Call of duty 2!ne dela server!problems!
omahen ::
Tukaj SS Elitehitler prosim vas ce seveda kdo ve da mi prosim pove kako se naredi server za cod2 nekaj sem naredil ampak ne dela neki mi napise menu error!
en config sm u main koperu pa naredu bliznco pa notr sm upisu:
"D:\cod2server\Activision\Call of Duty 2\CoD2MP_s.exe" +set dedicated 2 +exec dedicated.cfg +map_rotate +set net_port "28961"
ce kdo ve zakaj ne dela ali pa ce mi je kdo pripravljen se enkrat povedati kako se naredi server za cod2 naj mi to prosim odpise alipa naj mi sporoci na msn:zazy3NO@SPAMhotmail.com
hvala!:)
Andraz
Kami ::
www.fpsadmin.com - tam maš tutorial
omahen ::
ja sam problem je da ne znam anglesk!
Andraz
OldSkul ::
"D:\cod2server\Activision\Call of Duty 2\CoD2MP_s.exe" +set dedicated 2 +exec dedicated.cfg +map_rotate +set net_port "28961 +set net_ip 192.168.*.* - pač lokalni IP na mreži
Tko mam jest in mi zadeva dela.
  • spremenil: OldSkul ()
omahen ::
sam problem je da men ko odprem konzolo mi napise:neki menu error:
CoD2 MP 1.0 build win-x86 Oct 6 2005
----- FS_Startup -----
Current language: english
Current search path:
C:\Program Files\Activision\Call of Duty 2\main\z_powerserver_mod_v05.iwd (15 files)
C:\Program Files\Activision\Call of Duty 2\main\z_PAM2_nodot.iwd (2 files)
C:\Program Files\Activision\Call of Duty 2\main\z_PAM2_Beta2.iwd (54 files)
C:\Program Files\Activision\Call of Duty 2\main\z_PAM2.0.iwd (65 files)
C:\Program Files\Activision\Call of Duty 2\main\Z_FGC_v07.iwd (27 files)
C:\Program Files\Activision\Call of Duty 2\main\zzz_svr_Thompson-30.iwd (3 files)
C:\Program Files\Activision\Call of Duty 2\main\zzz_svr_cooked_nades.iwd (6 files)
C:\Program Files\Activision\Call of Duty 2\main\zzz_Dale_smoke_mod_COD2.iwd (28 files)
C:\Program Files\Activision\Call of Duty 2\main\zzz_all_rifles_v1.4.iwd (12 files)
C:\Program Files\Activision\Call of Duty 2\main\zzzzzzz-compmod_v1.iwd (65 files)
C:\Program Files\Activision\Call of Duty 2\main\RCModV3.iwd (285 files)
C:\Program Files\Activision\Call of Duty 2\main\nadesmod.iwd (7 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_14.iwd (4038 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_13.iwd (22624 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_12.iwd (1016 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_11.iwd (1462 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_10.iwd (1936 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_09.iwd (2142 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_08.iwd (2723 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_07.iwd (3384 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_06.iwd (990 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_05.iwd (928 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_04.iwd (698 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_03.iwd (26 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_02.iwd (40 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_01.iwd (16 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_00.iwd (102 files)
C:\Program Files\Activision\Call of Duty 2/main
C:\Program Files\Activision\Call of Duty 2/raw
C:\Program Files\Activision\Call of Duty 2/raw_shared
C:\Program Files\Activision\Call of Duty 2/devraw
C:\Program Files\Activision\Call of Duty 2/devraw_shared
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw10.iwd (414 files)
localized assets iwd file for english
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw09.iwd (98 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw08.iwd (8 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw07.iwd (1014 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw06.iwd (3110 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw05.iwd (5310 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw04.iwd (6240 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw03.iwd (6580 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw02.iwd (6404 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw01.iwd (5510 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw00.iwd (4764 files)
File Handles:
82146 files in iwd files
execing default_mp.cfg
couldn't exec language.cfg
execing players/Andraz/config_mp.cfg
dedicated is read only.
