Forum » Operacijski sistemi » [WINDOWS 7] Vprašanja in težave
erzy ::
dober večer vsem skupaj imam problem hotel sem gledati csi po računalniku z Media Player Classic Home Cinema seveda na windows 7 in mi javi da ne najde kodeka..? natancčneje..
Media Type 0:
Video: XVID 576x320 25.00fps 1028Kbps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {44495658-0000-0010-8000-00AA00389B71}
formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 131256
cbFormat: 156
VIDEOINFOHEADER:
rcSource: (0,0)-(0,0)
rcTarget: (0,0)-(0,0)
dwBitRate: 1028125
dwBitErrorRate: 0
AvgTimePerFrame: 400000
BITMAPINFOHEADER:
biSize: 40
biWidth: 576
biHeight: 320
biPlanes: 1
biBitCount: 24
biCompression: XVID
biSizeImage: 552960
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0020: 1d b0 0f 00 00 00 00 00 80 1a 06 00 00 00 00 00 .°......€.......
0030: 28 00 00 00 40 02 00 00 40 01 00 00 01 00 18 00 (...@...@.......
0040: 58 56 49 44 00 70 08 00 00 00 00 00 00 00 00 00 XVID.p..........
0050: 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 ................
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090: 00 00 00 00 00 00 00 00 00 00 00 00 ............
Simple. Poišči kodek. Ti priporočam da uporabiš drugi predvajalnik videov. Npr "vlc player". Ali "gom" ki je zastojn na uradini strani,
Intel Core2Duo E8500 3,17GHz, ASUS P5Q Pro,
erzy ::
ker en kodek imam ze sedaj ffdshow neki takega...
Obstaja ogromno kodekov, eni so ze ene datoteke drugi za druge. Meni GOM če nima ustreznega kodeka poišče sam na internetu pa namestiš in dela bp. ;)
- spremenil: erzy ()
jan01 ::
Poskusi s novejšo verzijo mpc home cinema 1164
Gom player je slab, saj sili svoje media splitterje(ne moreš uporabljat drugih) + ima slabe svoje dekoderje(tukaj pa res lahko uporabljaš druge). Boljša alternativa gomplayerja je kmplayer(pa ne govorim o linuxovem!)
VLC -najslabši, najbolj bugast player ever. Exploitov pri vsaki verziji cel kup. Veliko boljša alternativa tega je smplayer
- spremenilo: jan01 ()
PerS ::
a kdo ve kako se naredi upgrade iz window 7 beta na RC, da ne bo težilo z ugašanjem? Ker ko sem kliknil na upgrade pri namestitvi pravi da to ni mogoče pa da bo treba novo inštalacijo narest :S A se lahko kako izognem temu, ker sem ravno sredi dela in ni najboljši čas da delam novo inštalacijo kompletnega sistema..
bluefish ::
http://www.google.si/search?q=windows+7...
Ti pa to početje močno odsvetujem. Sprva po nadgradnji verjetno ne bo težav, pozneje pa se lahko prične zapletati.
Prav tako bo sam postopek precej dolg.
- spremenil: bluefish ()
solatko ::
Jaz sem ravnokar nadgradil z verzijo 7260, dela odlično, pa še v Slovenščini je. Nadgradit moraš v Angleščini, potem pa samo izbereš jezik iz tabele. Log off in po ponovnem vklopu si v jezikovni verziji, katero potrebuješ. Sama nadgradnja, pa kar traja cca 2 uri, vendar se vseeno splača, pa iz 7100 na 7137 nisem imel tudi pozneje nikakršnih težav, tako, da jih tudi sedaj ne pričakujem.
bluefish ::
Saj pri nadgradnji iz ene RC verzije na drugo RC oz. iz Beta na Beto ni problema. Lahko se zatakne pri Beta > RC.
solatko ::
Tudi iz Viste na beta in na 7137 RC in sedaj na 7260 multilanguae, je šlo brez najmanjših problemov, edino visto Ultimate, sem moral spravit na angleško verzijo (zbrisati slovenščino), pri 7260 pa se vsi jeziki avtomatsko naložijo in samo menjaš med njimi.
Jebac18 ::
jaz imam 7100 verzijo in mi je čist kul samo d se ne briše internet mi dela nubenih problemov zaenkrat..imam pa jo že od kar je prsla vn ..
