Forum » Pomoč in nasveti » Nenajde Tv-Cipa Geforce2 Mx 400
mirsi ::
Tko preprost nenajde!! nikjer
probal vse detoratorje, uradne driverje...
nenajde ;(
je kaput?
nenajde ;(
je kaput?
AngelOfDeath ::
Nenajde Tv-Cipa Geforce2 Mx 400 ?
o kakšnem Tv čipu govoriš ?
kolk jaz vem je to grafični
keri os maš
mašp antivirus vklopljen med inštalacijo ?
keri os maš
Joze_K ::
idi na nemsko stran TVTool, tam v forumu bos videl kateri cipi so vse podprti za TVOut, pa tudi s tem programom bos lahko krmilil TV izhod.
www.tvtool.de
www.tvtool.de
mirsi ::
AngelOfDeath - Nevem kk nerazumes!?
Na kartici Geforce2 mx 400 se tud nahaja tv.out a ne..vsaj na tej ki jo imam jaz!
tv tool pa tud napise da nenajde tv-chipa in da naj v twinview sedaj "Nview" nastimam bla bla... in tud sem
pa v properties pod geforce ko kaze vse podatke o graficni pise pod Tv-chip - Not Found
zato ga pa tud tvtool ni mogu zaznat!!
pa sej zdej tk ni vazno ker sm kartico poslal nazaj tistmu ko mi jo je prodal ;) nevem a je vedel za to okvaro al kaj!!
vseeno hvala
vseeno hvala
Joze_K ::
http://www.nvidia.com/view.asp?IO=IO_20...
TV-out on my graphics card is not working. How can I fix this?
To test the TV-out feature of your graphics card, turn off your computer. Then connect the S-VIDEO cable from your graphics card to your TV. If your TV does not support S-VIDEO, then you may need to purchase an “S-VIDEO to Composite” adapter. Once you have all the connections you need, connect your graphics card to your TV. Make sure there are no other devices in between, such as a VCR or switchbox. Then, unplug the PC monitor from your graphics card leaving only the TV connected to your PC. Make sure your TV is set to AUX or Line-In. Otherwise, your graphics card will not detect the presence of a TV. Turn on your PC. The system should automatically detect your TV and send the video signal to your TV. If it does display the video signal onto your TV but stops once you boot into Windows, it may simply be a driver issue. You should download the latest drivers for your graphics card from: http://www.nvidia.com/view.asp?PAGE=dri....
If you do not get a video signal on your TV when you turn on your PC, then this means that either your TV is not sending a video signal back to your graphics card to let it know that a TV is present, or that the TV encoder that handles TV output is not functioning. If you have a different TV to test with, please perform the same test to see if the TV-out is working. Check that none of the pins inside the video cable are bent or missing. If you cannot get TV output from any TV, then your TV encoder is probably defective. Contact your graphics card manufacturer or retailer where you purchased your graphics card from for possible graphics card replacement if your card is still under warranty.
| » | atikmpag.sys BSoDOddelek: Pomoč in nasveti | 4173 (3921) | zupanman |
| » | ko prižgem računalnik se ne prikaže slikaOddelek: Pomoč in nasveti | 1925 (1819) | FX6300B |
| » | Grafična kartica in laptopOddelek: Pomoč in nasveti | 2215 (2063) | DeeCoy |
| » | Full Screen Anti-aliasiOddelek: Pomoč in nasveti | 1179 (1088) | BaRtMaN |
| » | A je pomembno katero 9800 PRO izbrati?Oddelek: Kaj kupiti | 2223 (1875) | vuki |
