Forum » Loža » Primer brainwasha s strani slovenske politike in državnih institucij
kivi113 ::
Na strani piše, da je trava nevarna kot 20 čikov.
http://www.rtvslo.si/zdravje/marihuana-...
Na linku raziskave piše, da je nevarna toliko kot 2,5 - 5 čikov:
http://www.mrinz.ac.nz/Alcohol_drug_abu...
1. The respiratory effects of marijuana smoking
This study utilised the latest advances in CT scanning technology and respiratory physiology testing to determine the effects of cannabis smoking on pulmonary structure, function and symptoms. It identified that cannabis smoking had profound effects on the lung, causing symptoms such as cough, wheezing and chest tightness, and airways obstruction resulting in hyperinflation, and reduced lung density. For the first time, the dose equivalence between cannabis and cigarettes in causing lung damage was determined. This analysis identified that one cannabis joint had similar adverse effects on the lung as between 2.5 and 5 tobacco cigarettes. This finding has major public health significance.
Ali nekdo ne zna prepisati podatkov? Jaz mislim, da so razlogi drugi.
Kaj pa tisto o zdravljenju s kemoterapijo. Malo pogooglajte, npr. chemotherapy success rate, pridemo do rezultatov med 2% in 10%..?!?!
Opinions makers, tale bo težka.
- spremenil: kivi113 ()
KoMar- ::
Raziskav je veliko, vsaka stran pa objavi tiste številke, ki ji bolj ustrezajo - ni logično?
Sicer pa si poglej še, koliko ljudi pristane na psihiatriji zaradi trave napram čikov
PaX_MaN ::
PaX MaN,
wat?
Iz polinkane strani "raziskave":
64 subjects
Iz razširjene novice v Žurnalu(ki je polinkana, čeprav napak, med komentarji na RTVSLO):
79 bolnikov
kivi113 ::
Komar: ja čikarji večinoma tam okoli 50. leta pristanejo na onkološkem inštitutu. Tam jih potem nafilajo z drago kemoterapijo s šanso uspešnosti 2.5-10% (po googlu). Tam jih tolko časa mozgajo z dragimi "zdravili", da se pač denar sterilno odteče v žepe ... koga že? Me zanima statistika ozdravljenih s kemoterapijami, ki živijo vsaj še 10 let, v Sloveniji. Tega podatka verjetno ni mogoče dobiti. :)
"Sicer pa si poglej še, koliko ljudi pristane na psihiatriji zaradi trave napram čikov" - verjetno gre velik del teh ljudi najprej še čez prohibicijski aparat. No, pa Bill Gates, Steve Jobs, Woody Harleson, Bill Clinton, Barrack Obama, Michael Phelps, ... , tudi niso na psihiatriji v tem momentu :)
Pax_man:
Richard Beasley is the Director of the Medical Research Institute of New Zealand (iz tvojega linka na žurnalu). Moj link je prav tako do Medical Research Institute of New Zealand. Se pravi, da gre za istega človeka oz najverjetneje isto raziskavo, le da so malo številke med sabo premešali? Ali pa so jo po tvoje 2x delali, pa so dobili tako različne rezultate, s tem, da na strani še vedno piše, da je škoda 2,5-5x.
Sicer je pa Nova Zelandija baje zelo restriktivna glede drog, da lažje uvoziš ilegalca ko pa kako neznano sadje .. :)
Pax_man:
imagodei ::
@PaX MaN,
kje pa je OP v svojem sporočilu "zgrešil" napako pri prepisovanju?
- Hoc est qui sumus -
| » | Bi namesto gledanja oglasov donirali procesorski čas?Oddelek: Novice / Kriptovalute | 14843 (10954) | blackbfm |
| » | Zakaj ni konoplja legalizirana? (strani: 1 2 3 4 5 )Oddelek: Problemi človeštva | 60793 (49062) | jype |
| » | Prestop meje mlajši od 16 letOddelek: Loža | 4214 (3947) | Marilyn |
| » | koliko zaracunatiOddelek: Zvok in slika | 1438 (1349) | marko20 |
| » | PHP TečajOddelek: Pomoč in nasveti | 1514 (1245) | blackbfm |
