Forum » Navijanje » navijanje della
navijanje della
MecH ::
mam dell procesor intel celeron 2.40 ghz pa me zanima ce bi se ga dal navit.sm mal po drugih forumih gledu (ta mi je najbl usec) pa pravjo da se ne da navit k je tko narjen
procesor
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Celeron
Codename Northwood
Specification Intel(R) Celeron(R) CPU 2.40GHz
Package (platform ID) Socket 478 mPGA (0x2)
CPUID F.2.9
Extended CPUID F.2
Brand ID 10
Core Stepping D1
Technology 0.13 um
Core Speed 2394.2 MHz
Multiplier x FSB 24.0 x 99.8 MHz
Rated Bus speed 399.0 MHz
Stock frequency 2400 MHz
Instructions sets MMX, SSE, SSE2
L1 Data cache 8 KBytes, 4-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 128 KBytes, 2-way set associative, 64-byte line size
FID/VID Control no
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01001005h
Max CPUID level 00000002h
Max CPUID ext. level 80000004h
Cache descriptor Level 2, U, 128 KB, 1 thread(s)
Cache descriptor Level 1, T, 12 KB, 1 thread(s)
Cache descriptor Level 1, D, 8 KB, 1 thread(s)
CPUID
0x00000000 0x00000002 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000F29 0x0001080A 0x00004400 0xBFEBFBFF
0x00000002 0x665B5101 0x00000000 0x00000000 0x003B7040
0x80000000 0x80000004 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00000000
0x80000002 0x20202020 0x20202020 0x20202020 0x20202020
0x80000003 0x65746E49 0x2952286C 0x6C654320 0x6E6F7265
0x80000004 0x20295228 0x20555043 0x30342E32 0x007A4847
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x00000017 0x000A0000 0x00000000
MSR 0x0000002C 0x00000000 0x18100018
MSR 0x000001A0 0x00000000 0x00000089
maticna
0FG015 (0x00000153 - 0x005028A0)
Northbridge Intel i865P/PE/G/i848P rev. A2
Southbridge Intel 82801EB (ICH5) rev. 02
Graphic Interface AGP
AGP Revision 3.0
AGP Transfer Rate 8x
AGP SBA supported, enabled
Memory Type DDR
Memory Size 512 MBytes
Channels Dual
Memory Frequency 133.0 MHz (3:4)
CAS# latency (CL) 2.0
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 6
Performance Mode enabled
MCHBAR I/O Base address 0x0FECF0000
MCHBAR I/O Size 256
MCHBAR registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 08 08 08 08 08 08 00 00 00 00 00 00 00 00
10 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 25 12 20 17 C6 42 14 00 71 62 30 20 81 83 13 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 48 10 00 00 04 04 01 00 04 04 01 00 28 08 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
js se u to glih ne zastop kej velik tko da nasveti so dobrodosli!!!
procesor
Processor 1 ID = 0
Name Intel Celeron
Codename Northwood
CPUID F.2.9
Extended CPUID F.2
Brand ID 10
Core Stepping D1
Technology 0.13 um
FID/VID Control no
CPU Thread 0
APIC ID 0
Type 01001005h
CPUID
maticna
AGP Revision 3.0
Memory Type DDR
Channels Dual
Cycle Time (tRAS) 6
MCHBAR I/O Size 256
MCHBAR registers
Xserces ::
težka ja... ce mas mogoce intel plato loh pozabs na navijanje...
Poglej kir clock generator ma plata in potem poglej če ga podpira setfsb, potem lahko malo naviješ.
Pyr0Beast ::
Bsel mod.
zee ::
Upam, da se zavedaš, da četudi ga naviješ na 3 GHz, bo to še vedno zelo slab procesor.
zee
MecH ::
ja to itak sam k mam ze tko cis krs pa sm mislu da bi ga usaj izbolsu da bi kej bol delu tko pa k mam intel plato to odpade
hval za pomoc
hval za pomoc
| » | BSOD 0x00000124Oddelek: Pomoč in nasveti | 2005 (1446) | s1m0n |
| » | BSOD me spravlja v obupOddelek: Strojna oprema | 2348 (1820) | rsroki |
| » | BSOD problemOddelek: Pomoč in nasveti | 2249 (1907) | Oktan |
| » | Windows XP težave...Oddelek: Operacijski sistemi | 2360 (2226) | edey |
| » | xserver-xree86Oddelek: Operacijski sistemi | 1884 (1796) | Skrat |
