Forum » Navijanje » navijanje E7500
navijanje E7500
theoneman ::
Živjo
zanima me na kulk bi se dal tole stvarco navit:
intel core 2 duo 2.93GHZ 11x 266
Tnx TOM
Tnx TOM
theoneman ::
OK amm valcoline a ni 4,5 mal prehudo edin če bim meu vodno hlajenje:D
Evo moj komp:
Računalnik:
Tip računalnika ACPI x64-based PC
Operacijski sistem Microsoft Windows 7 Ultimate
OS Service Pack [ TRIAL VERSION ]
Internet Explorer 8.0.7600.16385
DirectX DirectX 11.0
Ime računalnika THEONEMAN
Ime uporabnika Jure Potočnik
Prijavna domena [ TRIAL VERSION ]
Datum / Čas 2009-08-07 / 20:14
Osnovna plošča:
Tip procesorja DualCore Intel Core 2 Duo E7500, 3200 MHz (11 x 291)
Ime osnovne plošče Gigabyte GA-G31M-ES2L (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 2 DDR2 DIMM, Audio, Video, Gigabit LAN)
Čipset osnovne plošče Intel Bearlake G31
Sistemski spomin [ TRIAL VERSION ]
Tip BIOSa Award Modular (02/05/09)
Komunikacijska vrata (COM in LPT) Communications Port (COM1)
Komunikacijska vrata (COM in LPT) Printer Port (LPT1)
Zaslon:
Grafična kartica NVIDIA GeForce 9500 GT (1024 MB)
3D-pospeševalnik nVIDIA GeForce 9500 GT
Multimedia:
Zvočna kartica Realtek ALC883 @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1]
Diski:
IDE kontroler Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Storage Controller A0DI0LJC IDE Controller
Trdi disk Generic USB CF Reader USB Device
Trdi disk Generic USB MS Reader USB Device
Trdi disk Generic USB SD Reader USB Device
Trdi disk Generic USB SM Reader USB Device
Trdi disk WDC WD10EADS-00M2B0 ATA Device (931 GB, IDE)
Optični disk Optiarc DVD RW AD-5200S ATA Device (DVD+R9:8x, DVD-R9:12x, DVD+RW:20x/8x, DVD-RW:20x/6x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW)
Optični disk YHWJODC YJG1EB4LAVC SCSI CdRom Device
SMART Hard Disks Status OK
Partiticije:
C: (NTFS) [ TRIAL VERSION ]
D: (NTFS) 653856 MB (382923 MB prosto)
Polna velikost [ TRIAL VERSION ]
Vhod:
Tastatura Logitech HID-Compliant Keyboard
Miška Logitech USB Wheel Mouse
Mreža:
Primarni IP-naslov [ TRIAL VERSION ]
Primarni MAC-naslov 00-24-1D-93-63-BF
Mrežna kartica Hamachi Network Interface (5.97 [ TRIAL VERSION ])
Mrežna kartica Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (192. [ TRIAL VERSION ])
Periferija:
Tiskalnik Epson ESC/P-R
Tiskalnik Fax
Tiskalnik Microsoft XPS Document Writer
USB1 kontroler Intel 82801GB ICH7 - USB Universal Host Controller [A-1]
USB2 kontroler Intel 82801GB ICH7 - Enhanced USB2 Controller [A-1]
USB-naprave Lenovo Q350 USB PC Camera
USB-naprave Logitech HID-Compliant Keyboard
USB-naprave Logitech USB Wheel Mouse
USB-naprave USB Composite Device
USB-naprave USB Input Device
USB-naprave USB Mass Storage Device
DMI:
DMI BIOS proizvajalec Award Software International, Inc.
DMI BIOS Verzija F8
proizvajalec DMI sistema Gigabyte Technology Co., Ltd.
DMI Sistem produkt G31M-ES2L
verzija DMI sistema
Serijska številka DMI sistema [ TRIAL VERSION ]
UUID DMI sistema [ TRIAL VERSION ]
DMI proizvajalec osnovne plošče Gigabyte Technology Co., Ltd.
