Forum » Pomoč in nasveti » Nadgradnja BIOSA !?!
Nocko ::
LP!
Imam eno vprašanje in upam da mi bo kdo znal pomagati!
Rad bi nadgradil bios od ABIT SA6R osnovne plošče.Tega še nisem nikdar počel,zato me zanima, na kaj moram pazit,ker baje da se da veliko stvari uničiti,itd.,...
Pa me zanima če mi lahko kdo pomaga pri tem,..
Aja plošča ma tud RAID!!!
Hvala za vašo pomoč.
@Nocko
@Nocko
shark16 ::
1. How to upgrade BIOS:
a. Boot into MS-DOS or "Safe mode and command prompt" if you are using
Windows95/98
b. Run "kg768.exe" to extract all files.
c. Run "runme.bat"
*** Please notice that we suggest you flashing the bios with switches
"/py /sn /cd /cp /cc /cks /R" or by "runme.bat".
d. For more detail, please visit:
http://fae.abit.com.tw/eng/download/bio... (English)
2.After BIOS updated, pull off the power core and then clear the CMOS data
via jumper before restarting system please.
Windows95/98
c. Run "runme.bat"
Nocko ::
THX ZA TE INFORMACIJE!
EVO GA TU JELINK ZA MOJO PLOŠČO:
ZAJ PA ME ZANIMA NASLEDNJE, PREDZADNJI UPDATE OD 2001 PODPIRA DO 1.1 PROCESORE,ZA NOVEJSEGA 2002 PA PIŠE ŠE NEKAJ DRUGEGE,PA ME ZANIMA,ČE TA ZADNJI UPDATI PODPRIRAJO VSE OSTALE STVARI,KI JIH PONUJAJO STAREJŠI UPDATI,ALIMORAM VSAKO STVAR NA NOVO UPDATAT!?!
| » | Update BIOSOddelek: Pomoč in nasveti | 1302 (1256) | ali3n |
| » | Flashanje Biosa na ABIT ploščiOddelek: Pomoč in nasveti | 1713 (1626) | smilyxx |
| » | Problem z navitim celeronomOddelek: Navijanje | 1072 (947) | ru7 |
| » | Pomoč z HPT370 UDMA/ATA 100 RAID ControllerOddelek: Pomoč in nasveti | 2999 (2906) | Nocko |
| » | IBM deskstar 40GB - Bios UpgradeOddelek: Strojna oprema | 1803 (1506) | Sponka |
