Delovanje ratio masterja
MattPwnz ::
LP!
Hodim v 2. letnik računalniške srednje šole in pripravljam referat o delovanju tega programa (ratio master) Za tiste ki tega ne poznate --> je program z FAKE upload na trackerjih. Prvo moram povedati da NE vzpodbujam piratstva ali hackanja na tem forumu, prosim vas le za pomoč, da mi nekdo ki ta program mogoče pozna in ve kako deluje, da mi razloži KAKO program deluje, da mu uspe prepričati tracker, da deluje kot Bittorrent itd.
Iz ratio masterjeve uradne strani mi je uspelo dobiti informacijo ki je pa žal v angleščini in je ne zastopim v celoti. Referat pa seveda mora biti v slovenščini. Tako da bi prosil če mi lahko kdo prevede tole v slovenščino:
RatioMaster has hardcoded emulations for the most commonly used BitTorrent clients,
but it is also able to parse external files for emulation settings, thus making it easily
extensible for your favorite client and easy to update when new versions of said clients
are released. The client files (extension “.client”) are actually renamed XML files and
the syntax should be pretty straight-forward. The emulation layer includes support for
parameter order in GETs, reproduction of HTTP headers, generation of application-specific
peer_ids and keys and more. RatioMaster can also parse the tracker reannounce time from
the tracker’s HTTP response, and combined with the fact that you can specify down and
up rates makes it pretty hard to detect by any anti-cheat scripts, if not downright
impossible. Other features, like a TCP listener (so as to appear connectable on the
tracker’s peerlist) and a leecher counter (so as to stop any uploads when a torrent
has 0 leechers) also contribute to RatioMaster’s spoofing abilities
Res najlepša hvala za pomoč vnaprej!
t3hn0 ::
Na kratko:
tvoj torrent program ti med downloadanjem/uploadanjem posilja podatke o tem koliko si zloadal/uploadal nazaj na tracker, da le-ta vodi statistiko. To se posilja preko HTML z GET metodo (to lahko tudi opazujes s kaksnim programckom).
Ratio master pa posnema torrent program, s tem da le posilja podatke "koliko je zloadal", brez da bi dejansko kaj zloadal/uploadal.
MattPwnz ::
hvala za tvoj odgovor. Ampak mene bolj zanima NA KAKŠEN NAČIN, programu uspe prelisičiti tracker in mu dati FAKE podatke?
overlord_tm ::
Pac posilja podatke da uploadas ceprav ne uploadas. Sej server ne gre potem gledati ce so ostali res downloadali od tebe.
RatioMaster ni glih neki s čimer bi se dal z lahkoto nardit referat :P
[P2P] BitTorrent - Naslednja generacija P2P (strani: 1 2 3 4 … 36 37 38 39 )
Oddelek: Omrežja in internet
1904541052 (2323) karafeka
PartiS in utorrent
2928470 (19927) T-h-o-r
Ratio master
Oddelek: Programska oprema
146863 (6270) givos
uTorrent problemi
213386 (2984) alexz