DMI produkt osnovne plošče G31M-S2L
DMI verzija osnovne plošče
DMI serijska številka osnovne plošče [ TRIAL VERSION ]
DMI proizvajalec ohišja Gigabyte Technology Co., Ltd.
DMI verzija ohišja
DMI serijska številka ohišja [ TRIAL VERSION ]
DMI Asset Tag ohišja [ TRIAL VERSION ]
DMI tip ohišja Desktop Case
DMI Total / Free Memory Sockets 2 / 0
Evo moj komp:
Računalnik:
Osnovna plošča:
Zaslon:
Multimedia:
Diski:
Partiticije:
Vhod:
Mreža:
Periferija:
Tiskalnik Fax
DMI:
DMI BIOS Verzija F8
verzija DMI sistema
DMI verzija ohišja
na tej plati bos bolj malo navijal, ker je cena plate 50e.
- spremenil: mtosev ()
ne. ne bo se skurila kaj prevec najijanja na plati za 50e ne pricekuj.
theoneman ::
ja k nastavš kulk čm met procesor je max 11x pol pa od 200 - 700 a zdej mam mal manj k 300 tk da ne vem :D mal mi je hecn ta dual bios:D
BALAST ::
Tole matično sem imel jaz in sem navil Pentium C2D E5200, 2,5ghz @3,8ghz stabilno pri 1,4250V bios/ 1,360V Everest, 333 x 11,5 množilnik. Ram je bil pa Corsair Dominator 8500 1066Mhz na 2,1V bios/ 2,14 Everest, hladilnik pa orginal od intela z pasto Artic silver 5.
In kot cenena matična je tudi cenjena pri navijalcih, vsaj pri dual core procesorjih. In so tudi će navili C2D E8400 na 5Ghz z vodnim hlajenjem. Edina pomankljivost je da je FSB wall dokaj nizkih 360Mhz, ter da je max napetost spomina 2,1V.
theoneman ::
Torej na kulk lahk navijem 2.93GHz ? na 3,5 al bi se dal še kej več?
aja pa kulk je lahk temperatura procesorja,. k zdej je 47° sm se hitr segreje na 52 al pa kej več,.
TOM
TOM
BALAST ::
Procesor bo prebavil sunke do 90°C brez okvar (prime95), medtem ko Intelova priporočena max obratovalna temperatura je 74°C.
Zdaj koliko boš navil je stvar procesorja in stabilnosti napajalnika ter spomina. Poizkus prvo dvignit voltažo procesorja na 1,35V, potem voltažo NB za +0.2, spomin +0.1 in SB na +0.1. in poizkusi dvigovati FSB po korakih za 20Mhz, ko se ne bo več bootal, počakaj da se resetira bios nastavitev in zmanjšaj za 10Fsb. Potem poizkusi, če ti pride v Winse brez napak.
theoneman ::
Aha ok bom probu sm men tam rdeče utripa kr piše da če nastavlam fsb da naj pustim voltage na auto in ne namanual:)
theoneman ::
Amm pa še to slikco poglej:
Zakaj je temp1 in temp2 -XX° temp3 pa kr vročeee:D
pa mal poglej kakšne so napetosti,. mal so mi hecne:)
TOM
TOM
- spremenil: theoneman ()
BALAST ::
To je pač napačno odčitavanje senzorjev, ti glej samo na core1 in core2, napetost pa na vcore1 PROC in vcore2 RAM, ostale stvari te ne zanimajo.
Tudi če je v biosu rdeča številka, to samo pomeni da proizvajalec ne priporoča nadaljevanje stopnevanja in da bi bilo dobro dokupit kakšen ventilator za prezračevanja ohišja. A to je tvoj maximum?, na tej voltaži ti mora it vsaj na 3,5Ghz stabilno.
theoneman ::
ne vem jst sm šu dozdej na 3,23 in dela uredu bom ju3 zjutrej spet probu kej navit,.
