Mini ninja
Mini ninja
mravla ::
zanima me kako se da premagati glavnega bossa na koncu?
ima nekaksne krogle leteče okoli sebe in ne moreš do njega. v pomoči piše da ga lahko premagaš samo z magijo.
vendar nikakor ne morem ugotoviti kako se da to rešiti.
hvala
če ga poženeš, bo letel
Matej_K ::
stand in front of a ball and throw a shuriken at ashida, he bounces it back off his sheild and it will be glowing, either dodge behind the pillar, or time a jump so the glowing shuriken hits the ball and shatters it, you will also have his minions to deal with. try to break the ball before it lights up as thats when he sends his minions on you. its a lengthy process. when the balls are destroyed run to ashida and attack, then he regenrates the balls after so many attacks and its done all over again. keep at it till he's dead!!
NE POGLEJ VSEGA, KER POTEM TI NEBO ZANIMIVO GA PREMAGAT...
  • spremenil: Matej_K ()
Kitajska pokazala prenos s kvantno prepletenostjo na razdalji 1200 kilometrov (strani: 1 2 3 4 )
18161572 (54979) FrRoSt
NBA 2K14
Oddelek: Igre
303087 (2283) Kurzweil
HTC HD mini, Legend, Desire
Oddelek: Mobilne tehnologije
4511107 (7990) LuGi
Glasbeni izrazi v angleščini
Oddelek: Sedem umetnosti
177355 (6969) embe
ali mi lahko nekdo razloži par vicev
243698 (2902) Yohan del Sud