Measured CPU speed is 2.99 GHz
System memory is 447 MB (capped at 1 GB)
Video card is "RADEON 9100 IGP"
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: doma-53e574b06a
IP: 169.254.166.33
IP: 193.95.195.239
--- Common Initialization Complete ---
execing dedicated.cfg
invalid variable name: .Admin
invalid variable name: .Email
invalid variable name: .Irc
invalid variable name: .Website
invalid variable name: .Forums
invalid variable name: .Location
g_gametype will be changed upon restarting.
sv_cheats is write protected.
logfile opened on Mon Dec 19 21:13:42 2005
sv_iwdNames is read only.
sv_iwds is read only.
sv_referencedIwdNames is read only.
sv_referencedIwds is read only.
map_rotate...
"sv_mapRotation" is:"gametype sd map mp_breakout gametype ctf map mp_brecourt gametype dm map mp_burgundy gametype tdm map mp_carentan gametype tdm map mp_dawnville gametype tdm map mp_decoy gametype tdm map mp_downtown gametype sd map mp_farmhouse gametype tdm map mp_leningrad gametype tdm map mp_matmata gametype sd map mp_railyard gametype tdm map mp_toujane gametype dm map mp_trainstation"
"sv_mapRotationCurrent" is:""
Setting g_gametype: sd.
Setting map: mp_breakout.
------ Server Initialization ------
Server: mp_breakout
File Handles:
handle 1: console_mp.log
164292 files in iwd files
Loading 'ui_mp/ingame.menu'...
Loading 'ui_mp/ingame_controls.menu'...
Loading 'ui_mp/ingame_options.menu'...
Loading 'ui_mp/ingame_system.menu'...
Loading 'ui_mp/ingame_leave.menu'...
Loading 'ui_mp/ingame_callvote.menu'...
Loading 'ui_mp/wm_quickmessage.menu'...
Menu load error: ui_mp/wm_quickmessage.menu, line 9: unknown menu keyword name
Menu load error: ui_mp/wm_quickmessage.menu, line 10: unknown menu keyword quickmessage
Menu load error: ui_mp/wm_quickmessage.menu, line 10: unknown menu keyword visible
Menu load error: ui_mp/wm_quickmessage.menu, line 10: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 11: unknown menu keyword fullscreen
Menu load error: ui_mp/wm_quickmessage.menu, line 11: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword rect
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword 640
Menu load error: ui_mp/wm_quickmessage.menu, line 12: unknown menu keyword 480
Menu load error: ui_mp/wm_quickmessage.menu, line 13: unknown menu keyword focuscolor
Menu load error: ui_mp/wm_quickmessage.menu, line 13: unknown menu keyword 1
Menu load error: ui_mp/wm_quickmessage.menu, line 14: unknown menu keyword disablecolor
Menu load error: ui_mp/wm_quickmessage.menu, line 14: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 15: unknown menu keyword style
Menu load error: ui_mp/wm_quickmessage.menu, line 15: unknown menu keyword 0
Menu load error: ui_mp/wm_quickmessage.menu, line 17: unknown menu keyword onOpen
Menu load error: ui_mp/wm_quickmessage.menu, line 18: unknown menu keyword {
Menu load error: ui_mp/wm_quickmessage.menu, line 19: unknown menu keyword setDvar
Menu load error: ui_mp/wm_quickmessage.menu, line 19: unknown menu keyword cl_bypassMouseInput
Menu load error: ui_mp/wm_quickmessage.menu, line 20: unknown menu keyword 1
Menu load error: ui_mp/wm_quickmessage.menu, line 20: menu has no name
------- Game Initialization -------
gamename: Call of Duty 2
gamedate: Oct 6 2005
******* script compile error *******
unknown function: (file 'extreme/_ex_clientcontrol.gsc', line 711)
self maps\mp\gametypes\_weapons::updateDisabledSingleClient(self.pers["weapon"]);
Error during initialization:
(see console for details)
:D
Če to veš kaj nardit bi te prosu za msn?!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
pa prosu bi nekoga da bi mi preko msnja poslou cfg file se enkrat ka mislm da je mal napacn
Andraz
skuti ::
Js znam narediti server in imam programe s katerimi teh kod sploh ne rabiš pisati:D
Če želiš programe ali pa informacije me dodaj na msn-ju: skuti99@hotmail.com!;)
--------------------------- CoD 2 MP Rules
PIK@LO ::
LP!
vidim da ste razčistili.Eno vprašanje. imam mrežo 6 računalnikov, na vsakem pc-ju je igro Call of duty 2 (legalne!!!!)- Ko hočemo narediti server ali se vsi povezati nanj, nam naraste ping na 999. Zakaj to. Prenos ni problem. Je mogoče vzrok ker imajo vsi trije špili le en port 28960 in vsi računalniki silijo naenkrat skoz? Ce ima kdo pojma mi prosim pomagajte. Hvala
Sašo
skuti ::
Ali ste naredili Dedicated internet ali lan?
