HsMrg.exe
HsMrg.exe
Ciklamen ::
Lep pozdrav.
ker mi gre že to počasi na živce, da ne morem prižgat PCja in normalno zalaufat programe, brez da ubijem ta proces (zraven kot description piše HsMrg application, tako da nevem od kod izvira sploh), se obračam na vas, če slučajno kdo ve, kateri program uporablja ta proces. Preiskal sem že cel internet, ne najdem nič koristnega...
- End of the Post ->
KoMar- ::
Kako melodramatično... "preiskal si že cel internet"... si ziher?
Ker tole najde Google takoj: http://www.avsforum.com/avs-vb/showthre...
Ciklamen ::
Sem tudi gledal to stran, pa nekako se mi zdi da ni pravega odgovora (ali pa sem jaz nor).
KoMar- ::
beankid, do you have an Asus soundcard like the Xonar? HSMgr.exe is used for EAX on those. If you do have one, download and install the "Vista Game Patch" from Asus. This should resolve the issue.
I am starting to think something hardware wise went bad on my computer....possibly the motherboard. I just don't have to money to put forth to fix it since it does power up and runs the computer for normal tasks. I just have a hard time to justify that purchase right now unless I know 100%
The computer will go into S3 sleep, just not S1....
Auzentech cards that are EAX compatible also use HSMgr.exe. If you don't use any games that have EAX, you can kill HSMgr.exe with no ill effect. You can also use MSConfig to prevent it from starting on boot.
See http://social.answers.microsoft.com/...8-166cb5fa7886 for reference.
  • spremenil: KoMar- ()
Ciklamen ::
Eh, nvm...
Nisem študiral da ga lahko disablam na MSConfigu.
Se opravičujem, my bad...
Hvala ti za trud vseeno KoMar-
Studying in Slovenia
Oddelek: Šola
267667 (4359) BivšiUser2
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820340 (17180) arrigo
Creative razpolovil število zaposlenih (strani: 1 2 )
549633 (7833) Han
Logitech MouseWare bug (?)
272610 (2206) Swiwer
Kaj za vraga je to RAID?
142838 (2503) krucymucy
