Forum » Pomoč in nasveti » MSN Messenger - problem s pogovornim oknom!
RunoTheDog ::
P4ajo ::
(sicer nevem kako to popravit, pripomnil bi le, da meni slike ne odpre (ne poveže se mi do nje))
RunoTheDog ::
Že odpravil...
Če bo kdo kdaj potreboval:
1. Press Alt-Tab (maybe several times) to switch to chat dialog (that is out of desktop bounds).
2. Press Alt-Space to activate so called system menu (menu that opens when you click on the icon in left-top corner of the window).
3. Select "Move" (use up and down arrows and press Enter). Now a cursor will switch from normal pointer to four-way arrow and the window should move automatically into desktop bounds.
4. Use arrows to move around the window. Press Enter to end movement.
| » | SMB povezava Winows 10 s Synology NASOddelek: Operacijski sistemi | 4392 (3658) | dukedl |
| » | Driver za grafično se preneha odzivat in opomore.Oddelek: Pomoč in nasveti | 944 (863) | lopov |
| » | Zaflešan Linksys wrt160nlOddelek: Omrežja in internet | 1617 (1354) | Spc |
| » | Novice o XGLjuOddelek: Novice / Ostala programska oprema | 4468 (3677) | G-man |
| » | Fast Forward DVOddelek: Sedem umetnosti | 1638 (1483) | simy |
