Forum » Pomoč in nasveti » WD 500 GB my book ext.drive - problem
jos69 ::
Zaradi težav z elektriko v hiši nam je metalo ven FID stikalo.
Seveda je tudi comp ugasnil med delovanjem.ko smo zadevo uredili
sem ugotovil da na zunanjem disku ne vidim nobenih datotek.
Disk mi pravilno pokaže velikost in zasedenost na disku in nič drugega.
Disk je priklopljen preko firewira.Sem pa z enim programom ugotovil da
je disk sedaj RAW(kaj bi naj to pomenilo.
Verjetno bi kakšen softwarski program rešil problem.
Diska pa seveda ne bi rad formatiral.
Prosim za nasvete.
Prosim za nasvete.
1024 ::
Ne piši nič po disku!
Sledi navodilom:
Do not install GetDataBack on the drive you want to recover! It is strongly recommended to proceed as follows:
Install the program to another computer, which doesn't have any problems. If you have a choice, choose the computer with the most RAM and is the fastest. Attach the drive you want to recover as a slave to this machine. Make sure the drive is jumpered correctly and is recognized by the BIOS.
After downloading GetDataBack run the setup.exe. The setup Wizard will guide you through the installation process.
NEW: If there is no way to attach the drive to an extra computer, you can run GetDataBack from a WinPE boot CD-ROM.
http://www.runtime.org/data-recovery-so...
Sledi navodilom:
Fish knows everything.
- spremenilo: 1024 ()
| » | trdi disk ni inicializiranOddelek: Pomoč in nasveti | 5332 (4829) | scipascapa |
| » | Diagnostično orodje za WDOddelek: Programska oprema | 5037 (4897) | clovk |
| » | USB ključ error => disk is not formattedOddelek: Pomoč in nasveti | 4762 (4319) | muzičar |
| » | Nedokončan zapis indeksa particije. HELP!Oddelek: Pomoč in nasveti | 1270 (1168) | Alex- |
| » | Po zagonu HD Tach-a ni sistema na disku?!Oddelek: Pomoč in nasveti | 1544 (1415) | mm |
