Forum » Igre » Prince of Persia: The Forgotten Sands
Rotaidal ::
This new game marks the return to the Prince of PersiaŸ Sands of Time storyline. Prince of Persia: The Forgotten Sands™ will feature many of the fan-favorite elements from the original series as well as new gameplay innovations that gamers have come to expect from Prince of Persia.
Experience the story, setting, and gameplay return to the Sands of Time universe as we follow the original Prince of Persia through a new untold chapter.
Over 2 years in the making and created by Ubisoft Montreal, the team that brought you past Prince of Persia and Assassin’s Creed games.
Play the epic story of the heroic Prince as he fights and outwits his enemies in order to save his kingdom.
http://prince-of-persia.uk.ubi.com/
Release date: EU May 20, 2010
Izide pa na vseh platformah.
FeniksX ::
Opa to mi deli, Sands of time zgodba je najbolša, ta zadnja izdaja princa je bla mi kr neki :P
Bor H ::
Me kr matra tole, je pa izdelava v teku bila že pred izdajo POP4, verjamem da nas ubi uspe letos presenetit z novim Princom, Sam Fisherjem in Ghost Recon squadom :)
destroyer2k ::
tt2
Ah nakoncu bo se zgodilo to, kar trdijo da ni res.
Game based on movie witch the movie is based on game.
Berserker ::
Za vsak primer se pripravite na razočaranje, edina igra ki je bila vredi po filmu je king kong( izpod ubisofta na srečo), ampak lahko se zgodi presenečenje.
Moram rečt da mi je bil Wariorr within najboljši del z temačnim vzdušjem, brutalnimi prijemi in napadi nad sovragi, bežanje pred dahako in tehno-arabskimi ritmi in dobro zgodbo, pa tudi sam princ mi je v WW izgledal najboljše, temačen, resen.
Berserker ::
Dejansko sem zelo vesel, da se bo Princ vsaj oblikovno (okostnjaki, itn.) vrnil k drugemu delu serije (originalne, da se razumemo):
Prince of persia 2: The shadow & the flame
http://www.abandonia.com/sl/games/15089...
- spremenil: opeter ()
Tr0n ::
Bor H ::
Tale prince po prvih posnetih igranja zgleda totalno kul, ubistvu Sands of Time z nekaj dodanimi triki (manipulacija z vodo, mmmm...)
Berserker ::
Ja okolje je podobno kot pri Sands of Time , lik je na srečo podoben onemu iz Warior withina , ravno prava kombinacija + engine( scimitari ?) ki zna lepo izrisavat objekte daleč stran kot pri assasin credu ko se povzpeš na stolp. Upam da nebo borilni sistem zaradi armade sovragov poenostavljen, pri WW si imel lepo izbiro tehnik razsekavanja in usmrtitev ki so kar presenečale.
3ja3ka3 ::
Kupil oziroma zadel sem pričakovano Prince of Persia The Forgotten Sands ... ko sem že čisto vesel skakal ko se je zaganjala pa mi je napisalo da rabim internet :@ in ga imam in to zelo dobro povezavo . Kaj je narobe prosim naj kdo pove če ve.
Hvala
Hvala
Bor H ::
Tale Princ uporablja novo zaščito od Ubisofta, ki zahteva da si nonstop na netu. Poglej če ti kak firewall blokira setup.
3ja3ka3 ::
Vem tale DRM mi gre že pošteno na živce...inštalacija je potekala nemoteno ko pa zaženem igro mi reče:
"An Internet connection is required to play this game. Failed to connect to the Ubisoft master servers. Please verify that your Internet connection is functional and try again."
Nevem kaj bi lahko bilo narobe, razen...zraven sem dobil keycode vendar mi nikoli ni pokazalo okenca ki jo zahteva ali pa kaj podobnega...
Lp Jaka
Lp Jaka
Tomozuki ::
Film je bil vbistvu narejen po Sands of Time, če se primerja zgodba. Je zelo podobna, le imena krajev in likov se razlikujejo. Meni je bil od vseh najboljši ravno ta SOT, ker je bil res tak pravljičen. Z Warrior Whithin so me pa malo razočarali. Preveč neka darkerska scena za Perzijo... Ostali deli so bili tudi vredu.
