vb6
vb6
jzupevc ::
Kaka je procedura oziroma funkcija v VB6 za restart PC
Gandalfar ::
ExitWindowsEx
Zzzzzzz ::
Funkcije same, ki bi to delala v VB-ju ni. Je treba psoeči po API funkcijah. Poglej spodnji primer:
'In general section
Const EWX_LOGOFF = 0
Const EWX_SHUTDOWN = 1
Const EWX_REBOOT = 2
Const EWX_FORCE = 4
Private Declare Function ExitWindowsEx Lib "user32" (ByVal uFlags As Long, ByVal dwReserved As Long) As Long
Private Sub Form_Load()
'KPD-Team 1998
'URL: http://www.allapi.net/
'E-Mail: KPDTeam@Allapi.net
msg = MsgBox("This program is going to reboot your computer. Press OK to continue or Cancel to stop.", vbCritical + vbOKCancel + 256, App.Title)
If msg = vbCancel Then End
'reboot the computer
ret& = ExitWindowsEx(EWX_FORCE Or EWX_REBOOT, 0)
End Sub
StratOS ::
ja za navadne windowse, za NT moreš pa še security tokene uštimat .
[C#] Prosim pomagajte! Potrebujem program, ki bi pobiral podatke iz ene strani
Oddelek: Programiranje
213223 (2833) David1994
API+VB
262564 (2268) webblod
Odpiranje dat.exe v VB
123840 (3633) webblod
Visual basic Progress bar
52018 (1951) Lunik
Windows 2000 (nujno)
181423 (1191) andrej