VidKo ::
datoteko cversion.ini moraš editirat ;)
vrstico MinClient=7262 spremeni v MinClient=XXXX kjer je XXXX build različica nameščenega sistema.
http://www.commit.si
spletna računalniška trgovina za overclockerje, gamerje in modderje
schtr4jh ::
Živjo =)
En mesec nazaj sem si namestil Windows 7 (Build 7231). Samodejno so se namestili vsi gonilniki, vendar sem ugotovil (že na začetku), da zvok ne deluje tako, kot bi moral. Lev zvočnik deluje brez problemov, iz desnega pa sam hrušči. Zvočnike (Logitech z2300) sem pretestiral na drugem računalniku in delujejo brez problema. Torej v zvočnikih ni problem. Ko sem prenesel originalne gonilnike iz Gigabyte strani (matična plošča GA-8I945PLGE-RH), mi ob namestitvi vrne napako 0x00000103. Malo sem tudi googlal in našel [url=http://forums.lenovo.com/lnv/board/mess..., v kateri uporabnik piše, da naj namestim gonilnike iz Realtek-ove strani. Namestitev je bila uspešna, vendar se pojavlja enak problem.
Any ideas?
Any ideas?
dzinks63 ::
Instaliraj R2.20, meni dela na win7 7600x86 popolnoma ok. Je pa zunaj že novejša verzija R2.28
- spremenil: dzinks63 ()
neBlot ::
Jaz bi pa rad uninstaliral trenutni RC 7100 x86 build in instaliral tazadnji RTM 7600 x64.
Nisem še nikoli formatiral oken in bi rad slišal kakšen napotek, ker se bojim, da bom kaj zajebal.
Rotaidal ::
Nimaš kaj zajebat. Postopek je enak kot si snemal rc 7100, le da predno izbereš na kateri disk bi posnel okna, prvo formatiraš tisti disk.
Spodaj imaš možnost format disk:
neBlot ::
Hmm, čim poženem DVD mi javi to sporočilo:
Sem bootal iz CD-ja, pa spet en nesmiselen error:
Kaj pa formatiranje direkt v os-u in reinstalacija, je to mogoče?
Windows has encountered a problem communicating with a device connected to your computer. This error can be caused by unplugging a removable storage device such as an external USB drive while the device is in use, or by faulty hardware such as a hard drive or CD-ROM drive that is failing. Make sure any removable storage is properly connected and then restart your computer. If you coninue to receive this error message, contact the hardware manufacturer. Status: 0xc00000e9
Rotaidal ::
Ja valda da ti, če imaš 32 bit sistem, ti bi pa snemal 64 bit preko.
... aja si bootal z dvdja
poglej če kaj pomaga:
http://social.microsoft.com/Forums/en-U...
http://www.overclock.net/operating-syst...
- spremenil: Rotaidal ()
Anto ::
Js sm si inštaliru win7 build 7600 x64...Vse dela ok razen IPTV. Imam Siol trio in na Visti je normalno vse delalo z bilokirim programom(Multicast, VLC, FripTV....). IPTV spremljam na 2TV(mpeg2) in na računalniku(mpeg4)... Problem je da z bilokaterim programom poizkušam gledati TV, mi vsi začnejo štekati. Poleg slike na računalniku začne zelo štekati tudi slika na obeh TV...Potrebno je 5-10min da se zadeva umiri, ter da potem deluje TV normalno naprej. Poskusil sem že različne verzije programov, nastavitve v požarnem zidu....vendar čisto nič ne pomaga...
Če prižgem računalnik in grem takoj gledati IPTV(na računalniku) deluje normalno...Ko pa se povežem na internet, in ko recimo v MulticastTV preklopim v fullscreen in prestavim na drug kanal se začne štekanje(ko preklopim kanal, takrat se naj bi naložil EPG-mogoče zato začne štekati-zaradi aktivnosti internetne povezave)?? Tudi internet dela veliko počasi potem ko se začne štekanje in ugasnem program-5-10min dela internet počasi in TV še vedno štekata...Takih problemov na Visti SP2 ni-sem včeraj poiskusil in dela vse normalno. Torej mislim, da je problem v WIN7.
Ve kdo kaj bi še lahko poiskusil ??
Mogoče z novo Lan kartico ?? Ker sedaj imam 2 in obe sta integrirani na matični plošči-Gigabyte UD5...
neBlot ::
Hvala ti lepa!! Ponovna peka DVD-ja na nižji hitrosti je pomagala...
