Forum » Kaj kupiti » Nov računalnik
Nov računalnik
janezek67 ::
* Microsoft Windows
o Windows XP
+ with Service Pack 3 or Higher
o Vista Home Premium, Business, Ultimate, or Enterprise
+ with Service Pack 1 (Service Pack 2 recommended)
o Windows 7
o 64-bit Vista or Windows 7 required for Adobe Premier Pro CS5 and After Effects CS5
* Intel
o Pentium 4 or AMD Athlon 64 processor
+ (Intel Core 2 Duo or AMD Phenom ll processor recommended)
+ Intel Core 2 Duo or AMD Phenom ll required for Adobe Premier Pro CS5
+ Processor with 64-bit support required for Adobe Premier Pro CS5 and After Effects CS5
* RAM
o 2 GB RAM (4 GB or more recommended)
* Hard Disk Space
o 24.3 GB of available hard disk space for installation
+ additional free hard disk space required during installation
+ cannot install on flash-based storage devices
o 7200 RPM hard drive for editing compressed video formats
+ RAID 0 for uncompressed
* Video
o Color monitor with 16-bit or greater video card
o 1.280 x 900 (1280 x 1024 recommended) monitor resolution
+ with qualified hardware-accelerated OpenGL graphics card
o Adobe Certified GPU card for GPU-accelerated performance in Adobe Premier Pro CS5
+ Visit www.adobe.com/go/premiere_systemreqs for the latest list of supported cards
o 256 MB Video RAM
o Some GPU-accelerated features in Photoshop CS5 require Shader Model 3.0 and OpenGL 2.0
o Some features in Adobe Bridge require rely on a DirectX 9-capable graphics card with at least 64 MB of VRAM
o Adobe Certified card for capture and export to tape for SD/HD workflows
* OHCI-compatible IEEE 1394 port for DV and HDFV capture, export to tape, and transmit to DV device
* Sound card compatible with ASIO protocol or Microsoft Windows Drive Model
* DVD-ROM drive
o DVD+R burner for burning DVDs
o Blu-ray burner for creating Blu-ray Disc media
* Java Runtime Environment 1.6 (included)
* Quicktime 7.6.2 software required for Quicktime and multimedia features
* Adobe Flash Player 10 software required to export SWF files and to play back DVD projects exported as SWF files
* Broadband Internet connection required for online services
Tole so zahteve za Adobe. Kot vidim, je pomembno predvsem, da imaš za hude efekte Raid0 (se pravi dva hitra diska), vsaj 4 GB Rama in očitno 64 bitni operacijski sistem. Očitno tale adobe dela na Open GL knjižnici, tako da mislim da to Ati tudi dobro podpira.
o Windows XP
o Windows 7
* Intel
* RAM
* Hard Disk Space
* Video
o 256 MB Video RAM
* DVD-ROM drive
Nightcrawler ::
Vsi dam s HP-ji AOC-ji, Toshibam ipd... Bo metal plave zaslone pa nobenmu serviserju ne bo jasno kaj je narobe. Sem bil sam na nekem Anni gamerju, ja nikol ni delal. Če hočeš kvaliteto je to Apple oz. najmanj Dell.
Razen če nisi dovolj bogat, da lahko kupiš dvakrat, drugače pa najmanj Dell!
duky25 ::
Sam ti predlagam ta racunalnik,ki ga uporabljam sam in sem zelo zadovolen!
Kupil sem ga pri agt.si kjer ti ga sestavijo in testirajo zastonj!
