not enough storage is available to process this command ???
sith ::
Oj.
Postavljen imam server 2008 in želim uporabiti KMS klienta za licenciranje računalnikov v domeni...... da ne bom predolg.... ko hočem štartat inštalacijo KMS klienta mi napiše "not enough storage is available to process this command" .
Ali ima kdo kako idejo kaj bi lahko bil problem?
  • spremenil: sith ()
Rotaidal ::
Do one of the following, then retry the command: (1) reduce the number of running programs; (2) remove unwanted files from the disk the paging file is on and restart the system; (3) check the paging file disk for an I/O error; or (4) install additional memory in your system.
http://technet.microsoft.com/sl-si/libr...
Kako izklopiti page file
61065 (946) gzibret
Koliko placa za Visto?
Oddelek: Operacijski sistemi
132226 (1876) Pesimist
Your sistem is low on virtual memory?
81578 (1417) Nettisunny
win 2000 virtual memory to low
101858 (1684) civava23
Kako razdeliti 250GB disk? (strani: 1 2 )
517132 (6245) bajsibajsi
