Windows XP repair
Windows XP repair
kmetek ::
Kaj že moraš narediti, ko ti ne boota Windowse v stilu c:\windows\sytem\command
nekaj v tem stilu....svetuje pa R repair ta del vem, da prideš v console, kaj tam napišeš?
10x
tole javi \WINDOWS\SYSTEM32\CONFIG\SYSTEM
  • spremenil: kmetek ()
kmetek ::
nihče? :P
zdaj sem dal chkdsk/p in chkdsk/r....
SomeOneNew ::
To kar si do sedaj napisal nima ne repa ne glave.
Najprej povej v čem je sploh problem? Kakšno napako dobiš ob zagonu računalnika da se polkna ne naložijo?
kmetek ::
kmetek ::
Ma ne vem nekaj čudnega je danes, ok gremo od začetka.
Pred dnevi sem iz 640gb kloniral vsebino na 1tb hitrejši disk. Komplet vse.
In danes sem dodal še 2tb samsung disk, nato se je pojavil tale Error message WINDOWS/SYSTEM32/CONFIG/SYSTEM on Windows startup.
Ok, naredil sem tole:
"You need to get a Windows XP from someone and follow these instructions:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD.
2. At the first R=Repair option, press the R key
3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4. Enter in the administrator password when requested
5. cd \windows\system32\config
6. Depending on which section was corrupted:
ren software software.bad or ren system system.bad
7. Depending on which section was corrupted
copy \windows\repair\system
copy \windows\repair\software
8. Take out the CD ROM and type exit
If that doesn't work or you can't get into the repair console then With the XP disk you choose to install Windows XP and when you choose to install over the current XP installation you will be given the option to repair the current Windows installation and you won't lose all of your data. "
Naredil točki 6 in 7....zdaj pa se boota v windowse počasneje kot prej, zakaj? Nalaga zelo dolgo.
kmetek ::
a mislite če bi skopiral ta delujoči system file iz 640gb na 1tb, da bi delovalo?
zavajon ::
Jaz bi na tvojem mestu najprej preveril v BIOSu, katrei disk vzame za bootanje in po potrebi ustrezno nastavil.
Če pa želiš preveriti, ali je tvoj sistemski disk res bootable, izklopi vse ostale diske.
kmetek ::
Sej do danes zjutraj je 1TB deloval čisto ok, to mi je čudno.
na levi 1tb disk, kjer vidite na novo system in system.bad.....zdej, ko sem to naredil ga biksa - saj je tudi manjši?
Kaj sploh je ta file, kdo vse?
Hvala.
LuGi ::
Offtopic;(:
Verjetno bi manj časa porabil če bi iz starta naredil sveži inštal :|
Sicer pa no idea.
kmetek ::
Ja vem, samo imam res ogromno stvari gor itd...Zaenkrat sem skopiral z mozbackup profile firefoxa in vsa gesla itd.....
Obstaja še kaj za OUTLOOK itd? sem že skopiral obe .pst datoteki pa je...archive in outlook.
kmetek ::
Kaj sem naredil: priklopil nazaj 640gb, skopiral iz mape System Volume Information te fajle:
DEFAULT
SECURITY
SOFTWARE
SYSTEM
SAM
# Kliknite z desno in izberite View (Pogled) in Details (Podrobnosti), da boste videli datum ter izberite mapo, ki je bila narejena pred sesutjem! V njej se namreč skrivajo nastavitve
# Poiščite mapo Snapshot in kopirajte naslednje datoteke v mapo C:\Windows\Temp\ ali drugo poljubno mapo, v spodnji točki, boste seveda morali pot do mape ustrezno spremeniti
sej to je v bistvu system restore a ne?
samo zdej mi boota nenormalno dolgo, tudi 5 minut...kaj narediti?
fosil ::
To kopiranje datotek ni kompleten sistem restore.
Če si prišel v winse naredi še system restore.
Opis celotnega postopka klik
Tako je!
kmetek ::
Ja samo ko zaženem system restore, mi error vrže :|
fosil ::
Ja vidim da si te fajle kopiral z drugega diska.
Naredi tako kot piše v linku in jih kopiraj od tam kjer piše.
Tako je!
solatko ::
Naredi sliko 640 diska, potem pa restore slike na 1 ali 2T disk. Pol urce dela.
Kr tko disk kopirat na drug disk, ne gre, ker windows xp to ne dovolijo.
  • spremenil: solatko ()
kmetek ::
ja bom zdej bootal iz 640, pobral uporabno robo iz 1tb, skopiral kar se da , ter naredil restore sliko na 1tb...pomoje je to edina rešitev.
hvala vsem.
SomeOneNew ::
Kaj pa če bi sprobal najprej repair od Windowsov? In s tem ne mislim repair konzole temveč ponovna namestitev samo sistemskih datotek (programi in tvoji dokumenti ostanejo nedotaknjeni).
Windows Repair
kmetek ::
a da bi samo xpje čez namestil?
solatko ::
Repair ne deluje na drugem disku. XP-ja ne moreš kar prekopirat na drug disk in bo delovalo. Tko ne gre, gre samo z restore, narejene slike sistema s kakšnim, za to namenjenim programom. Jaz sem za ta opravila kupil ACRONIS TRUE IMAGE, drugi pa pač to delajo z drugimi programi. Če hočeš brez tega, brez nove instalacije ne bo šlo, imaš pa na MS strani navodila, kako to narediš. Je pa vse bolj komplicirano, kot prenos slike.
kmetek ::
Ma ne sej bom pač preživel
zdaj imam aktivnega predhodnika 640gb (hvala bogu, da ga še nisem prodal) in bom medtem z 1tb pač vse skopiral itd....
pa na novo naredil clone z True Image na 1tb....potem pa upajmo, da bo mir.
Ne vem, zakaj je sploh do napake prišlo, delalo 2 tedna oK.
Windows XP - lsass.exe
Oddelek: Operacijski sistemi
93237 (2053) Rauf
Problem pri prižganju računalnik
241620 (1395) Jernej88_
Win. could not start...... wtf. \windows\system32\config\system
82820 (2733) Tovaris Stalin
Windows XP - težave z zagonom
63170 (3012) SebaR
Kako obdržati linke do aplikacij, register in ostalo, ko reinštaliraš WinXP???
131964 (1712) Lith