Sem pa naletel na nov problem :S. In sicer za božjo voljo mi ne spusti product key-a naprej. Sem bral naokoli, da se da akivirat preko warez tool kita, a kaj ko bi moral za to prvo v Windowse pridet... :[
zerdoner ::
Pozdravljeni...imam eno vprašanje...Iz microsoftove strani sem si snel win7 7100...in dobil zraven ključ, ki bi naj veljal eno leto...zanima me pa sledeče: 1. ali si lahko iz torrentov snamem win7 7600 in uporabim ta dobljeni ključ ali ne bo šlo skozi...
2. če si namestim win7 7100 lahko potem posodobim na verzijo 7600 ali se to ne da?
Hvala
Hvala
Kako namestim Windows 7 na hladilnik?
Daš w7 dvd v hladnilnik in ...
- spremenil: iloveboobz ()
Mipe ::
Vendar uradno ne bo zraven vse dokler ne uradno izdajo W7. Igre za DX10 se začnejo razvijati šele takrat, ko je DX10 splošno razširjen in obstaja trg. Mogoče je že zdaj nekaj razvijalcev na tem, vendar glede na razvojno dobo iger in trenutni status W7, lahko rečem da to še ne bo tako kmalu.
XPji bodo trajali še kar nekaj časa, dokler ne bodo DX10 kartice (cenejše) in igre bolj razširjene.
bluefish ::
pravzaprav je DX10 neke vrste DX8, ki ni ravno zaživel. Za DX11 mnogi napovedujejo boljšo prihodnost.
Malajlo ::
Hvala
http://www.microsoft.com/windows/window... pa se prijaviš preko LoginLive? Oziroma https://www.microsoft.com/betaexperienc... Mislim, da ni nujno, da si M$ partner... Zakaj torrenti?
DaVidQ ::
Zanima me če že dela PB, oz če je že kdo igral CoD2 MP na serverju z PB ?
Seveda, vse lepo dela, edina težava je, da te bo vrjetno na nekaterih serverjih vn metalo zarad "unknown windows api function 131133, 131136 ipd... Sem že pisal evenbalacncu zarad tega, pa so mi nek programček poslal, pol sem jim pa mogu report nazaj poslat... zdj zopet čakam na odgovor...
NoXy ::
DaVidQ : Seveda, vse lepo dela, edina težava je, da te bo vrjetno na nekaterih serverjih vn metalo zarad "unknown windows api function 131133, 131136
Torej to pomeni da NE dela haha :D Vseeno hvala za info.
DaVidQ ::
Sem omenil da se to dogaja samo na 2 serverjih? Torej ne vidim velikega problema
Poleg tega se da to rešit.
Master Chief ::
Dajte povedat mate tud vi kake probleme s Crysisom? Nazadne sn probal z 9.5 catalysti in je delal super, amapk max 20min. Nakar stekne. Vcasih se niti ne zazene, ko pa so tiste reklame na zacetku pa tak utripne. VSE ostale igre delujejo BP. S kisto je vse OK. 64bit se zazene, ampak tema. 32 pa takle heca. So 9.7 cat porihtani? Mogoc pomaga nardit bliznco, pa dodat -dx9? Je se kdo poskusal Crysis na 7 64bit?
Vitamin-B ::
Mene zanima katero verzijo (32 ali 64 bitno) naj si namestim? Seveda gre za 7.
Predvsem me zanima v koliko hitreje mi bo delovala Mathematica pri 64 biti verziji ter koliko komplikacij bom imel z ostalimi programi in igrami. Zanima me tui splošna kompatibilnost 7ke s stvarmi, k npm. delajo v XPju.
aja mam pa p5q pro, e8400, hd4780 512, 4 gb ram
Hvala, lp
Hvala, lp
- spremenil: Vitamin-B ()
| ! | [WINDOWS 8] Vprašanja in težave (strani: 1 2 3 4 … 27 28 29 30 )Oddelek: Operacijski sistemi | 528189 (93870) | jedateruk |
| » | Nadgradnja Windows 10 (strani: 1 2 )Oddelek: Pomoč in nasveti | 32697 (27817) | R1710 |
| » | Zmešnjava z gonilniki - W7 in XP - ter dual boot problemOddelek: Operacijski sistemi | 7425 (7030) | solatko |
| » | Windows 7 najuspešnejši Microsoftov operacijski sistem (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 31945 (28700) | Jst |
| » | Windows 7 se prodaja odlično (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 21632 (19026) | jest10 |
