Forum » Igre » COD 2 ne deluje
COD 2 ne deluje
zigc1996 ::
Včeraj sem inštalerov COD 2. Ko sem hotel igrati sem ga pognal, ampak se je pokazalo sporočilo: Fatal Error:
Error During initialization: No valid rendering code path detected. In pol klikneš OK in se ti pokaže neko poročilo:
CoD2 MP 1.0 build win-x86 Oct 6 2005
----- FS_Startup -----
Current language: english
Current search path:
C:\Program Files\Activision\Call of Duty 2\main\iw_14.iwd (4038 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_13.iwd (22624 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_12.iwd (1016 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_11.iwd (1462 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_10.iwd (1936 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_09.iwd (2142 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_08.iwd (2723 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_07.iwd (3384 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_06.iwd (990 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_05.iwd (928 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_04.iwd (698 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_03.iwd (26 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_02.iwd (40 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_01.iwd (16 files)
C:\Program Files\Activision\Call of Duty 2\main\iw_00.iwd (102 files)
C:\Program Files\Activision\Call of Duty 2/main
C:\Program Files\Activision\Call of Duty 2/raw
C:\Program Files\Activision\Call of Duty 2/raw_shared
C:\Program Files\Activision\Call of Duty 2/devraw
C:\Program Files\Activision\Call of Duty 2/devraw_shared
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw10.iwd (414 files)
localized assets iwd file for english
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw09.iwd (98 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw08.iwd (8 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw07.iwd (1014 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw06.iwd (3110 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw05.iwd (5310 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw04.iwd (6240 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw03.iwd (6580 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw02.iwd (6404 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw01.iwd (5510 files)
C:\Program Files\Activision\Call of Duty 2\main\localized_english_iw00.iwd (4764 files)
File Handles:
81577 files in iwd files
execing default_mp.cfg
couldn't exec language.cfg
========= autoconfigure
configure_mp.csv: using CPU configuration 2 GHz 512 MB
execing configure_mp.cfg
configure_mp.csv: using GPU configuration "*"
Measured CPU speed is 2.39 GHz
System memory is 1022 MB (capped at 1 GB)
Video card is "Intel(R) 82845G/GL/GE/PE/GV Graphics Controller"
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: ziga-pc
IP: 192.168.1.2
----- Initializing Renderer ----
----- Client Initialization -----
----- Client Initialization Complete -----
----- R_Init -----
Getting Direct3D 9 interface...
Pixel shader version is 0.0
Vertex shader version is 0.0
Video card or driver doesn't accelerate transform and lighting.
Video card or driver doesn't support high-quality polygon offset.
Video card or driver doesn't support the required fixed-function texture blend operations.
DirectX 7 rendering path will not be available.
Video card or driver doesn't support direction lights in the fixed-function pipeline.
Video card or driver doesn't support texture coordinate generation in the fixed-function pipeline.
Video card or driver doesn't support enough texture coordinates for the DirectX 9 code path.
DirectX 9 rendering path will not be available.
Video card or driver doesn't support enough textures for the DirectX 9 code path.
Video card or driver doesn't support enough hardware lights for the DirectX 7 code path.
Error during initialization:
Zdej ne vem kako naprej. Prosim če mi pomagate.
LP Žiga
File Handles:
Winsock Initialized
Hostname: ziga-pc
IP: 192.168.1.2
----- R_Init -----
LP Žiga
- zaklenil: ahac ()
bajsibajsi ::
Najpogostejsi vzrok za tvoj problem je nepodprto graficno cipovje. Dosti intengriranih Intelovih graficnih cipov ni niti podpiralo T&L ali PS.. ceprav bi ti moralo biti skoraj vseeno, ce poskusih v DX7.
bajsibajsi ::
Zgolj za informacijo. Katero graficno kartico imas?
Ce ne ves v Start meni Zazeni vpisi "dxdiag" in v noven oknu spodaj kliknu Shrani vse informacije ter nato zgornjo stran ali dve tistih informacij prilimaj tu.
paljer ::
Nov računalnik je potrebno kupiti,
grafična je Video card is "Intel® 82845G/GL/GE/PE/GV Graphics Controller, kar je vsekakor nič vredno za igre.
