Forum » Zvok in slika » Entire Nikon 2009/ 2010 DSLR Product Roadmap Leaked
kuglvinkl ::
2009
Nikon D3000
12.3MP
7 AF points
ISO 200-3200 extendable to 6400
3.5fps
Video unknown
Nikon D300s
12.3MP
7fps
HD video (1080p .mov h.264, 24fps)
CF and SD cards slots
920,000 pixel LCD screen
D700x
24.5MP
5fps
Plus a bunch of new lenses, mostly updating older classics with new G-version, the ones that come without an aperture ring, and adding internal autofocus motors to work with lower end models. These will be:
AF-S Nikkor 24 to 135 mm f/3.5-5.6G ED VR
AF-S Nikkor 70-200mm f/2.8G ED VR II
AF-S Nikkor 35 mm f/1.4G
AF-S Nikkor 85 mm f/1.4G
Then, 2010. Here come the big ones:
Nikon D4
15.7MP (more sensitive and with less noise)
Up to 16fps with “double exposure”
ISO 200-12800 (plus extended range)
61-point AF
1080p video at 30fps
CLS control (although no flash is mentioned)
Nikon D400
13.8MP (more sensitive and with less noise)
8fps
Up to 12fps with “double exposure”
ISO 200-6400 (plus extended range)
61-point AF
1080p video at 24fps
Nikon D4x
30.2MP
ISO 100 - 6400
6fps
Plus lenses for 2010
AF-S Nikkor 14 to 28 mm f/3.5-4.5G ED
AF-S Nikkor 120 to 450 mm f/4.5-5.6G ED VR
AF-S Nikkor 300 mm f/4G VR
Nikkor AF-S VR 400 mm f/5.6G
AF-S Nikkor 70 to 240 mm f/3.5-4.5G VR
AF-S Nikkor 105 mm f/2G DC
AF-S Nikkor 24 to 85 mm f/4G VR
AF-S DX Nikkor 60 to 95 mm f/2G VR
AF-S DX Nikkor 17-60 mm f/2.8G VR
Več: KLIK!
Nikon D3000
12.3MP
7 AF points
3.5fps
Video unknown
Nikon D300s
12.3MP
7fps
D700x
24.5MP
5fps
Nikon D4
61-point AF
Nikon D400
8fps
61-point AF
Nikon D4x
30.2MP
ISO 100 - 6400
6fps
Več: KLIK!
piek ::
Ubogi Canon, cisto ga bodo povozili. =)
Nikon D4, mnjami.
Nikon D4, mnjami.
Finish it off if you started it!
kuglvinkl ::
Prejšni vikend sem fotkal s aktualnim 105mm 2.0. Jezus kristus... Mokre sanje.
Kar se tiče teh G modelov, sem malo skeptičen. Imam recmo 50mm 1.4G. In AF ni tko hiter kot pri "starem 50mm 1.4. In nisem edini, ki ga to moti.
Jasno me pa matra 35mm 1.4... Čeprav sem z 2.0 izredno zadovoljen. V bistvu primarna leča.
Pogrešam pa 24mm...
In vidim, da ni zamenjave za D700 :) Tko da sem se kot kaže zelo prav odločil. D700x seveda ni zamenjava za D700.
Pogrešam pa 24mm...
piek> Ubogi Canon, cisto ga bodo povozili. =)
Jaz pa nisem več tolk prepričan (pa sem pred enim letom bil).
Če bi se Canon odločil podpreti odprt razvoj strojne programske opreme, bi njihovi fotoaparati totalno rulali.
kuglvinkl ::
Nion je te dni oznanil spinoff 100 ljudi v novo firmo, ki bo skrbela izključno za FW.
BW? Misliš, 2.8 ti je predrago, ostalo pa je samo 3-5-5.6?
kuglvinkl> Nion je te dni oznanil spinoff 100 ljudi v novo firmo, ki bo skrbela izključno za FW.
Hja, to ni dovolj dobro, se bojim. Dokler ni open source, je krš :)
BigWhale ::
Ja. Canon ima tri linije objektivov. Tiste s spremenljivim f-om. Od 3 pa do 5.6 in dva s fiksnim. Prvi f4 so malenkost 'manj profesionalni' in precej cenejsi od zadnjih f2.8.
kuglvinkl ::
Imate samo zoome? Fiksnih nič? :) Jest nimam zoomov...
Hja, ta obvezne fiksne že mamo (100 makro, 15 fisheye, 50/1.4, 300/4) ampak mamo pa tut ta obvezne zoome (24-105/4, 70-200/2.8, 16-35/2.8).
noraguta ::
ja pa najbolš , da so slike posnete z takim firmwaretom kr avtomatično licencirane z CC ker slike ki niso CC so krš.
kuglvinkl ::
Predvsem je pametno, da ne nabijajo megapikslov, ampak raje višajo občutljivost.
Seveda, če pa že hočeš 30MP si pač ubodeš takšen model, namenjen za studijo. Me prav zanima, kako bo z aparati srednjega formata...
noraguta> ja pa najbolš , da so slike posnete z takim firmwaretom kr avtomatično licencirane z CC ker slike ki niso CC so krš.
Saj ne veš, kaj govoriš.
A si videl Magic Lantern? A poznaš originalni 5Dmk2 firmware?
Well, there.
Well, there.
| » | Nov D-SLR (strani: 1 2 )Oddelek: Kaj kupiti | 32537 (20802) | BigWhale |
| » | Problemi z izostritvijo-Nikon dslr-pomoč!Oddelek: Zvok in slika | 1598 (1175) | kurjač |
| » | Nikon D5100 + Tamron 18-200 ali 18-105 VROddelek: Kaj kupiti | 5362 (5158) | Good Guy |
| » | Nikon predstavil novo kamero D7000 in 35mm f/1.4 objektiv (strani: 1 2 )Oddelek: Novice / Ostale najave | 17795 (14027) | kuglvinkl |
| » | Nikon predstavil D3100 in štiri nove objektive (strani: 1 2 3 )Oddelek: Novice / Ostale najave | 26708 (24220) | legice |
