Forum » Operacijski sistemi » Windows Web Server 2008 - nekaj mi ni jasno
Exceptions and Additional Terms Specific to Windows Web Server 2008
For Windows Web Server 2008
Limitation on Use.
The software may be used solely as an Internet-accessible front-end web server for development and deployment of the following:
Web pages
Web sites
Web applications
Web services
POP3 mail serving.
Access to content, information, and applications served by the software may not be limited to your or your affiliates’ employees. You may run database engine software on an instance of the software solely to support applications running on the same instance of the software. You may run web server software (for example, Microsoft Internet Information Services), management or security agents (for example, the MOM agent) on an instance of the software.
Any other usage of the software is not permitted.
Lahko kdo razlozi?
Limitation on Use.
Web pages
Web sites
Web applications
Web services
POP3 mail serving.
Lahko kdo razlozi?
Daedalus ::
Nekdo ti je pravkar povedal, kaj lahko delaš z Windows Web Server 2008. Če jih uporabljaš za karkoli drugega, je to kršitev EULA. Pa verjetno bi kaka dosti tečna inšpekcija zarad tega lahko napisala kako anti-warez kazen.
[J.P.Sartre]
[J.P.Sartre]
wrong. niti ga nimam instaliranega. ni potrebno biti "pameten".
Daedalus ::
A pol praviš, da sem narobe razumel limitation on use?
[J.P.Sartre]
[J.P.Sartre]
ne govorim da mi o neki antiwazen kazni govoris.
zanima me ce lahko to uporabljam kot workstation al ne? ce ne. win08 ne rabim.
bluefish ::
Kot je bilo že rečeno o temi, kjer se je govorilo o konferenci, je to namenjeno le za potrebe web serverja. EULA ti brani uporabi za workstation.
| » | VarnostOddelek: Informacijska varnost | 24997 (6698) | techfreak :) |
| » | Dual boot 2 x windows xp in licenceOddelek: Operacijski sistemi | 1699 (1467) | ender |
| » | Legalno ali nelegalno?Oddelek: Programska oprema | 2414 (1712) | poweroff |
| » | Kje kupit Windows XP Pro in koliko stane?Oddelek: Operacijski sistemi | 5343 (4293) | bond007 |
| » | Linux / ATI Radeon / problem z driverjiOddelek: Operacijski sistemi | 2214 (2031) | ahac |
