koristnega...torej če mi lahko kdo pomaga mu bom zelo hvaležen.
File Handles:
Winsock Initialized
Hostname: hisni
IP: 192.168.1.2
IP: 5.59.78.106
execing server.cfg
map_rotate...
File Handles:
]status
map: mp_dawnville
- spremenil: oldb12 ()
popster ::
nisem slicer gledal logov, a mozno da če lahko samo iz svoje mreže "accessaš" to pomeni da lahko ne spusti firewall, ISP blokira ali pa kaj z statičnim Ip-je/dnsjem
oldb12 ::
z izklopljenim firewallom ne dela, torej to ni... če pa kaj druga slučajno blokira pa nevem...
oldb12 ::
aja pa lahko se povežem preko notranjega ipja(192.168.1.1) al pa prek čist petega, oni ko mi ga napiše tu pa sploh ne zazna, če to kaj pomaga
| » | Kako narediti svoj server v Call of Duty 2 ?Oddelek: Igre | 9547 (3207) | deadzone |
| » | Call of duty 2!ne dela server!problems!Oddelek: Igre | 6026 (4028) | ViperR |
| ⊘ | COD 2 ne delujeOddelek: Igre | 3312 (2321) | Heavy |
| ⊘ | cod2 server problemi[pomoč please]- modem???Oddelek: Igre | 2946 (2872) | Mavrik |
| » | COD2 set dedicated 2Oddelek: Igre | 3894 (3749) | Mr.B |