CPU je Intelov verjetno p4 na 2.4Ghz.
Zdaj, ko je konec šole zahtevaj za darilo malo boljši računalnik, 300-400 € in bo COD 2 letel.
zigc1996 ::
Time of this report: 7/17/2009, 12:36:41
Machine name: ZIGA-PC
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.090206-1316)
Language: English (Regional Setting: Slovenian)
System Manufacturer: Dell Computer Corporation
System Model: OptiPlex GX60
BIOS: Default System BIOS
Processor: Intel(R) Celeron(R) CPU 2.40GHz
Memory: 1022MB RAM
Page File: 572MB used, 1891MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
Memory: 1022MB RAM
DxDiag Notes
mihec91 ::
A bi tale call of duty delov na mojmu računalniku:
Racunalnik Intel
osnovna plošca ASUS P6T
procesor Intel Core i7 920 2.66GHZ
ram DD3 6GB 1333Mhz
grafika Ati HD 4890 1024Mb PCIe
disk 1TB WD SATAII 7200 rpm 32Mb
Napajalnik LC power 850W Silent
DVD RW NEC AD 7243S
Ohišje Antec Three Hundred
Najlepša hvala za pomoč :)
Racunalnik Intel
ram DD3 6GB 1333Mhz
DVD RW NEC AD 7243S
- spremenil: mihec91 ()
mihec91 ::
Racunalnik Intel
ram DD3 6GB 1333Mhz
DVD RW NEC AD 7243S
Racunalnik Intel
ram DD3 6GB 1333Mhz
DVD RW NEC AD 7243S
__Devil__ ::
Racunalnik Intel
ram DD3 6GB 1333Mhz
DVD RW NEC AD 7243S
Seveda bi delal. Kaj ti to resno al kaj? ker tak komp ni bil ravno poceni.
EDIT: Razen, če maš komp priklopljen na kaj takega: http://www.webtv.si/video/index/id/19687 .. 150 inchev!!!
Pol povej
- spremenil: __Devil__ ()
bajsibajsi ::
@zigc1998 Uff ravno tako kot sem predvideval. OptiPlex GX60 so vecinoma sloneli na 845 chipsetu z integriranimi Intelovimi graficnimi cipi, kar ni primerno za igranje COD2. Sam procesor Celeron 2GHz+ in 1GB rama bi zadostovalo, ce bi nabavil kaksno starejso AGP graficno kartico v rangu R9800 ali GF6800 za cca. 15 evrov. Problem je, da v DELL OptiPlexu vecinoma ni bilo plat, ki bi imele AGP rezo; pa tudi ohisja so bila naceloma vsa nizko lezeca.
Kaksen rabljen AMD2000+, giga rama z zgoraj omenjeno graficno kartico se dandanes dobi zelo ugodno, verjetno za nekaj 10 evrov. COD2 DX7 na takem sistemu z lahkoto leti na 60+ FPS.
st0jko ::
Racunalnik Intel
ram DD3 6GB 1333Mhz
DVD RW NEC AD 7243S
Lahko se zgodi da ne bo delal. Imaš preslabo ohišje.
Najbolje bo da probaš.
keks?
mihec91 ::
ne nisem se hotu pohvalt :) sam zanimal me je ker bo 64 bitna vista al ma to kej veze s špilam al ne ? pa kuko je kej s programi kot so adobe photoshop... azureus, nero, office,...????
Heavy ::
Vse ti bo delalo. Meni še Quake1 laufa na visti 64, ki nikakor ni hotel pod xpji.
| » | Kako narediti svoj server v Call of Duty 2 ?Oddelek: Igre | 9619 (3279) | deadzone |
| » | CoD Problemi (strani: 1 2 )Oddelek: Igre | 13131 (9104) | iloveboobz |
| » | Call of duty 2!ne dela server!problems!Oddelek: Igre | 6089 (4091) | ViperR |
| ⊘ | cod2 server problemi[pomoč please]- modem???Oddelek: Igre | 3023 (2949) | Mavrik |
| » | COD2 set dedicated 2Oddelek: Igre | 3951 (3806) | Mr.B |
