Forum » Programiranje » [VB] kako zaznati bluetooth telefon?
jishiri ::
Zdravo!
zanima me ce je kdo ze imel kake podvige glede bluetooth naprav, namrec bi rad spisal preprost program, a se je ze na zacetku zataknilo in ne vem kako zaceti...
nekaksen potek:
- odkriti napravo pridobiti ime in naslov
- ce je pravi telefon ki ga isce
- izvrsiti kill process (recimo notepad.exe)
- ob izgubitvi signala tega telefona
- izversitev ponovnega zagona aplikacije (recimo notepad.exe)
ze v naprej se zahvaljujem za pomoč
LP, JM
nekaksen potek:
LP, JM
jishiri ::
Imports System.Net
Imports System.IO
Imports InTheHand.Net
Imports InTheHand.net.Bluetooth
Imports InTheHand.Net.Sockets
Public Class Form1
Dim count As Integer
Dim startm As Integer
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Timer1.Enabled = True
Timer2.Enabled = True
count = 0
startm = 0
End Sub
Private Sub Timer1_Timer()
count = count + 1
If count = "5" And startm = 0 Then
startm = 0
count = 0
'shell process()
lstbx.Items.Add("No Bluetooth Devices Found")
lstbx.Items.Add("Monitoring Started...")
End If
End Sub
Private Sub Timer2_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer2.Tick
startm = 0
lstbx.Items.Clear()
'BluetoothRadio.PrimaryRadio.Mode = RadioMode.Connectable
Dim client As New BluetoothClient()
Dim devices As BluetoothDeviceInfo() = client.DiscoverDevices()
Dim headsetAddress As BluetoothAddress = Nothing
Dim device As BluetoothDeviceInfo
For Each device In devices
If device.DeviceName = "" Then
lstbx.Items.Add(device)
If device.DeviceName = "LGuk" Then
lstbx.Items.Add("Bluetooth Devices Found")
lstbx.Items.Add("Monitoring Stoped...")
headsetAddress = device.DeviceAddress
startm = 1
'Kill()
End If
End If
Next device
'Dim headset As New BluetoothEndPoint(headsetAddress, BluetoothService.Headset)
'client.Connect(headset)
'Dim myStream As Stream = client.GetStream()
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Me.Close()
End Sub
End Classam ja tole mi je za 1x ratalo spacati...
- spremenilo: jishiri ()
| » | Visual BasicOddelek: Programiranje | 4290 (3316) | cekr |
| » | vb.net: dynamic textboxOddelek: Programiranje | 1538 (1428) | saule |
| » | Visual Studio - koda za prikaz OS?Oddelek: Programiranje | 1471 (1238) | detroit |
| » | [VB] Komunikacija s serijskimi napravamiOddelek: Programiranje | 2745 (2019) | mNeRo |
| » | VB.net MDI in formi splošnoOddelek: Programiranje | 1991 (1934) | strel |