Če imate naštimano na internet poskusite na lan in nato samo pod CoD 2 MP pod Join Game / Source : nstimas local in ti najde server . To bi moralo delovati!
PIK@LO ::
sej na LAN gre igrati, le preko neta ne. Ko se hočemo npr. na server v Avstraliji povezati gre le enemu igrati, če pa pride drugi ali vsi zadaj pa imamo naenkrat pinge 999. pa je konec. Ko pa gredo drugi dol, pa spet špila. Neznanka ha?
skuti ::
Tej imate pa verjetno prepočasen internet.:(
Kakšnega pa imate?:\
redarmy ::
zdravo a mi lohk kšn pomaga?problem je k zalavfam kšn server mi napiše da ta key code je že v porabi a se da temu kako izognt?
OmegaBlue ::
Tako da ga kupiš.
Denis15 ::
Tako da ga kupiš.
redarmy če kupiš org key ZS
xD
redarmy ::
HVALA!
aja kje se ga pa kupi in kolk stane?
ne spoznam se na to k mam šele 11 let
  • spremenil: redarmy ()
CareKajze ::
redarmy ::
EJ ker servem v COD2 je vam najboljši?
st0jko ::
HVALA!
kupiš ga tukaj klik stane pa borih 15€+poštnina.
keks?
dejan kren ::
alo eno uprašanje, ko se connectam na kak server mi par minut normalno dela, nato me vrže ven in napiše :
CoD2MP_S.EXE je naletel na težavo
a mi lahko nekdo lepo prosim pove kako odpravim težavo.
HVALA !
OnFire ::
@dejan kren
A maš krekano? Če maš je lahko zanič crack.
redarmy ::
Ej ker server je vm najbolši???
timmyy ::
Eno uprašanje, ko u xf kliknem kak server mi vrže vn : Failed to load gfx driver gfx_d3d_mp_x86_s.dll.
prej sm ga normalno špilu po sm pa hotu naredit en server pa delu čist po navodilih pa ko sm pršu do konca,ko sm kliknu mi pa vrže to vn. in pol sm zbrisu bližnjico iz namizja pa tisto kar morš dat u main pa probam....Failed to load gfx driver gfx_d3d_mp_x86_s.dll.
Help
rešeno =)
  • spremenil: timmyy ()
redarmy ::
Halo?! Ker je vŠ najbolŠi server!? ;(
  • polepsal: Rotaidal ()
iNooby ::
Gustek server toujane sd
je možno met server če maš rutera?
Haters gonna hate...
  • spremenilo: iNooby ()
Rotaidal ::
Zakaj pa ne?
iNooby ::
nevem, mogo bi porte odpret al kak je s tem ne? pa še dinamični ip naslov mam...
bi mi lahko nekdo prosim natanko razložil kako torej naredit server preko routerja z din. IP? al pa prilimal kak vodič?
hvala :)
ViperR ::
pa sej mas na netu za vsak ruter napisan vodič kak se port odpre.. drgac pa http://www.callofduty.si/clanki/vodici/... . Tuki sm jst naredu dela vse super..
iNooby ::
viper sem tudi jaz naredil po tem vodiču pa se mi zatakne pol ko vtipkam not za start map mp_toujane naprimer...pol dalje pa nevem kak bi v game priso
ViperR ::
ja na x fire najdes server(tak ip kukr si napisov) pa gres not in napises /rcon login GESLO KI GA V MAPI SERVER.CFG NAPISES, /rcon map mp_toujane. Pa v mapi server.cfg je geslo za admin in za rcon uporablat(to je razlika).
Kako narediti svoj server v Call of Duty 2 ?
Oddelek: Igre
229617 (3277) deadzone
CoD Problemi (strani: 1 2 )
Oddelek: Igre
6513120 (9093) iloveboobz
COD 2 ne deluje
Oddelek: Igre
143347 (2356) Heavy
cod2 server problemi[pomoč please]- modem???
Oddelek: Igre
53021 (2947) Mavrik
COD2 set dedicated 2
Oddelek: Igre
63948 (3803) Mr.B
