MSN Messenger - problem s pogovornim oknom!
RunoTheDog ::
Dober dan,
imam čuden problem. Pogovorno okno MSNja se mi je premaknilo izven "vidnega" namizja!
Bom raje prilimal sliko, da boste vedeli o čem govorim. Probal sem se že igrati z resolucijo, pa mi ni uspelo tega odpravit. Ali ve kdo, kako to odpravit (poleg reinstalla)?
 and Settings\jink\Desktop
P4ajo ::
(sicer nevem kako to popravit, pripomnil bi le, da meni slike ne odpre (ne poveže se mi do nje))
RunoTheDog ::
Že odpravil...
Če bo kdo kdaj potreboval:
1. Press Alt-Tab (maybe several times) to switch to chat dialog (that is out of desktop bounds).
2. Press Alt-Space to activate so called system menu (menu that opens when you click on the icon in left-top corner of the window).
3. Select "Move" (use up and down arrows and press Enter). Now a cursor will switch from normal pointer to four-way arrow and the window should move automatically into desktop bounds.
4. Use arrows to move around the window. Press Enter to end movement.
SMB povezava Winows 10 s Synology NAS
Oddelek: Operacijski sistemi
324391 (3657) dukedl
Driver za grafično se preneha odzivat in opomore.
7944 (863) lopov
Zaflešan Linksys wrt160nl
Oddelek: Omrežja in internet
91617 (1354) Spc
Novice o XGLju
134468 (3677) G-man
Fast Forward DV
Oddelek: Sedem umetnosti
171638 (1483) simy
