Forum » Pomoč in nasveti » Antivirusni program boot - ključek?
AlesC ::
Obstaja kak antivirusni program za na ključek, da ti ga lahko boot-a z dosa? Kao neke vrste safe disk! Ključek lahko naštelam da mi dela kot 1 naprava... Rabim nujno neki.
Hvala za vsak odgovor
ST-777 ::
Safe disk? Morda ti bo ustrezalo tole:
Boot Windows XP from a USB flash drive
"What if you could return the machine to a bootable state just by inserting a USB flash drive though? Believe it or not, it is actually possible to install a bootable copy of Windows XP onto a flash drive and then boot a PC off of the flash drive.
From there, you can use applications that you have installed on the flash drive anti virus, anti spyware, disk repair, etc.) to fix the PC's problem."
| » | Format usb ključkaOddelek: Pomoč in nasveti | 5119 (3028) | Skylord |
| » | Remix OS 64 bit (napačen) downloadOddelek: Operacijski sistemi | 4041 (3682) | m3k |
| » | ADATA S102 Pro 64 GB USB 3.0Oddelek: Strojna oprema | 1898 (1628) | Han |
| » | Sveža namestitev na prenosnik s hibridnim diskomOddelek: Operacijski sistemi | 1024 (931) | legion |
| » | Inštaliranje Windows7 iz usbOddelek: Pomoč in nasveti | 4409 (3966) | king67 |
