Antivirusni program boot - ključek?
AlesC ::
Obstaja kak antivirusni program za na ključek, da ti ga lahko boot-a z dosa? Kao neke vrste safe disk! Ključek lahko naštelam da mi dela kot 1 naprava... Rabim nujno neki.
Hvala za vsak odgovor
ST-777 ::
Safe disk? Morda ti bo ustrezalo tole:
Boot Windows XP from a USB flash drive
"What if you could return the machine to a bootable state just by inserting a USB flash drive though? Believe it or not, it is actually possible to install a bootable copy of Windows XP onto a flash drive and then boot a PC off of the flash drive.
From there, you can use applications that you have installed on the flash drive anti virus, anti spyware, disk repair, etc.) to fix the PC's problem."
Format usb ključka
255170 (3079) Skylord
Remix OS 64 bit (napačen) download
Oddelek: Operacijski sistemi
174089 (3730) m3k
ADATA S102 Pro 64 GB USB 3.0
191915 (1645) Han
Sveža namestitev na prenosnik s hibridnim diskom
81044 (951) legion
Inštaliranje Windows7 iz usb
144422 (3979) king67
