Problem z Winsi
Problem z Winsi
markk1 ::
imam sledeči problem. ko se hočem prijaviti v windowse pod uporabnik se mi med prijavljanjem odjavi. podobno se mi dogaja ko se hočem loginat v safe mode načinu pod administrator. pozna kdo rešitev?
hvala
Pozdravljen, imel sem isti problem pri Windows XP, meni je pomagalo edino formatiranje.
Ali pa poskusi spodnji postopek:
There has been some morphing of the BlazeFind malware. Here is a second approach to making the computer bootable:
(from the LavaSoft forum)
First things first get to recovery console.
At recovery console, we need to replace the software hive with a previous good backup. It should look something like this:
C:\windows>cd system32\config
C:\windows\system32\config>ren software software.old
This renames the current software hive to software.old
C:\windows\system32\config>copy C:\windows\repair\software
It should say "1 file(s) copied"
NOTE: After the next step you will want to remove the cd, then boot into safe mode. If you do not boot into safe mode in Windows XP it may prompt you to reactivate and you may not be able to get into Windows.
C:\windows\system32\config>exit
Now hit the F8 key and boot into safe mode. Logon to the administrator account when you reach the welcome screen. Hopefully you will be able to logon.
Now we need to edit your old registry to change the path to the userinit.exe file:
open regedit.exe
Highlight HKEY_LOCAL_MACHINE (note: this is important, if you do not highlight this the next step will not work)
goto file - load hive...
Now select your old registry file which should be in C:\windows\system32\config\software.old
It will ask you what to name it, if you don't understand, just type "test".
Now navigate to the following:
HKEY_LOCAL_MACHINE\ - what your named this in the previous step - \microsoft\windows nt\currentversion\winlogon.
Look at what the userinit value is. On my customer's machine it was %system32%\userinit.exe which is invalid.
NOTE: If you can, post what your value is when you look at this.
Next change the value to read C:\windows\system32\userinit.exe
Now close the registry editor, and we need to go back to recovery console to put your original registry back which should look like this:
C:\windows\system32\config>del software
C:\windows\system32\config>ren software.old software
This (in theory) should get you back into Windows.
Več preberi tukaj: http://www.tek-tips.com/viewthread.cfm?...
nUUb ::
Če si slučajno kakšen nezanesljiv .exe kliknil, se je tudi men zgodilo, da sem naletel na virus ki je spremenil administratorsko geslo ter po prijavi v svoj račun odjavil in je pomagalo le formatiranje in še prej backup podatkov v drugem računalniku
Windows XP - lsass.exe
Oddelek: Operacijski sistemi
93223 (2039) Rauf
Problem z odpiranjem spletnih strani, setup datotekami...
254552 (4341) Tac20
Windowsi se mi ne zaženejo????
Oddelek: Programska oprema
312037 (1638) sonceeek
Win. could not start...... wtf. \windows\system32\config\system
82806 (2719) Tovaris Stalin
Windows XP - težave z zagonom
63161 (3003) SebaR
