Forum » Pomoč in nasveti » A se to da narest?
A se to da narest?
trilko ::
Eno vprasanje. Mam 20 GB disk, fat32 particija. Ampak bi rd zdej ene 15 giga (filmi, mp3ji in ostale take zadeve) s tega diska presnel na enga drucga, potem na mojmu formatirov disk, naredu NTFS particijo in presnel z drugega diska vse tiste zadeve. Sm reku da morm prevert prej da mi ne bo pol zal ce ne bo delal...
teac ::
To gre, ker ntfs zazna fat32. Če pa bi imel sistem na fat32 in bi hotel kopirat iz ntfs particije pa to nebi šlo (fat32 ne zazna ntfs).
Aja...sicer pa si nabavi Partition Magic, pa sploh neboš rabil formatirat diska, ampak samo spremeniš particijo iz fat32 v ntfs.
- spremenilo: teac ()
Ribicija ::
NT-ji imajo en ukaz, ki ti spremeni particijo iz FAT v NTFS. Tudi če so programi gor se to lahko dela in se nič ne izgubi. Evo iz helpa copy/paste.
Converts FAT and FAT32 volumes to NTFS.
Syntax
convert [volume] /fs:ntfs [/v] [/cvtarea:FileName] [/nosecurity] [/x]
Parameters
volume
Specifies the drive letter (followed by a colon), mount point, or volume name to convert to NTFS.
/fs:ntfs
Required. Converts the volume to NTFS.
/v
Specifies verbose mode, that is, all messages will be displayed during conversion.
/cvtarea:FileName
For advanced users only. Specifies that the Master File Table (MFT) and other NTFS metadata files are written to an existing, contiguous placeholder file. This file must be in the root directory of the file system to be converted. Use of the /CVTAREA parameter can result in a less fragmented file system after conversion. For best results, the size of this file should be 1 KB multiplied by the number of files and directories in the file system, however, the convert utility accepts files of any size.
For more information about using the /cvtarea parameter, see "File Systems" at the Microsoft Windows XP Resource Kits Web site.(http://www.microsoft.com/)
Important
You must create the placeholder file using the fsutil file createnew command prior to running convert. Convert does not create this file for you. Convert overwrites this file with NTFS metadata. After conversion, any unused space in this file is freed. For more information about the fsutil file command, see Related Topics.
/nosecurity
Specifies that the converted files and directory security settings are accessible by everyone.
/x
Dismounts the volume, if necessary, before it is converted. Any open handles to the volume will no longer be valid.
Remarks
You must specify that the drive should be converted when the computer is restarted. Otherwise, you cannot convert the current drive.
If convert cannot lock the drive (for example, the system volume or the current drive), it offers to convert the drive the next time the computer restarts.
The location of the MFT is different on volumes that have been converted from previous version of NTFS, so volume performance might not be as good on volumes converted from Windows NT.
Volumes converted from FAT to NTFS lack some performance benefits compared to volumes initially formatted with NTFS. On converted volumes, the MFT might become fragmented. In addition, on converted boot volumes, NTFS permissions are not applied after the volume is converted.
Examples
To convert the volume on drive E to NTFS and display all messages, type:
convert e: /fs:ntfs /v
Syntax
Parameters
volume
/fs:ntfs
/v
/cvtarea:FileName
Important
/nosecurity
/x
Remarks
Examples
trilko ::
Ma mi nc ne pomaga ker mam ful enga sranja na disku pa sem itak hotu formatirat pa Win XP nalozit. Se neki me zanima: a winsi XP majo v instalaciji to moznost da ti v NTFS formatira?
| » | kako razsiriti datoteko večjo od 4gb?Oddelek: Pomoč in nasveti | 1720 (1720) | Mr.B |
| » | ? spremeniti FAT32 particijo v NTFS, ne da bi formatiral? Help!Oddelek: Operacijski sistemi | 3292 (3068) | ZLOky |
| » | FAT32 pretvorba v NTFS?Oddelek: Pomoč in nasveti | 2790 (2516) | astras |
| » | w2k in NTFS quick format?Oddelek: Programska oprema | 1874 (1748) | CaqKa |
| » | NTFSOddelek: Operacijski sistemi | 1777 (1628) | andrej |