Ohisje:Cooler Master Centurion 690 - 72,84€
Napajalnik:Antec TruePower NEW 750 - 120,13 €
Maticna plosca:Gigabyte GA-P55A-UD3 - 127,79 €
Procesor:Intel i5 750 - 188,33 €
Spomin:Mushkin PC3-12800 "Essential" KIT 4096 MB, DDR III, 1600 MHz - 118,38 €
Graficna kartica:Gigabyte Radeon HD 5850 - 282,49 €
Trdi disk:Western Digital WD6401AALS "Caviar Black™"
640 GB, Serial ATA II, 32 MB - 66,45
Oticna enota:Samsung SH-S223C BEBE - 22,87 €
Operaciski sistem:Microsoft Windows 7 Professional SLO DSP - 138,56 €
vse skupaj te pride:1.137,84€
Tako da bos imel mir najmanj 2leti,kar se tice igranja igric,zato 750W napajalnik,ce bo potrebno kakrsna koli nadgradnja racunalnika ali graficne kartice!
Ohisje je dovolj hlajeno imas ze vgrajene 3vent moznost do 7vent,tako da ne bo nobenih velikih temperatur!
Pri igranju,kot so Gta4,Css,Bordelands,Residet evil... Vse na high resoluciji se kartica ne segreje,vec kot 65C!
Kar se tice Nivade in Radeon sem gledal teste in Radeon prekasa vse Nivada kartice,tako da kar se tice Nivade denar vrzen stran,ter kartice so zelo pozresne in glasne!
Kar se tice procesorja bo i5 750 vec kot super samo da je 4 jederni da lahko delas vec stvari na enkrat in v igranju se zelo obnese tako da ni potrebno kupovanje i7 verzije!
Tako da po 2-3letih samo dokupis graficno kartico,ker imas moznost CrossFireX ™ in bos imel mir se za 2leti!
Ps.seveda je odlocitev tvoja!
- spremenil: duky25 ()
IvoJan ::
ja kaj je pa s tabo?? a si sploh prebral za kaj bo on uporabljal ta racunalnik??
duky25 ::
se opravicujem pol nisem prebral prve strani!
pol bo ta konfigiracija dovolj!
ohisje:Antec Three Hundred - 49,77 €
napajalnik1:Antec TruePower NEW 750 - 120,13 €
maticna:ASUS P7P55D - 115,69 €
procesor:IntelŸ i5 750 - 188,33
spomin:Mushkin PC3-12800 "Essential" KIT 4096 MB, DDR III, 1600 MHz X2 - 236,76 €
trdi disk:Western Digital WD1001FALS "CaviarŸ Black™" 1000 GB, Serial ATA II, 32 MB - 88,78 €
oticna enota:Samsung SH-S222H BEBE - 24,21 €
operaciski sistem:Microsoft Windows 7 Professional SLO DSP - 138,56 €
skupaj:962,23€
ceprav nevem zakaj tok rama pa tak mocen napajalnik?
drugace pa si poglej pri AGT.si si ga lohka sestavis po zelji!
skupaj:962,23€
Se vidi, da razen igračkanja ne veš, kaj početi na računalniku.
duky25 ::
takse neumne komenta prosim da zadrzite zase!
ce se ne motim je ta oseba iskala pomoc tako da ker ste tako pametni da cez mene nekaj govorite mu raje svetujte!
tako da idiotskih komentarjev ne potrebujemo!
hvala lepa!
hvala lepa!
IvoJan ::
srsly.. ce je tebi tak pro setup sestavil pa povej kere komponente mas pa da vidimo koliko se razlikuje od tega kar smo mu mi sestavili...
| » | Nakup računalnika do 1500€ (strani: 1 2 3 )Oddelek: Kaj kupiti | 27050 (24319) | Pr0xim0 |
| » | Namizni računalnik za odbelavo video-audio (strani: 1 2 3 )Oddelek: Kaj kupiti | 17421 (15901) | fuzia |
| » | Računalnik do 1700€ (strani: 1 2 )Oddelek: Kaj kupiti | 13577 (12361) | Pipi Castro |
| » | PC za grafično delo?Oddelek: Kaj kupiti | 3027 (2422) | Opkow |
| » | Nov i7 sistem - najboljše za najmanj denarja (strani: 1 2 3 )Oddelek: Kaj kupiti | 13667 (10207) | paps |