Berserker ::
Čudno, meni je pa bil v WW sam princ najboljši zaradi te temačnosti, zagrenjenosti, resnosti, v prvem delu si bil bolj kot ne street kid, do trojke pa postaneš bolj kot ne veteran akrobacije. Pa tudi sam borilni sistem je bil dober z razčetverjenjem, beg pred dahako, če prvič igraš ti je bolj kot ne wtf vse skupaj. Če bi delali skozi na teh pravljičnih delih kot je prvi in tretji del bi dobili nekakšno avanturo z lahko zgodbo, drugi del pa je vnesel malo resnobe, no tako si vsaj jaz predstavljam. Nov princ je tudi pravljičen ampak je bolj kot ne vse plehko načičkano.
- spremenil: Berserker ()
Bor H ::
škoda samo, da imajo starejši princi probleme z dual core procesorji, bi z veseljem še kdaj preigral
Bor H ::
Laufa pri polnih FPSih (če maš LCD + vsync je to 60) ampak se zadeva predvaja kot v počasnem posnetku, včasih je težava rešljiva da mu v task managerju daš affinity samo na en procesor, včasih amdjev overdrive (al neki podobnega) dostkrat pa nič, jst osebno se še ubadam da bi ga zagnal preko wina v linuxu
wolverine22 ::
pri meni so se pri vseh 3 delih pohitreno predvajale vse video sekvence in ko sem se hotel spustiti s kake policke je princ kar potrzaval v zraku...ampak potem sem vklopil vsync in je bilo vse normalno. Procesor i5...pa mislim da je bilo isto tudi pri E8400.
Bor H ::
kot rečeno, odvisno od sistema, ampak praviloma so problemi z multicore zadevami, čist možno da je pa to vezano na prve generacije takih procesorjev in so zdj že kej spremenil
adolf ::
rabil bi pomoč:)
tale zadnji princ je dober, samo nekako ne morem iz ene določene sobe
pa ne vem al ne znam al je software napaka?????????
Marilyn ::
rabil bi pomoč:)
se mi je zgodilo že ja!..ampak sem imel pi_ra_t*k_o verzijo...poglej da imaš zadnji patch...vrata se mi niso hotela odpret, kljub temu, da sem postopal pravilno..sem skakal ko zmešan okrog, in razmišljal kaj delam narobe
- spremenilo: Marilyn ()
adolf ::
ja točno tako se je zgodilo, pridem z novim mečem, kao v palačo, pobijem vse vrata šklocajo, a zgodi se nič :(
a mi lahko pomagaš mogoče s kako bližnjico, da nebom zadel kam v temo :)
tnx
tnx
Marilyn ::
joj fantina, to igro sem igral že dolgo časa nazaj, tako, da točno kaj narediti, ti neznam povedat
..upam, pa da si razumel moj namig malo prej
Marilyn ::
vem, pa da sem samo slišal vrata kako "šklocajo" ja, kot si rekel...pa se niso premikala..pa me je delalo nervoznega...prosim obvesti me, če sem pomagal
g. Razor je takrat hitel z patchom, tako, da so se potem dogajale napake...izgubljal sem živce in pa čas...na srečo sem šel za vsak slučaj preverit ali mogoče obstaja popravek in wuooola...popravek patcha je bil tukaj
adolf ::
pozdravljen!
obrnil sem cel net, pa nisem imel sreče pri iskanju patcha :(
vse kar najdem je 1.0 verzija
Kupi original, saj ni tako drag:
http://www.zavvi.com/games/platforms/pc...
Saj ti ni treba. Shraniš svoj profil oz. savegame nekam v drugo mapo, potem pa igraš od tiste točke naprej.
http://in.answers.yahoo.com/question/in...
| » | Assassin's Creed Valhalla (2020) (strani: 1 2 3 4 5 6 )Oddelek: Igre | 58340 (23573) | Kvinta |
| » | UPLAY AKCIJE PO 1€Oddelek: Igre | 1745 (981) | dottor |
| » | igre kot darksidersOddelek: Igre | 1775 (1677) | MecH |
| » | Prince of Persia: Next Gen (strani: 1 2 )Oddelek: Igre | 7776 (5386) | laught |
| » | FarCry brezplačno (strani: 1 2 3 )Oddelek: Novice / Igre | 19600 (12727) | R33D3M33R |