Se takat tipkava al me pa rajp dodej na msn: jurepot@hotmail.com
Thanks TOM
Thanks TOM
dzinks63 ::
intel core 2 duo 2.93GHZ 11x 266, nekaj več o intel procesorjih
Za kombinacijo z to matično ploščo bi lahko naredil BSEL mod na procesorju in bi imel potem intel E7500 z 333fsb, kar pa je nekako preveč (11x333=3666, mogoče bi šlo le z zelo dobrim hladilnikom na procesorju) in bi postavil množilnik v biosu kar na 10, kar bi zneslo končnih 3,3GHz, to pa bi moralo laufat BP. Mogoče bi moral le malo povečati voltažo na procesorju, na ramih pa mislim, da ni potrebno , če bi jih laufal na 800.
- spremenil: dzinks63 ()
theoneman ::
aha ,. sm pomoje bom ostal na 310 FSB pa množilnik 11x to je vse skup: 3,41GHz
kr tud hladilnik k mam je sm navadn ventilator:D nč posebnega pomoje je biu ukul 30€:p
TOM
TOM
Valvoline ::
TOM
Poglej na kolk maš rame nastavljene,ker k navijaš se tut rami navijajo,zmanjšaj frekvenco ramov in poskus še enkrat.
Valvoline ::
downlodaj si program cpu-z in poglej na kolk so rami nastavljeni. tale proc gre ziher na 350fsb najmanj.
Valvoline ::
ok tle je slikca:
TOM
Tu je težava,že delajo na 2x465 torej na 930mhz.
Zmanjšaj frekvenco tak da ne grejo čez varnih 800-850mhz. Voltažo procesorju nastavi na 1.35 in navijaj pač kolk se da stabilno,vendar skoz kontroliraj frekvence ramov. Delilnik ramov je treba nastavit tako da bojo deloval v območju 800-850mhz
- spremenil: Valvoline ()
Valvoline ::
OK tnx bom to ju3 probu:)
TOM
Niso prepočasni le delilnik je treba naštimat da ne bojo naviti čez 900mhz
Revenant ::
Več maš jajc, bolj boš navil. In če procesor postane črn in začne smrdeti po bajturini, potem je procesor najverjetnjeje skurjen.
Bolje golob v roki kot kurac na strehi.
TOP ::
Revenant,daj ne bluzi s takimi,če nisi še nikoli probal,verjetno si spet eden tistih,ki je nekaj slišal.
M-XXXX ::
Drugič bod raje tiho, kot da govoriš take bedarije...
CleanPower ::
kva si ti fuknen a kua:)?
navadn ventilator za 30eur? za 30 eur dobiš že odličen heat-pipe hladilnik!
theoneman ::
ja no nekje k sm gledu,. se mi niso zdel glih ql za 30€:D
TOM
TOM
Revenant ::
Wtf? Kaj ti ne paše? Pravim samo da če je procesor črn in zažgan, potem je najverjetneje skurjen
TOP ::
Pa dobro Revenant,ma kaj ti bluziš o nekih skurjenih procesorjih.Tukaj sprašuje kako naviti proc,ne pa da je skuru proc,daj preberi prej o čem se pogovarjamo,pa potle bluzi.
Valvoline ::
Časi p2 p3 in starih athlonov so mimo. Zej majo vsi procesorji termalno zaščito in ne prihaja do poškodbe zarad pregrevanja.
| » | Zamenjava operacijskega sistema ! (strani: 1 2 3 )Oddelek: Pomoč in nasveti | 14248 (12459) | Assass1n |
| » | Zvok ne delujeOddelek: Pomoč in nasveti | 1107 (1022) | Blinder |
| » | PC - ni zvoka (zvok je "izginil")Oddelek: Pomoč in nasveti | 1913 (1772) | Mihal01 |
| » | ugašanje in restartanje računalnikaOddelek: Pomoč in nasveti | 6715 (6368) | Cold1 |
| » | Procesor ko žerjavica?Oddelek: Hlajenje in modifikacije | 2079 (1845) | T0RN4D0 |
